[GRASS-SVN] r60559 - grass-addons/grass7/raster/r.roughness.vector
Wed May 28 12:16:20 PDT 2014
Author: hellik
Date: 2014-05-28 12:16:20 -0700 (Wed, 28 May 2014)
New Revision: 60559
   grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
r.roughness.vector: add pythonized grass6 addon - step 6 - cleanup manual
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html	2014-05-28 18:37:52 UTC (rev 60558)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html	2014-05-28 19:16:20 UTC (rev 60559)
@@ -1,55 +1,92 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html><head><title>r.roughness.window.vector</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css"></head>
+<h2>DESCRIPTION</h2>
-<body style="background-color: white;">
-<img style="width: 76px; height: 91px;" src="grass_logo.png" alt="GRASS logo"><hr align="center" noshade="noshade" size="6"><h2>NAME</h2>
-<em><b>r.roughness.vector.py</b></em> - Calculates surface roughness in a moving-window, as the orientation of vectors normal to surface planes.
-<h2>KEYWORDS </h2>
-raster, elevation, slope, aspect
-<h2>SYNOPSIS</h2>
-<span style="font-weight: bold;">r.roughness.window.vector</span><br style="font-weight: bold;">
-<span style="font-weight: bold;">r.roughness.window.vector help</span><br>
-<span style="font-weight: bold;">r.roughness.window.vector</span> <b>map</b>=<em>string</em>
-[<b>slope</b>=<em>string</em>] [<b>aspect</b>=<em>stri</em>ng]
-[<b>window</b>=<em>integer</em>] [<span style="font-weight: bold;">strength</span>=<em>string</em>]
-[<span style="font-weight: bold;">fisher</span>=<em>string</em>] [<b>compass</b>=<em>string</em>]
-[<b>colatitude</b>=<em>string</em>] [<span style="font-weight: bold;">xcos</span><b></b>=<em>string</em>] [<span style="font-weight: bold;">ycos</span>=<em>string</em>] [<span style="font-weight: bold;">zcos</span>=<em>string</em>] [--<b>overwrite</b>] [--<b>verbose</b>] [--<b>quiet</b>]
-<h3>Flags:</h3>
-<dl><dt><b>--overwrite</b></dt>
-<dd>Allow output files to overwrite existing files</dd>
-<dt><b>--verbose</b></dt>
-<dd>Verbose module output</dd>
-<dt><b>--quiet</b></dt>
-<dd>Quiet module output</dd>
-</dl><h3>Parameters:</h3>
-<dl><dt><b>map</b>=<em>string</em></dt>
-<dd>Input elevation raster map</dd>
-<dt><b>slope</b>=<em>string</em></dt>
-<dd>Input slope map</dd>
-<dt><b>aspect</b>=<em>integer</em></dt>
-<dd>Input aspect map</dd><dt><b>window</b>=<em>integer</em></dt>
-<dd>Moving-window size (uses <span style="font-style: italic;">r.neighbors</span>)</dd><dt><b>strength</b>=<em>string (optional)</em></dt>
-<dd>Output "vector strength" map </dd><dt><b>fisher</b>=<em>string (optional)</em><em></em></dt>
-<dd>Output "Fisher's K parameter" map </dd><dt><b>compass</b>=<em>string</em><em> (optional)</em></dt>
-<dd>Input compass aspect map</dd><dt><b>colatitude</b>=<em>string</em><em> (optional)</em></dt><dd>Input colatitude map</dd><dt><b>xcos</b>=<em>string</em><em> (optional)</em></dt><dd>Input <span style="font-style: italic;">x</span> directional cosine map </dd><dt><b>ycos</b>=<em>string</em><em> (optional)</em></dt><dd>Input <span style="font-style: italic;">y</span> directional cosine map </dd><dt><b>zcos</b>=<em>string</em><em> (optional)</em></dt><dd>Input <span style="font-style: italic;">z</span> directional cosine map </dd></dl><h2>DESCRIPTION</h2>
-In this script surface roughness is taken as the dispersion of vectors
-normal to surface areas (pixels). Normal vectors are defined by
-slope and aspect.<br><br>This script will create several temporary
-maps, for the directional cosines in each direction (x,y,z), for the
-sum of these cosines and vector strengh.<br><br>The options <span style="font-style: italic;">compass</span>, <span style="font-style: italic;">colatitude</span>, <span style="font-style: italic;">xcos</span>, <span style="font-style: italic;">ycosm</span> and <span style="font-style: italic;">zcos</span>
-are created as temporary files each time the script is run. If the user
-wants to create several map (with different window sizes, for
-instance), it is recommended to create those maps with <span style="font-style: italic;">r.mapcalc</span> and use them as input:<br><br><span style="font-style: italic;">r.mapcalc compass = "if(aspect==0,0,if(aspect < 90, 90-aspect, 360+90-aspect))"</span><br style="font-style: italic;"><br style="font-style: italic;"><span style="font-style: italic;">r.mapcalc colatitude = "90 - slope"</span><br style="font-style: italic;"><br style="font-style: italic;"><span style="font-style: italic;">r.mapcalc xcos = "sin(colatitude)*cos(compass)"</span><br style="font-style: italic;"><br style="font-style: italic;"><span style="font-style: italic;">r.mapcalc ycos = "sin(colatitude)*sin(compass)"</span><br style="font-style: italic;"><br style="font-style: italic;"><span style="font-style: italic;">r.mapcalc zcos = "cos(colatitude)"</span><br style="font-style: italic;"><br><br><br>If the user does not specify the output maps names, they will be set to <span style="font-style: i
 talic;"><br><br>INPUT_MAP_vector_strength_NxN</span> <br>and<br><span style="font-style: italic;">INPUT_MAP_fisher_K_NxN</span><br><br>where N is the window size.<p>
-</p><h2>REFERENCES</h2><p>Hobson, R.D., 1972. Surface roughness in topography: quantitative approach. In: Chorley, R.J. (ed) <span style="font-style: italic;">Spatial analysis in geomorphology</span>. Methuer, London, p.225-245.<br></p><p>McKean, J. & Roering, J., 2004. <span style="font-style: italic;">Objective landslide detection and surface morphology mapping using high-resolution airborne laser altimetry. Geomorphology</span>, 57:331-351</p>
+<p>
+In this script surface roughness is taken as the dispersion of vectors
+normal to surface areas (pixels). Normal vectors are defined by slope
+and aspect.
+</p>
+<p>
+This script will create several temporary maps, for the directional
+cosines in each direction (x,y,z), for the sum of these cosines and
+vector strength.
+</p>
+<p>
+The options <em>compass</em>, <em>colatitude</em>, <em>xcos</em>,
+<em>ycosm</em> and <em>zcos</em> are created as temporary files each
+time the script is run.
+</p>
+<p>
+If the user wants to create several map (with different window sizes,
+for instance), it is recommended to create those maps with
+<em>r.mapcalc</em> and use them as input:
+</p>
+<div class="code">
+ <pre>
+  r.mapcalc compass = "if(aspect==0,0,if(aspect < 90, 90-aspect, 360+90-aspect))"
+  r.mapcalc colatitude = "90 - slope"
+  r.mapcalc xcos = "sin(colatitude)*cos(compass)"
+  r.mapcalc ycos = "sin(colatitude)*sin(compass)"
+  r.mapcalc zcos = "cos(colatitude)"
+ </pre>
+</div>
+<p>
+If the user does not specify the output maps names, they will be set to
+</p>
+<div class="code">
+ <pre>
+  <em>INPUT_MAP_vector_strength_NxN</em>
+ </pre>
+</div>
+and
+<div class="code">
+ <pre>
+  <em>INPUT_MAP_fisher_K_NxN</em>
+ </pre>
+</div>
+where N is the window size.
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+  # calculate roughness factor by search window = 5
+  r.roughness.vector elevation=DEM slope=slope aspect=aspect window=5
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>
+</em>
+<h2>REFERENCES</h2>
+<p>
+Hobson, R.D., 1972. Surface roughness in topography: quantitative
+approach. In: Chorley, R.J. (ed). <em>Spatial analysis in
+geomorphology</em>. Methuer, London, p.225-245.
+<br>
+<br>
+McKean, J. & Roering, J., 2004. <em>Objective landslide detection
+and surface morphology mapping using high-resolution airborne laser
+altimetry. Geomorphology</em>, 57:331-351.
+</p>
 <h2>AUTHORS</h2>
-Carlos Henrique Grohmann - Institute of Energy and Environment, University of São Paulo, Brazil.<br>
-Helmut Kudrnovsky - http://www.alectoria.at
+Carlos Henrique Grohmann - Institute of Energy and Environment, University of São Paulo, Brazil<br>
+Helmut Kudrnovsky
 <p>
-<i>Last changed: $Date$</i>
-</p><hr><p><a href="index.html">Main
-index</a> - <a href="raster.html">raster index</a>
-- <a href="full_index.html">Full index</a></p>
-</body></html>
\ No newline at end of file
+<i>Last changed: $Date$</i>
