[GRASS-SVN] r60586 - grass-addons/grass7/raster/r.roughness.vector
svn_grass at osgeo.org
Thu May 29 08:22:32 PDT 2014
Author: hellik
Date: 2014-05-29 08:22:32 -0700 (Thu, 29 May 2014)
New Revision: 60586
grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
r.roughness.vector: cleanup, wording
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html 2014-05-29 12:54:13 UTC (rev 60585)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html 2014-05-29 15:22:32 UTC (rev 60586)
@@ -15,15 +15,11 @@
<p>
The options <em>compass</em>, <em>colatitude</em>, <em>xcos</em>,
<em>ycosm</em> and <em>zcos</em> are created as temporary files each
-time the script is run.
+time the script is run. If the user wants to create several map (with
+different window sizes, for instance), it is recommended to create those
+maps with <em>r.mapcalc</em> and use them as input:
</p>
-<p>
-If the user wants to create several map (with different window sizes,
-for instance), it is recommended to create those maps with
-<em>r.mapcalc</em> and use them as input:
-</p>
<div class="code">
<pre>
r.mapcalc compass = "if(aspect==0,0,if(aspect < 90, 90-aspect, 360+90-aspect))"
@@ -78,14 +74,24 @@
geomorphology</em>. Methuer, London, p.225-245.
<br>
<br>
-McKean, J. & Roering, J., 2004. <em>Objective landslide detection
+McKean, J. & Roering, J., 2004. Objective landslide detection
and surface morphology mapping using high-resolution airborne laser
-altimetry. Geomorphology</em>, 57:331-351.
+altimetry. <em>Geomorphology</em>, 57:331-351.
+<a href="http://dx.doi.org/10.1016/S0169-555X(03)00164-8" target="_blank">http://dx.doi.org/10.1016/S0169-555X(03)00164-8</a>.
+<br>
+<br>
+Grohmann, C.H., Smith, M.J. & Riccomini, C., 2011. Multiscale Analysis
+of Topographic Surface Roughness in the Midland Valley, Scotland.
+<em>Geoscience and Remote Sensing, IEEE Transactions on</em>, 49:1200-1213.
+<a href="http://dx.doi.org/10.1109/TGRS.2010.2053546" target="_blank">http://dx.doi.org/10.1109/TGRS.2010.2053546</a>
</p>
<h2>AUTHORS</h2>
-Carlos Henrique Grohmann - Institute of Energy and Environment, University of São Paulo, Brazil<br>
+Carlos Henrique Grohmann - Institute of Energy and Environment,
+University of São Paulo, Brazil. (<a href="http://carlosgrohmann.com"
+target="_blank">http://carlosgrohmann.com</a>)
+<br>
Helmut Kudrnovsky
<p>
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py 2014-05-29 12:54:13 UTC (rev 60585)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py 2014-05-29 15:22:32 UTC (rev 60586)
@@ -36,7 +36,7 @@
#%Module
-#% description: Calculates surface roughness with a moving-window approach
+#% description: Calculates surface roughness in a moving-window, as the orientation of vectors normal to surface planes.
#% keywords: raster
#% keywords: terrain
#% keywords: aspect
@@ -52,20 +52,20 @@
#% key: slope
#% type: string
#% gisprompt: old,cell,raster
-#% description: Input raster slope map
+#% description: Input slope map
#% required : yes
#%end
#%option
#% key: aspect
#% type: string
-#% description: Input raster aspect map
+#% description: Input aspect map
#% required : yes
#%end
#%option
#% key: window
#% type: integer
-#% description: Window size (3,5,7,...,25)
+#% description: Moving-window size (uses r.neighbors)
#% required : no
#% answer : 3
#%end
@@ -73,49 +73,49 @@
#% key: strength
#% type: string
-#% description: Output vector strength map
+#% description: Output "vector strength" map
#% required : no
#%end
#%option
#% key: fisher
#% type: string
-#% description: Output Fischer's K parameter map
+#% description: Output "Fisher's K parameter" map
#% required : no
#%end
#%option
#% key: compass
#% type: string
-#% description: OPTIONAL INPUT: Compass aspect values (longitude)
+#% description: Input compass aspect map (optional)
#% required : no
#%end
#%option
#% key: colatitude
#% type: string
-#% description: OPTIONAL INPUT: Colatitude values (90 - slope)
+#% description: Input colatitude map (optional)
#% required : no
#%end
#%option
#% key: xcos
#% type: string
-#% description: OPTIONAL INPUT: X directional cosine map
+#% description: Input x directional cosine map (optional)
#% required : no
#%end
#%option
#% key: ycos
#% type: string
-#% description: OPTIONAL INPUT: Y directional cosine map
+#% description: Input y directional cosine map (optional)
#% required : no
#%end
#%option
#% key: zcos
#% type: string
-#% description: OPTIONAL INPUT: Z directional cosine map
+#% description: Input z directional cosine map (optional)
#% required : no
#%end
