[GRASS-SVN] r60587 - grass/branches/releasebranch_7_0/general/g.mlist
svn_grass at osgeo.org
Thu May 29 13:50:59 PDT 2014
Author: neteler
Date: 2014-05-29 13:50:59 -0700 (Thu, 29 May 2014)
New Revision: 60587
grass/branches/releasebranch_7_0/general/g.mlist/main.c
g.mlist: output= implemented by Martin & Huidae; check for mutually exclusive options/flags (backport of trunk, r60500)
Modified: grass/branches/releasebranch_7_0/general/g.mlist/main.c
--- grass/branches/releasebranch_7_0/general/g.mlist/main.c 2014-05-29 15:22:32 UTC (rev 60586)
+++ grass/branches/releasebranch_7_0/general/g.mlist/main.c 2014-05-29 20:50:59 UTC (rev 60587)
@@ -9,7 +9,7 @@
* PURPOSE: Lists available GRASS data base files of the
* user-specified data type to standard output
- * COPYRIGHT: (C) 1999-2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2014 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -27,9 +27,8 @@
static int any = 0;
-static void make_list(const struct list *,
- const char *, const char *,
- int, int, int, int);
+static void make_list(FILE *, const struct list *, const char *, const char *,
+ int, int, int);
int main(int argc, char *argv[])
@@ -41,6 +40,7 @@
struct Option *exclude;
struct Option *separator;
struct Option *mapset;
+ struct Option *output;
} opt;
struct
@@ -53,8 +53,9 @@
} flag;
int i, n, all, num_types, nlist;
void *filter = NULL, *exclude = NULL;
+ FILE *fp;
const char *mapset;
- char separator[2];
+ char *separator;
G_gisinit(argv[0]);
@@ -96,6 +97,11 @@
opt.separator = G_define_standard_option(G_OPT_F_SEP);
opt.separator->answer = "newline";
+ opt.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.output->required = NO;
+ opt.output->label = _("Name for output file");
+ opt.output->description = _("If not given or '-' then standard output");
flag.regex = G_define_flag();
flag.regex->key = 'r';
flag.regex->description =
@@ -131,6 +137,21 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (opt.output->answer && flag.pretty->answer)
+ G_fatal_error(_("output= and -p are mutually exclusive"));
+ if (opt.output->answer && flag.full->answer)
+ G_fatal_error(_("output= and -f are mutually exclusive"));
+ if (flag.type->answer && flag.pretty->answer)
+ G_fatal_error(_("-t and -p are mutually exclusive"));
+ if (flag.type->answer && flag.full->answer)
+ G_fatal_error(_("-t and -f are mutually exclusive"));
+ if (flag.full->answer && flag.pretty->answer)
+ G_fatal_error(_("-f and -p are mutually exclusive"));
if (flag.regex->answer && flag.extended->answer)
G_fatal_error(_("-r and -e are mutually exclusive"));
@@ -148,24 +169,16 @@
exclude = G_ls_glob_filter(opt.exclude->answer, 1);
- if (strcmp(opt.separator->answer, "newline") == 0)
- separator[0] = '\n';
- else if (strcmp(opt.separator->answer, "comma") == 0)
- separator[0] = ',';
- else if (strcmp(opt.separator->answer, "space") == 0)
- separator[0] = ' ';
- else if (strcmp(opt.separator->answer, "tab") == 0)
- separator[0] = '\t';
- else
- separator[0] = opt.separator->answer[0];
- separator[1] = 0;
+ separator = G_option_to_separator(opt.separator);
- mapset = opt.mapset->answer;
+ if (!opt.output->answer || strcmp(opt.output->answer, "-") == 0)
+ fp = stdout;
+ else if ((fp = fopen(opt.output->answer, "w")) == NULL)
+ G_fatal_error(_("Failed to create file [%s]"), opt.output->answer);
- if (mapset == NULL)
+ if ((mapset = opt.mapset->answer) == NULL)
mapset = "";
- if (G_strcasecmp(mapset, ".") == 0)
+ else if (strcmp(mapset, ".") == 0)
mapset = G_mapset();
for (i = 0; opt.type->answers[i]; i++) {
@@ -182,13 +195,16 @@
for (i = 0; i < num_types; i++) {
+ const struct list *elem;
n = all ? i : M_get_element(opt.type->answers[i]);
+ elem = M_get_list(n);
if (flag.full->answer) {
char lister[GPATH_MAX];
- sprintf(lister, "%s/etc/lister/%s", G_gisbase(),
- M_get_list(n)->element[0]);
+ sprintf(lister, "%s/etc/lister/%s", G_gisbase(), elem->element[0]);
G_debug(3, "lister CMD: %s", lister);
@@ -197,15 +213,19 @@
continue;
+ else if (flag.pretty->answer)
+ G_list_element(elem->element[0], elem->alias, mapset, NULL);
else
- make_list(M_get_list(n), mapset, separator,
- flag.pretty->answer, flag.type->answer,
+ make_list(fp, elem, mapset, separator, flag.type->answer,
flag.mapset->answer, mapset && *mapset);
- if (!flag.pretty->answer && any)
- fprintf(stdout, "\n");
+ if (any)
+ fprintf(fp, "\n");
+ if (fp != stdout)
+ fclose(fp);
if (filter)
G_free_ls_filter(filter);
@@ -215,10 +235,9 @@
exit(EXIT_SUCCESS);
- const struct list *elem,
- const char *mapset, const char *separator,
- int pretty, int add_type, int add_mapset, int single_mapset)
+static void make_list(FILE *fp, const struct list *elem, const char *mapset,
+ const char *separator, int add_type, int add_mapset,
+ int single_mapset)
char path[GPATH_MAX];
const char *element = elem->element[0];
@@ -227,16 +246,11 @@
int count;
int i;
- if (pretty) {
- G_list_element(element, alias, mapset, NULL);
- return;
if (!mapset || !*mapset) {
int n;
for (n = 0; mapset = G__mapset_name(n), mapset; n++)
- make_list(elem, mapset, separator,
- pretty, add_type, add_mapset, n == 0);
+ make_list(fp, elem, mapset, separator, add_type, add_mapset,
+ n == 0);
return;
@@ -244,19 +258,14 @@
if (access(path, 0) != 0)
return;
- list = G__ls(path, &count);
- if (!list)
+ if ((list = G__ls(path, &count)) == NULL)
return;
if (count > 0) {
- if (any) {
- if (pretty)
- else
- fprintf(stdout, "%s", separator);
- G_message(_("%s available in mapset <%s>:"),
- elem->text, mapset);
+ if (any)
+ fprintf(fp, "%s", separator);
+ if (fp == stdout)
+ G_message(_("%s available in mapset <%s>:"), elem->text, mapset);
/* Suppress "... found in more mapsets" warnings from G_find_file2. */
@@ -267,12 +276,12 @@
int need_mapset = 0;
if (any && i != 0)
if (add_type)
- fprintf(stdout, "%s/", alias);
+ fprintf(fp, "%s/", alias);
- fprintf(stdout, "%s", name);
+ fprintf(fp, "%s", name);
if (!add_mapset && !single_mapset) {
const char *mapset2 = G_find_file2(element, name, "");
@@ -280,7 +289,7 @@
need_mapset = strcmp(mapset, mapset2) != 0;
if (add_mapset || need_mapset)
- fprintf(stdout, "@%s", mapset);
+ fprintf(fp, "@%s", mapset);
G_free(name);
@@ -288,7 +297,7 @@
G_suppress_warnings(0);
- fflush(stdout);
+ fflush(fp);
G_free(list);
