[GRASS-SVN] r60588 - grass/branches/releasebranch_7_0/raster/r.series
Thu May 29 14:01:34 PDT 2014
Author: neteler
Date: 2014-05-29 14:01:34 -0700 (Thu, 29 May 2014)
New Revision: 60588
   grass/branches/releasebranch_7_0/raster/r.series/r.series.html
r.series manual: explain approach for Windows with g.mlist and file output
Modified: grass/branches/releasebranch_7_0/raster/r.series/r.series.html
--- grass/branches/releasebranch_7_0/raster/r.series/r.series.html	2014-05-29 20:50:59 UTC (rev 60587)
+++ grass/branches/releasebranch_7_0/raster/r.series/r.series.html	2014-05-29 21:01:34 UTC (rev 60588)
@@ -130,8 +130,14 @@
 Example for counting the number of days above a certain temperature using
 daily average maps ('???' as DOY wildcard):
 <div class="code"><pre>
-r.series input=`g.mlist rast pat="temp_2003_???_avg" sep=,` \
+# Approach for shell based systems
+r.series input=`g.mlist rast pattern="temp_2003_???_avg" sep=,` \
          output=temp_2003_days_over_25deg range=25.0,100.0 method=count
+# Approach in two steps (e.g., for Windows systems)
+g.mlist rast pattern="temp_2003_???_avg" output=mapnames.txt
+r.series file=mapnames.txt \
+         output=temp_2003_days_over_25deg range=25.0,100.0 method=count
 </pre></div>
