[GRASS-SVN] r60589 - grass/trunk/raster/r.series
svn_grass at osgeo.org
Thu May 29 14:02:00 PDT 2014
Author: neteler
Date: 2014-05-29 14:02:00 -0700 (Thu, 29 May 2014)
New Revision: 60589
grass/trunk/raster/r.series/r.series.html
r.series manual: explain approach for Windows with g.mlist and file output
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html 2014-05-29 21:01:34 UTC (rev 60588)
+++ grass/trunk/raster/r.series/r.series.html 2014-05-29 21:02:00 UTC (rev 60589)
@@ -130,8 +130,14 @@
Example for counting the number of days above a certain temperature using
daily average maps ('???' as DOY wildcard):
<div class="code"><pre>
-r.series input=`g.mlist rast pat="temp_2003_???_avg" sep=,` \
+# Approach for shell based systems
+r.series input=`g.mlist rast pattern="temp_2003_???_avg" sep=,` \
output=temp_2003_days_over_25deg range=25.0,100.0 method=count
+# Approach in two steps (e.g., for Windows systems)
+g.mlist rast pattern="temp_2003_???_avg" output=mapnames.txt
+r.series file=mapnames.txt \
+ output=temp_2003_days_over_25deg range=25.0,100.0 method=count
</pre></div>
