[GRASS-SVN] r60619 - grass/trunk/general/g.list
svn_grass at osgeo.org
Fri May 30 17:38:40 PDT 2014
Author: wenzeslaus
Date: 2014-05-30 17:38:40 -0700 (Fri, 30 May 2014)
New Revision: 60619
Added:
grass/trunk/general/g.list/test_g_list.py
g.list: tests for most important functionality
Added: grass/trunk/general/g.list/test_g_list.py
--- grass/trunk/general/g.list/test_g_list.py (rev 0)
+++ grass/trunk/general/g.list/test_g_list.py 2014-05-31 00:38:40 UTC (rev 60619)
@@ -0,0 +1,225 @@
+import unittest
+from grass.script import read_command
+LIST_RASTERS = """----------------------------------------------
+raster files available in mapset <PERMANENT>:
+aspect elevation_shade lsat7_2002_70
+basin_50K facility lsat7_2002_80
+boundary_county_500m geology_30m ncmask_500m
+cfactorbare_1m lakes ortho_2001_t792_1m
+cfactorgrow_1m landclass96 roadsmajor
+el_D782_6m landcover_1m slope
+el_D783_6m landuse96_28m soilsID
+el_D792_6m lsat7_2002_10 soils_Kfactor
+el_D793_6m lsat7_2002_20 streams_derived
+elev_lid792_1m lsat7_2002_30 towns
+elev_ned_30m lsat7_2002_40 urban
+elev_srtm_30m lsat7_2002_50 zipcodes
+elev_state_500m lsat7_2002_61 zipcodes_dbl
+elevation lsat7_2002_62
+raster files available in mapset <landsat>:
+lsat5_1987_10 lsat5_1987_40 lsat5_1987_70 lsat7_2000_30 lsat7_2000_61
+lsat5_1987_20 lsat5_1987_50 lsat7_2000_10 lsat7_2000_40 lsat7_2000_70
+lsat5_1987_30 lsat5_1987_60 lsat7_2000_20 lsat7_2000_50 lsat7_2000_80
+LIST_VECTORS = """----------------------------------------------
+vector files available in mapset <PERMANENT>:
+P079214 elev_lid792_bepts poi_names_wake
+P079215 elev_lid792_cont1m precip_30ynormals
+P079218 elev_lid792_randpts precip_30ynormals_3d
+P079219 elev_lidrural_mrpts railroads
+boundary_county elev_lidrural_mrptsft roadsmajor
+boundary_municp elev_ned10m_cont10m schools_wake
+bridges firestations soils_general
+busroute1 geodetic_pts soils_wake
+busroute11 geodetic_swwake_pts streams
+busroute6 geology streets_wake
+busroute_a geonames_NC swwake_10m
+busroutesall geonames_wake urbanarea
+busstopsall hospitals usgsgages
+census_wake2000 lakes zipcodes_wake
+censusblk_swwake nc_state
+comm_colleges overpasses
+LIST_GROUPS = """----------------------------------------------
+imagery group files available in mapset <landsat>:
+lsat7_2000
+LIST_RASTERS_MAPSET = """----------------------------------------------
+LIST_RASTERS_TITLES = """----------------------------------------------
+aspect South-West Wake county: Aspect [degrees from east]
+basin_50K South-West Wake county: Watersheds derived from 30m NED
+boundary_county_500m North Carolina county boundaries
+cfactorbare_1m Rural area: C-factor with fields bare
+cfactorgrow_1m Rural area: C-factor for growing season
+el_D782_6m NC Flood lidar-based 6m(20ft) DEM
+el_D783_6m NC Flood lidar-based 6m(20ft) DEM
+el_D792_6m NC Flood lidar-based 6m(20ft) DEM
+el_D793_6m NC Flood lidar-based 6m(20ft) DEM
+elev_lid792_1m Rural area: Lidar-based 1m DEM
+elev_ned_30m South-West Wake county: National Elevation Data 30m
+elev_srtm_30m South-West Wake county: SRTM-V1 30m terrain surface model
+elev_state_500m North Carolina DEM 500m
+elevation South-West Wake county: Elevation NED 10m
+elevation_shade South-West Wake county: Shaded relief
+facility Rural area: Footprint of planned facility
+geology_30m South-West Wake county: geology derived from vector map
+lakes South-West Wake county: Wake county lakes
+landclass96 South-West Wake county: Simplified landuse classes
+landcover_1m Rural area: Landcover
+landuse96_28m South-West Wake county: NC Land Use 1996 clipped
+lsat7_2002_10 LANDSAT-TM7 Band 1 Visible (0.45-0.52um) 30m
+lsat7_2002_20 LANDSAT-TM7 Band 2 Visible (0.52-0.60um) 30m
+lsat7_2002_30 LANDSAT-TM7 Band 3 Visible (0.63-0.69um) 30m
+lsat7_2002_40 LANDSAT-TM7 Band 4 Near Infrared (NIR) (0.76-0.90um) 30m
+lsat7_2002_50 LANDSAT-TM7 Band 5 Near Infrared (NIR) (1.55-1.75um) 30m
+lsat7_2002_61 LANDSAT-TM7 Band 6 Thermal (10.40-12.50um) 60m Low Gain
+lsat7_2002_62 LANDSAT-TM7 Band 6 Thermal (10.40-12.50um) 60m High Gain
+lsat7_2002_70 LANDSAT-TM7 Band 7 Mid Infrared (MIR) (2.08-2.35um) 30m
+lsat7_2002_80 LANDSAT-TM7 Band 8 Panchromatic (PAN) (0.52-0.90um (15m)
+ncmask_500m North Carolina boundary MASK
+ortho_2001_t792_1m Rural area (792 tile) NC Flood Orthophoto 2001
+roadsmajor South-West Wake county: roadsmajor
+slope South-West Wake county: slope in degrees
+soilsID South-West Wake county: Soils: ID
+soils_Kfactor Rural area: Soils: K-factor
+streams_derived South-West Wake county: Streams derived from 10m DEM
+towns South West Wake: Cities and towns derived from zipcodes
+urban South West Wake: Urban areas derived from vector map
+zipcodes South West Wake: Zipcode areas derived from vector map
+zipcodes_dbl South West Wake: Zipcode areas from vector map, fp
+lsat5_1987_10 LANDSAT-TM5 Band 1 Visible (0.45-0.52um) 30m
+lsat5_1987_20 LANDSAT-TM5 Band 2 Visible (0.52-0.60um) 30m
+lsat5_1987_30 LANDSAT-TM5 Band 3 Visible (0.63-0.69um) 30m
+lsat5_1987_40 LANDSAT-TM5 Band 4 Near Infrared (NIR) (0.76-0.90um) 30m
+lsat5_1987_50 LANDSAT-TM5 Band 5 Near Infrared (NIR) (1.55-1.75um) 30m
+lsat5_1987_60 LANDSAT-TM5 Band 6 Thermal (10.40-12.50um) 120m
+lsat5_1987_70 LANDSAT-TM5 Band 7 Mid Infrared (MIR) (2.08-2.35um) 30m
+lsat7_2000_10 LANDSAT-TM7 Band 1 Visible (0.45-0.52um) 30m
+lsat7_2000_20 LANDSAT-TM7 Band 2 Visible (0.52-0.60um) 30m
+lsat7_2000_30 LANDSAT-TM7 Band 3 Visible (0.63-0.69um) 30m
+lsat7_2000_40 LANDSAT-TM7 Band 4 Near Infrared (NIR) (0.76-0.90um) 30m
+lsat7_2000_50 LANDSAT-TM7 Band 5 Near Infrared (NIR) (1.55-1.75um) 30m
+lsat7_2000_61 LANDSAT-TM7 Band 6 Thermal (10.40-12.50um) 60m Low Gain
+lsat7_2000_70 LANDSAT-TM7 Band 7 Mid Infrared (MIR) (2.08-2.35um) 30m
+lsat7_2000_80 LANDSAT-TM7 Band 8 Panchromatic (PAN) (0.52-0.90um (15m)
+LIST_RASTERS_TITLES_MAPSET = """----------------------------------------------
+class GListTest(unittest.TestCase):
+ def setUp(self):
+ pass
+ def test_list_rasters(self):
+ """Test human readable list of rasters.
+ Supposing we are in user1 of NC and have access
+ to landsat (besides PERMANENT).
+ self.maxDiff = None
+ stdout = read_command('g.list', type='rast')
+ self.assertMultiLineEqual(stdout, LIST_RASTERS)
+ def test_list_vectors(self):
+ """Test human readable list of vectors.
+ stdout = read_command('g.list', type='vect')
+ self.assertMultiLineEqual(stdout, LIST_VECTORS)
+ def test_list_groups(self):
+ """Test human readable list of imagery groups.
+ stdout = read_command('g.list', type='group')
+ self.assertMultiLineEqual(stdout, LIST_GROUPS)
+ def test_list_rasters_in_mapset(self):
+ """Test human readable list of rasters in a specific mapset.
+ stdout = read_command('g.list', type='rast', mapset='landsat')
+ self.assertMultiLineEqual(stdout, LIST_RASTERS_MAPSET)
+ def test_list_rasters_titles(self):
+ """Test human readable list of rasters with titles.
+ stdout = read_command('g.list', flags='f', type='rast')
+ self.assertMultiLineEqual(stdout, LIST_RASTERS_TITLES)
+ def test_list_rasters_titles_in_mapset(self):
+ in a specific mapset.
+ stdout = read_command('g.list', flags='f', type='rast',
+ mapset='landsat')
+ self.assertMultiLineEqual(stdout, LIST_RASTERS_TITLES_MAPSET)
+ def tearDown(self):
+ pass
+if __name__ == '__main__':
+ unittest.main()
Property changes on: grass/trunk/general/g.list/test_g_list.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
