[GRASS-SVN] r60620 - in sandbox/annakrat: . r3.flow
Fri May 30 19:11:14 PDT 2014
Author: annakrat
Date: 2014-05-30 19:11:14 -0700 (Fri, 30 May 2014)
New Revision: 60620
Added:
   sandbox/annakrat/r3.flow/
   sandbox/annakrat/r3.flow/integrate.py
   sandbox/annakrat/r3.flow/r3.flow.html
   sandbox/annakrat/r3.flow/r3.flow.py
   sandbox/annakrat/r3.flow/rast3d_functions.py
   sandbox/annakrat/r3.flow/test_interpolation.py
initial r3.flow GSoC code added to sandbox
Added: sandbox/annakrat/r3.flow/integrate.py
--- sandbox/annakrat/r3.flow/integrate.py	                        (rev 0)
+++ sandbox/annakrat/r3.flow/integrate.py	2014-05-31 02:11:14 UTC (rev 60620)
@@ -0,0 +1,50 @@
+# -*- coding: utf-8 -*-
+ at author: Anna Petrasova
+from rast3d_functions import get_velocity
+# nice explanation of runge-kutta with picture:
+# http://www.marekfiser.com/Projects/Vector-field-visualization-on-GPU-using-CUDA/
+#4-Vector-field-integrators-for-stream-line-visualization
+def integrate_next(rast3d_region, arrays, point, delta_t):
+    k1 = [None] * 3
+    k2 = [None] * 3
+    k3 = [None] * 3
+    k4 = [None] * 3
+    x, y, z = point[0], point[1], point[2]
+    # first
+    velocity = get_velocity(rast3d_region, arrays[0], arrays[1], arrays[2], x, y, z)
+    if velocity is None:
+        return None
+    for i in range(3):
+        k1[i] = delta_t * velocity[i]
+    # second
+                            x + k1[0] / 2, y + k1[1] / 2, z + k1[2] / 2)
+        return None
+        k2[i] = delta_t * velocity[i]
+    # third
+                            x + k2[0] / 2, y + k2[1] / 2, z + k2[2] / 2)
+        return None
+        k3[i] = delta_t * velocity[i]
+    # fourth
+                            x + k3[0], y + k3[1], z + k3[2])
+        return None
+        k4[i] = delta_t * velocity[i]
+    print k1, k2, k3, k4
+    # next point
+    next_point = [None] * 3
+        next_point[i] = point[i] + k1[i] / 6 + k2[i] / 3 + k3[i] / 3 + k4[i] / 6
+    return next_point
Added: sandbox/annakrat/r3.flow/r3.flow.html
--- sandbox/annakrat/r3.flow/r3.flow.html	                        (rev 0)
+++ sandbox/annakrat/r3.flow/r3.flow.html	2014-05-31 02:11:14 UTC (rev 60620)
@@ -0,0 +1,27 @@
+<h2>DESCRIPTION</h2>
+<h2>NOTES</h2>
+<h2>EXAMPLE</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.flow.html">r3.flow</a>
+</em>
+<h2>AUTHOR</h2>
+Anna Petrasova<br>
+<i><a href="http://gis.ncsu.edu/osgeorel/">NCSU OSGeoREL</a></i>
+<p>
+<i>Last changed: $Date: 2013-02-15 23:08:41 +0100 (Fri, 15 Feb 2013) $</i>
Added: sandbox/annakrat/r3.flow/r3.flow.py
--- sandbox/annakrat/r3.flow/r3.flow.py	                        (rev 0)
+++ sandbox/annakrat/r3.flow/r3.flow.py	2014-05-31 02:11:14 UTC (rev 60620)
@@ -0,0 +1,95 @@
+#!/usr/bin/env python
+# MODULE:       r3.flow
+# AUTHOR:       Anna Petrasova
+# PURPOSE:
+# COPYRIGHT:    (c) 2014 the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#		This program is distributed in the hope that it will be useful,
+#		but WITHOUT ANY WARRANTY; without even the implied warranty of
+#		MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#		GNU General Public License for more details.
+#%module
+#% description: Generate 3D flow lines from 3D raster representing velocity field
+#% keywords: raster3d
+#% keywords: vector
+#%end
+#%option G_OPT_R3_INPUT
+#% description: Names of three 3D raster maps describing x, y, z components of vector field
+#%end
+#%option G_OPT_V_INPUT
+#% key: seed_points
+#% description:
+#% label: Name of vector map with points from which flow lines are generated
+#%end
+#%option G_OPT_V_OUTPUT
+#% description: Name of vector map of flow lines
+#%end
+from grass.script import core as gcore
+from grass.script import array as garray
+from grass.script import raster3d as grast3d
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.vector.geometry import Line, Point
+from interpolate import integrate_next
+def main():
+    options, flags = gcore.parser()
+    try:
+        v_x, v_y, v_z = options['input'].split(',')
+    except ValueError:
+        gcore.fatal(_("Please provide 3 input 3D raster maps."))
+    # read input 3D maps
+    velocity = [garray.array3d(), garray.array3d(), garray.array3d()]
+    for inp, vel in zip((v_x, v_y, v_z), velocity):
+        if vel.read(mapname=inp) != 0:
+            gcore.fatal(_("Error when reading input 3D raster maps"))
+    map_info = grast3d.raster3d_info(v_x)
+    # how to estimate default delta t?
+    delta_T = map_info['nsres'] / map_info['max']
+    # read seed points
+    seeds = []
+    inp_seeds = VectorTopo(options['seed_points'])
+    inp_seeds.open()
+    for point in inp_seeds:
+        point.is2D = False  # just a workaround
+        seeds.append((point.x, point.y, point.z))
+    inp_seeds.close()
+    # create new vector map to store flow lines
+    flowline_vector = VectorTopo(options['output'])
+    if flowline_vector.exist() and not gcore.overwrite:
+        gcore.fatal(_("Vector map <{flowlines}> already exists.").format(flowlines=flowline_vector))
+    flowline_vector.open('w')
+    for seed in seeds:
+        line = Line([Point(seed[0], seed[1], seed[2])])
+        point = seed
+        while True:
+            point = integrate_next(map_info, velocity, point, delta_T)
+            if point is None:
+                if len(line) > 1:
+                    flowline_vector.write(line)
+                break
+            line.append(Point(point[0], point[1], point[2]))
+    flowline_vector.close()
+if __name__ == '__main__':
+    main()
Added: sandbox/annakrat/r3.flow/rast3d_functions.py
--- sandbox/annakrat/r3.flow/rast3d_functions.py	                        (rev 0)
+++ sandbox/annakrat/r3.flow/rast3d_functions.py	2014-05-31 02:11:14 UTC (rev 60620)
@@ -0,0 +1,106 @@
+#from grass.script import raster3d as grast3d
+def get_velocity(rast3d_region, v_x, v_y, v_z, x, y, z):
+    """Returns tuple of interpolated velocity values
+    in xyz components for a given point"""
+    vel_x = rast3d_get_window_value(rast3d_region, v_x, y, x, z)
+    vel_y = rast3d_get_window_value(rast3d_region, v_y, y, x, z)
+    vel_z = rast3d_get_window_value(rast3d_region, v_z, y, x, z)
+    if vel_x is None or vel_y is None or vel_z is None:
+        return None
+    return vel_x, vel_y, vel_z
+# following functions are already in raster3d library, this is simpler Python version
+# except for trilinear interpolation which could be added there.
+def rast3d_location2coord(rast3d_region, north, east, top):
+    """!Returns column, row and depth of a cell where the input
+    coordinates (north, east, top) lie."""
+    col = int((east - rast3d_region['west']) / rast3d_region['ewres'])
+    row = int((rast3d_region['north'] - north) / rast3d_region['nsres'])
+    depth = int((top - rast3d_region['bottom']) / rast3d_region['tbres'])
+    return col, row, depth
+def rast3d_get_value_region(rast3d_region, array, col, row, depth):
+    """Returns value of 3D raster array in particular column, row and depth.
+    Returns None if it is outside of array."""
+    if col < 0 or col >= rast3d_region['cols'] or \
+       row < 0 or row >= rast3d_region['rows'] or \
+       depth < 0 or depth >= rast3d_region['depths']:
+        return None
+    return array[depth][row][col]
+def rast3d_get_window_value(rast3d_region, array, north, east, top):
+    """Returns interpolated value in a point defined by geogr. coordinates"""
+    return rast3d_trilinear_interpolation(rast3d_region, array, north, east, top)
+def rast3d_trilinear_interpolation(rast3d_region, array, north, east, top):
+    """Linearly interpolates value in a given point from the 8 closest cells
+    based on the centers of cells."""
+    reg = rast3d_region
+    # find nearest cells
+    points = [(north - reg['nsres'] / 2., east - reg['ewres'] / 2., top - reg['tbres'] / 2.),
+              (north - reg['nsres'] / 2., east + reg['ewres'] / 2., top - reg['tbres'] / 2.),
+              (north + reg['nsres'] / 2., east - reg['ewres'] / 2., top - reg['tbres'] / 2.),
+              (north + reg['nsres'] / 2., east + reg['ewres'] / 2., top - reg['tbres'] / 2.),
+              (north - reg['nsres'] / 2., east - reg['ewres'] / 2., top + reg['tbres'] / 2.),
+              (north - reg['nsres'] / 2., east + reg['ewres'] / 2., top + reg['tbres'] / 2.),
+              (north + reg['nsres'] / 2., east - reg['ewres'] / 2., top + reg['tbres'] / 2.),
+              (north + reg['nsres'] / 2., east + reg['ewres'] / 2., top + reg['tbres'] / 2.)]
+    # get values of the nearest cells
+    values = []
+    for point in points:
+        col, row, depth = rast3d_location2coord(reg, *point)
+        value = rast3d_get_value_region(reg, array, col, row, depth)
+        if value is None:
+            values.append(0)
+        else:
+            values.append(value)
+    # compute weights
+    col, row, depth = rast3d_location2coord(reg, north, east, top)
+    if rast3d_get_value_region(reg, array, col, row, depth) is None:
+        return None
+    # hm, is there some more elegant way?
+    # x
+    temp = east - reg['west'] - col * reg['ewres']
+    x = (temp - reg['ewres'] / 2. if temp > reg['ewres'] / 2. else temp + reg['ewres'] / 2.) / reg['ewres']
+    rx = 1 - x
+    # y
+    temp = north - reg['south'] - (reg['rows'] - row - 1) * reg['nsres']
+    y = (temp - reg['nsres'] / 2. if temp > reg['nsres'] / 2. else temp + reg['nsres'] / 2.) / reg['nsres']
+    ry = 1 - y
+    # z
+    temp = top - reg['bottom'] - depth * reg['tbres']
+    z = (temp - reg['tbres'] / 2. if temp > reg['tbres'] / 2. else temp + reg['tbres'] / 2.) / reg['tbres']
+    rz = 1 - z
+    weights = [rx * ry * rz,
+               x * ry * rz,
+               rx * y * rz,
+               x * y * rz,
+               rx * ry * z,
+               x * ry * z,
+               rx * y * z,
+               x * y * z]
+    # weighted of surrounding values
+    value = 0
+    for i in range(len(weights)):
+        value += weights[i] * values[i]
+    return value
Added: sandbox/annakrat/r3.flow/test_interpolation.py
--- sandbox/annakrat/r3.flow/test_interpolation.py	                        (rev 0)
+++ sandbox/annakrat/r3.flow/test_interpolation.py	2014-05-31 02:11:14 UTC (rev 60620)
@@ -0,0 +1,51 @@
+ at brief test trilinear interpolation by comparing to scipy implementation
+import unittest
+from random import uniform
+from rast3d_functions import rast3d_trilinear_interpolation
+class TestTrivariateInterpolation(unittest.TestCase):
+    def setUp(self):
+        from scipy import ndimage
+        gcore.use_temp_region()
+        self.name = 'random_voxel'
+        self.minim = -25.
+        self.maxim = 123.
+        self.res = 5.
+    def test_interpolation(self):
+        gcore.run_command('g.region', n=self.maxim, s=self.minim, e=self.maxim, w=self.minim,
+                          t=self.maxim, b=self.minim, res3=self.res)
+        gcore.run_command('r3.mapcalc', expression=self.name + ' = rand(-20,500)')
+        rast3d = garray.array3d()
+        rast3d.read(mapname=self.name)
+        reg = grast3d.raster3d_info(self.name)
+        for i in range(100):
+            # avoid edges because numpy gives always 0
+            point = [uniform(self.minim + reg['ewres'] / 2., self.maxim - reg['ewres'] / 2.),
+                     uniform(self.minim + reg['nsres'] / 2., self.maxim - reg['nsres'] / 2.),
+                     uniform(self.minim + reg['tbres'] / 2., self.maxim - reg['tbres'] / 2.)]
+            tested = rast3d_trilinear_interpolation(reg, rast3d, point[1], point[0], point[2])
+            coordinates = [[(point[2] - 0.5 * reg['tbres'] - self.minim) / reg['tbres']],
+                          [(reg['north'] - point[1] - 0.5 * reg['nsres']) / reg['nsres']],
+                          [(point[0] - 0.5 * reg['ewres'] - self.minim) / reg['ewres']]]
+            reference = ndimage.map_coordinates(rast3d, order=1, coordinates=coordinates)
+            self.assertAlmostEqual(tested, reference, places=4)
+    def tearDown(self):
+        gcore.run_command('g.remove', rast3d=self.name)
+        gcore.del_temp_region()
+    unittest.main()
