[GRASS-SVN] r62590 - grass/trunk/vector
Tue Nov 4 07:03:40 PST 2014
Author: neteler
Date: 2014-11-04 07:03:40 -0800 (Tue, 04 Nov 2014)
New Revision: 62590
   grass/trunk/vector/vectorintro.html
vectorintro.html: minor fixes
Modified: grass/trunk/vector/vectorintro.html
--- grass/trunk/vector/vectorintro.html	2014-11-04 13:57:04 UTC (rev 62589)
+++ grass/trunk/vector/vectorintro.html	2014-11-04 15:03:40 UTC (rev 62590)
@@ -91,7 +91,7 @@
 <p>
 Area topology also holds information about isles. These isles are located
 within that area, not touching the boundaries of the outer area. Isles
-are holes inside the area, can consist of one or more areas and are used
+are holes inside the area, and can consist of one or more areas. They are used
 internally to maintain correct topology for areas.
 <p>
@@ -226,7 +226,7 @@
 The module <a href="v.in.region.html">v.in.region</a> saves the
 current region extents as a vector area.
-Split vector lines can be changes to polylines by
+Split vector lines can be converted to polylines by
 <a href="v.build.polylines.html">v.build.polylines</a>. Long lines can be
 split by <a href="v.split.html">v.split</a> and
 <a href="v.segment.html">v.segment</a>.
@@ -368,10 +368,10 @@
 <h3>See also</h3>
 <ul>
-  <li><a href="rasterintro.html">Introduction into raster data processing</a></li>
-  <li><a href="raster3dintro.html">Introduction into 3D raster data (voxel) processing</a></li>
-  <li><a href="vectorintro.html">Introduction into vector data processing</a></li>
-  <li><a href="imageryintro.html">Introduction into image processing</a></li>
-  <li><a href="databaseintro.html">Database management</a></li>
+  <li><a href="databaseintro.html">Introduction to database management</a></li>
+  <li><a href="rasterintro.html">Introduction to raster data processing</a></li>
+  <li><a href="raster3dintro.html">Introduction to 3D raster data (voxel) processing</a></li>
+  <li><a href="vectorintro.html">Introduction to vector data processing</a></li>
+  <li><a href="imageryintro.html">Introduction to image processing</a></li>
   <li><a href="projectionintro.html">Projections and spatial transformations</a></li>
 </ul>
