[GRASS-SVN] r62591 - grass/branches/releasebranch_7_0/vector
svn_grass at osgeo.org
Tue Nov 4 07:03:45 PST 2014
Author: neteler
Date: 2014-11-04 07:03:45 -0800 (Tue, 04 Nov 2014)
New Revision: 62591
grass/branches/releasebranch_7_0/vector/vectorintro.html
vectorintro.html: minor fixes
Modified: grass/branches/releasebranch_7_0/vector/vectorintro.html
--- grass/branches/releasebranch_7_0/vector/vectorintro.html 2014-11-04 15:03:40 UTC (rev 62590)
+++ grass/branches/releasebranch_7_0/vector/vectorintro.html 2014-11-04 15:03:45 UTC (rev 62591)
@@ -91,7 +91,7 @@
<p>
Area topology also holds information about isles. These isles are located
within that area, not touching the boundaries of the outer area. Isles
-are holes inside the area, can consist of one or more areas and are used
+are holes inside the area, and can consist of one or more areas. They are used
internally to maintain correct topology for areas.
<p>
@@ -226,7 +226,7 @@
The module <a href="v.in.region.html">v.in.region</a> saves the
current region extents as a vector area.
-Split vector lines can be changes to polylines by
+Split vector lines can be converted to polylines by
<a href="v.build.polylines.html">v.build.polylines</a>. Long lines can be
split by <a href="v.split.html">v.split</a> and
<a href="v.segment.html">v.segment</a>.
@@ -368,10 +368,10 @@
<h3>See also</h3>
<ul>
- <li><a href="rasterintro.html">Introduction into raster data processing</a></li>
- <li><a href="raster3dintro.html">Introduction into 3D raster data (voxel) processing</a></li>
- <li><a href="vectorintro.html">Introduction into vector data processing</a></li>
- <li><a href="imageryintro.html">Introduction into image processing</a></li>
- <li><a href="databaseintro.html">Database management</a></li>
+ <li><a href="databaseintro.html">Introduction to database management</a></li>
+ <li><a href="rasterintro.html">Introduction to raster data processing</a></li>
+ <li><a href="raster3dintro.html">Introduction to 3D raster data (voxel) processing</a></li>
+ <li><a href="vectorintro.html">Introduction to vector data processing</a></li>
+ <li><a href="imageryintro.html">Introduction to image processing</a></li>
<li><a href="projectionintro.html">Projections and spatial transformations</a></li>
</ul>
