[GRASS-SVN] r62647 - in grass/trunk/temporal/t.rast.algebra: . testsuite
svn_grass at osgeo.org
Thu Nov 6 15:00:49 PST 2014
Author: huhabla
Date: 2014-11-06 15:00:49 -0800 (Thu, 06 Nov 2014)
New Revision: 62647
Added:
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
temporal modules: Enabled granularity based algebra in t.rast.mapcalc and added tests
Modified: grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2014-11-06 22:19:11 UTC (rev 62646)
+++ grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2014-11-06 23:00:49 UTC (rev 62647)
@@ -56,7 +56,12 @@
#% description: Register Null maps
#%end
+#%flag
+#% key: g
+#% description: Use granularity sampling instead of the temporal topology approach
+#%end
import grass.script
import grass.temporal as tgis
import sys
@@ -67,6 +72,7 @@
nprocs = options["nprocs"]
spatial = flags["s"]
register_null = flags["n"]
+ granularity = flags["g"]
# Check for PLY istallation
try:
@@ -75,10 +81,14 @@
except:
grass.script.fatal(_("Please install PLY (Lex and Yacc Python implementation) to use the temporal algebra modules. "
"You can use t.rast.mapcalc that provides a limited but useful alternative to "
- "t.rast.mapcalc2 without PLY requirement."))
+ "t.rast.algebra without PLY requirement."))
tgis.init(True)
p = tgis.TemporalRasterAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs, register_null = register_null)
+ if granularity:
+ p.setup_common_granularity(expression=expression, lexer = tgis.TemporalRasterAlgebraLexer())
p.parse(expression, basename, grass.script.overwrite())
if __name__ == "__main__":
Added: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py (rev 0)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2014-11-06 23:00:49 UTC (rev 62647)
@@ -0,0 +1,227 @@
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import datetime
+import os
+import grass.script
+import grass.temporal as tgis
+import grass.gunittest as gunittest
+class TestTRastAlgebraGranularity(gunittest.TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ os.putenv("GRASS_OVERWRITE", "1")
+ tgis.init(True) # Raise on error instead of exit(1)
+ cls.use_temp_region()
+ cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+ w=0.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a5 = 5")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a6 = 6")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 7")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 8")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="c1 = 9")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d1 = 10")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d2 = 11")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d3 = 12")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 99")
+ tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+ title="A", descr="A", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+ title="B", descr="B", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="C", type="strds", temporaltype="absolute",
+ title="C", descr="C", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="D", type="strds", temporaltype="absolute",
+ title="D", descr="D", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1,a2,a3,a4,a5,a6",
+ start="2001-01-01", increment="1 month", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="B", maps="b1,b2",
+ start="2001-01-01", increment="3 months", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="C", maps="c1",
+ start="2001-01-01", increment="1 year", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1",
+ start="2001-01-01", increment="5 days", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d2",
+ start="2001-03-01", increment="5 days", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d3",
+ start="2001-05-01", increment="5 days", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name=None, maps="singletmap",
+ start="2001-03-01", end="2001-04-01", interval=True)
+ def tearDown(self):
+ self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", inputs="A,B,C,D", quiet=True)
+ cls.runModule("t.unregister", maps="singletmap", quiet=True)
+ cls.del_temp_region()
+ def test_1(self):
+ """Simple arithmetik test"""
+ expr = "R = if(C == 9, A - 1)"
+ self.assertModule("t.rast.algebra", expression=expr, flags="g", basename="r")
+ D = tgis.open_old_stds("R", type="strds")
+ self.assertEqual(D.metadata.get_number_of_maps(), 6)
+ self.assertEqual(D.metadata.get_min_min(), 0) # 1 - 1
+ self.assertEqual(D.metadata.get_max_max(), 5) # 6 - 1
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual(end, datetime.datetime(2001, 7, 1))
+ self.assertEqual( D.check_temporal_topology(), True)
+ self.assertEqual(D.get_granularity(), u'1 month')
+ def test_2(self):
+ expr = "R = if(D == 11, A - 1, A + 1)"
+ self.assertEqual(D.metadata.get_number_of_maps(), 15)
+ self.assertEqual(D.metadata.get_min_min(), 2) # 1 - 1
+ self.assertEqual(D.metadata.get_max_max(), 6) # 5 + 1
+ self.assertEqual(end, datetime.datetime(2001, 5, 6))
+ self.assertEqual(D.get_granularity(), u'1 day')
+ def test_simple_arith_hash_1(self):
+ """Simple arithmetic test including the hash operator"""
+ expr ='R = A + A # A'
+ self.assertEqual(D.metadata.get_max_max(), 7)
+ def test_simple_arith_td_1(self):
+ """Simple arithmetic test"""
+ expr = 'R = A + td(A:D)'
+ def test_simple_arith_if_1(self):
+ """Simple arithmetic test with if condition"""
+ expr = 'R = if(start_date(A) >= "2001-02-01", A + A)'
+ self.assertEqual(D.metadata.get_number_of_maps(), 5)
+ self.assertEqual(D.metadata.get_min_min(), 4)
+ self.assertEqual(D.metadata.get_max_max(), 12)
+ self.assertEqual(start, datetime.datetime(2001, 2, 1))
+ def test_simple_arith_if_2(self):
+ expr = 'R = if(A#A == 1, A - A)'
+ self.assertEqual(D.metadata.get_max_max(), 0)
+ def test_complex_arith_if_1(self):
+ """Complex arithmetic test with if condition"""
+ expr = 'R = if(start_date(A) < "2001-03-01" && A#A == 1, A+C, A-C)'
+ self.assertEqual(D.metadata.get_min_min(), -6) # 3 - 9
+ self.assertEqual(D.metadata.get_max_max(), 11) # 2 + 2
+ def test_temporal_neighbors(self):
+ """Simple temporal neighborhood computation test"""
+ expr ='R = (A[0,0,-1] : D) + (A[0,0,1] : D)'
+ self.assertEqual(D.metadata.get_number_of_maps(), 14)
+ self.assertEqual(D.metadata.get_min_min(), 2) # 1 + 1
+ self.assertEqual(D.metadata.get_max_max(), 10) # 5 + 5
+ self.assertEqual(start, datetime.datetime(2001, 1, 2))
+ def test_map(self):
+ """Test STDS + single map without timestamp"""
+ expr = "R = A + map(singletmap)"
+ self.assertEqual(D.metadata.get_min_min(), 100) # 1 + 99
+ self.assertEqual(D.metadata.get_max_max(), 105) # 6 + 99
+ def test_tmap_map(self):
+ """Test STDS + single map with and without timestamp"""
+ expr = "R = tmap(singletmap) + A + map(singletmap)"
+ self.assertEqual(D.metadata.get_number_of_maps(),1)
+ self.assertEqual(D.metadata.get_min_min(), 201)
+ self.assertEqual(D.metadata.get_max_max(), 201)
+ self.assertEqual(start, datetime.datetime(2001, 3, 1))
+ self.assertEqual(end, datetime.datetime(2001, 4, 1))
+if __name__ == '__main__':
+ gunittest.test()
