[GRASS-SVN] r62648 - grass/trunk/raster/r.param.scale
svn_grass at osgeo.org
Thu Nov 6 18:53:39 PST 2014
Author: annakrat
Date: 2014-11-06 18:53:39 -0800 (Thu, 06 Nov 2014)
New Revision: 62648
grass/trunk/raster/r.param.scale/find_normal.c
grass/trunk/raster/r.param.scale/process.c
r.param.scale: propagate NULL values instead of ignoring them - #2466
Modified: grass/trunk/raster/r.param.scale/find_normal.c
--- grass/trunk/raster/r.param.scale/find_normal.c 2014-11-06 23:00:49 UTC (rev 62647)
+++ grass/trunk/raster/r.param.scale/find_normal.c 2014-11-07 02:53:39 UTC (rev 62648)
@@ -16,7 +16,7 @@
/* on computation */
- float x, y, /* Local coordinates of window. */
+ double x, y, /* Local coordinates of window. */
x1 = 0, y1 = 0, /* coefficients of X-products. */
x2 = 0, y2 = 0,
x3 = 0, y3 = 0,
@@ -110,7 +110,7 @@
edge = EDGE, /* EDGE = (wsize-1)/2. */
offset; /* Array offset for weights & z */
- float x, y; /* Local window coordinates. */
+ double x, y; /* Local window coordinates. */
for (row = 0; row < 6; row++) /* Initialise column vector. */
obs[row] = 0.0;
Modified: grass/trunk/raster/r.param.scale/process.c
--- grass/trunk/raster/r.param.scale/process.c 2014-11-06 23:00:49 UTC (rev 62647)
+++ grass/trunk/raster/r.param.scale/process.c 2014-11-07 02:53:39 UTC (rev 62648)
@@ -36,7 +36,8 @@
/* raster row, each element is of type */
/* DCELL */
*window_ptr, /* Stores local terrain window. */
- centre; /* Elevation of central cell in window. */
+ centre, /* Elevation of central cell in window. */
+ *window_cell; /* Stores last read cell in window. */
CELL *featrow_out = NULL; /* store features in CELL */
@@ -55,8 +56,8 @@
temp; /* Unused */
double *weight_ptr; /* Weighting matrix for observed values. */
+ int found_null; /* If null was found among window cells */
/* GET RASTER AND WINDOW DETAILS */
@@ -86,10 +87,14 @@
row_in = (DCELL *) G_malloc(ncols * sizeof(DCELL) * wsize);
/* Reserve `wsize' rows of memory. */
- if (mparam != FEATURE)
+ if (mparam != FEATURE) {
row_out = Rast_allocate_buf(DCELL_TYPE); /* Initialise output row buffer. */
- else
+ Rast_set_d_null_value(row_out, ncols);
+ else {
featrow_out = Rast_allocate_buf(CELL_TYPE); /* Initialise output row buffer. */
+ Rast_set_c_null_value(featrow_out, ncols);
window_ptr = (DCELL *) G_malloc(SQR(wsize) * sizeof(DCELL));
/* Reserve enough memory for local wind. */
@@ -167,16 +172,41 @@
for (col = EDGE; col < (ncols - EDGE); col++) {
/* Find central z value */
centre = *(row_in + EDGE * ncols + col);
+ /* Test for no data and propagate */
+ if (Rast_is_d_null_value(¢re)) {
+ if (mparam == FEATURE)
+ Rast_set_c_null_value(featrow_out + col, 1);
+ else {
+ Rast_set_d_null_value(row_out + col, 1);
+ continue;
+ found_null = FALSE;
+ for (wind_row = 0; wind_row < wsize; wind_row++) {
+ if (found_null)
+ break;
+ for (wind_col = 0; wind_col < wsize; wind_col++) {
- for (wind_row = 0; wind_row < wsize; wind_row++)
- for (wind_col = 0; wind_col < wsize; wind_col++)
/* Express all window values relative */
/* to the central elevation. */
+ window_cell = row_in + (wind_row * ncols) + col + wind_col - EDGE;
+ if (Rast_is_d_null_value(window_cell)) {
+ else {
+ found_null = TRUE;
+ break;
*(window_ptr + (wind_row * wsize) + wind_col) =
- *(row_in + (wind_row * ncols) + col + wind_col -
- EDGE) - centre;
+ *(window_cell) - centre;
+ if (found_null)
+ continue;
/*--- Use LU back substitution to solve normal equations. ---*/
find_obs(window_ptr, obs_ptr, weight_ptr);
@@ -225,6 +255,10 @@
*(row_in + ((wind_row + 1) * ncols) + col);
+ else
for (wind_row = 0; wind_row < EDGE; wind_row++) {
Rast_put_row(fd_out, row_out, DCELL_TYPE); /* Write out the edge cells as NULL. */
