[GRASS-SVN] r62711 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Tue Nov 11 15:36:14 PST 2014
Author: huhabla
Date: 2014-11-11 15:36:14 -0800 (Tue, 11 Nov 2014)
New Revision: 62711
grass/trunk/lib/python/pygrass/modules/interface/module.py
pygrass: More tests and fixed function for the ParallelModuleQueue
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-11-11 20:55:57 UTC (rev 62710)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-11-11 23:36:14 UTC (rev 62711)
@@ -67,29 +67,57 @@
number of parallel processes it will wait for all processes to finish,
sets the stdout and stderr of the Module object and removes it
from the queue when its finished.
+ To finish the queue before the maximum number of parallel
+ processes was reached call wait() .
This class will raise a GrassError in case a Module process exits
with a return code other than 0.
Usage:
+ Check with a queue size of 3 and 5 processes
>>> import copy
>>> from grass.pygrass.modules import Module, ParallelModuleQueue
>>> mapcalc_list = []
+ Setting run_ to False is important, otherwise a parallel processing is not possible
>>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
>>> queue = ParallelModuleQueue(nprocs=3)
>>> for i in xrange(5):
... new_mapcalc = copy.deepcopy(mapcalc)
... mapcalc_list.append(new_mapcalc)
- ... new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
- ... queue.put(new_mapcalc)
- Module('r.mapcalc')
+ ... m = new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
+ ... queue.put(m)
+ >>> queue.wait()
+ >>> queue.get_num_run_procs()
+ 0
+ >>> queue.get_max_num_procs()
+ 3
+ >>> for mapcalc in mapcalc_list:
+ ... print(mapcalc.popen.returncode)
+ 0
+ 0
+ 0
+ 0
+ 0
+ Check with a queue size of 8 and 5 processes
+ >>> queue = ParallelModuleQueue(nprocs=8)
+ >>> mapcalc_list = []
+ >>> for i in xrange(5):
+ ... new_mapcalc = copy.deepcopy(mapcalc)
+ ... mapcalc_list.append(new_mapcalc)
+ ... queue.put(m)
>>> queue.wait()
+ 0
+ 8
0
@@ -98,6 +126,86 @@
0
0
+ Check with a queue size of 8 and 4 processes
+ >>> new_mapcalc = copy.deepcopy(mapcalc)
+ >>> mapcalc_list.append(new_mapcalc)
+ >>> m = new_mapcalc(expression="test_pygrass_1 =1")
+ >>> queue.put(m)
+ 1
+ >>> m = new_mapcalc(expression="test_pygrass_2 =2")
+ >>> queue.put(m)
+ 2
+ >>> m = new_mapcalc(expression="test_pygrass_3 =3")
+ >>> queue.put(m)
+ 3
+ >>> m = new_mapcalc(expression="test_pygrass_4 =4")
+ >>> queue.put(m)
+ 4
+ >>> queue.wait()
+ 0
+ 8
+ 0
+ 0
+ 0
+ 0
+ Check with a queue size of 3 and 4 processes
+ >>> queue = ParallelModuleQueue(nprocs=3)
+ >>> queue.put(m)
+ 1
+ >>> queue.put(m)
+ 2
+ >>> queue.put(m) # Now it will wait until all procs finish and set the counter back to 0
+ 0
+ >>> m = new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
+ >>> queue.put(m)
+ 1
+ >>> queue.wait()
+ 0
+ 3
+ 0
+ 0
+ 0
+ 0
def __init__(self, nprocs=1):
"""Constructor
@@ -147,13 +255,14 @@
"""Get the number of Module processes that are in the queue running
or finished
- :returns: the maximum number fo Module processes running/finished in
- the queue
+ :returns: the number fo Module processes running/finished in the queue
- return len(self._list)
+ return self._proc_count
def get_max_num_procs(self):
"""Return the maximum number of parallel Module processes
+ :returns: the maximum number of parallel Module processes
return self._num_procs
