[GRASS-SVN] r62712 - grass/trunk/temporal/t.rast.aggregate/testsuite
svn_grass at osgeo.org
Tue Nov 11 16:19:19 PST 2014
Author: huhabla
Date: 2014-11-11 16:19:19 -0800 (Tue, 11 Nov 2014)
New Revision: 62712
Added:
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
temporal modules: New tests for parallel processing of t.rast.aggregate
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2014-11-11 23:36:14 UTC (rev 62711)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2014-11-12 00:19:19 UTC (rev 62712)
@@ -13,7 +13,7 @@
from grass.gunittest.case import TestCase
from grass.gunittest.gmodules import SimpleModule
-class TestUnregister(TestCase):
+class TestAggregationAbsolute(TestCase):
@classmethod
def setUpClass(cls):
Added: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py (rev 0)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py 2014-11-12 00:19:19 UTC (rev 62712)
@@ -0,0 +1,165 @@
+"""Test t.rast.aggregation
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+from datetime import datetime
+class TestAggregationAbsoluteParallel(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ os.putenv("GRASS_OVERWRITE", "1")
+ tgis.init()
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0,
+ t=50, res=10, res3=10)
+ name_list = []
+ for i in range(540):
+ cls.runModule("r.mapcalc", expression="a%i = %i"%(i + 1, i + 1), overwrite=True)
+ name_list.append("a%i"%(i + 1))
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test",
+ description="A test", overwrite=True)
+ cls.runModule("t.register", flags="i", type="rast", input="A",
+ maps=name_list,
+ start="2001-01-01",
+ increment="4 hours",
+ overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+ def tearDown(self):
+ """Remove generated data"""
+ self.runModule("t.remove", flags="rf", type="strds", inputs="B")
+ def test_aggregation_12hours(self):
+ """Aggregation one month"""
+ self.assertModule("t.rast.aggregate", input="A", output="B",
+ basename="b", granularity="12 hours",
+ method="sum", sampling=["contains"],
+ nprocs=9, flags="s")
+ tinfo_string="""start_time=2001-01-01 00:00:00
+ end_time=2001-04-01 00:00:00
+ granularity=12 hours
+ map_time=interval
+ aggregation_type=sum
+ number_of_maps=180
+ min_min=6.0
+ min_max=1617.0
+ max_min=6.0
+ max_max=1617.0"""
+ info = SimpleModule("t.info", flags="g", input="B")
+ #info.run()
+ #print info.outputs.stdout
+ self.assertModuleKeyValue(module=info, reference=tinfo_string,
+ precision=2, sep="=")
+ def test_aggregation_1day_4procs(self):
+ start = datetime.now()
+ basename="b", granularity="1 day",
+ nprocs=4, flags="s")
+ end = datetime.now()
+ delta = end - start
+ print "test_aggregation_1day_4procs:", delta.total_seconds()
+ granularity=1 day
+ map_time=interval
+ number_of_maps=90"""
+ #info.run()
+ def test_aggregation_1day_3procs(self):
+ nprocs=3, flags="s")
+ print "test_aggregation_1day_3procs:", delta.total_seconds()
+ granularity=1 day
+ map_time=interval
+ number_of_maps=90
+ min_min=21.0
+ min_max=3225.0
+ max_min=21.0
+ max_max=3225.0"""
+ #info.run()
+ def test_aggregation_1day_2procs(self):
+ nprocs=2, flags="s")
+ print "test_aggregation_1day_2procs:", delta.total_seconds()
+ granularity=1 day
+ map_time=interval
+ number_of_maps=90
+ min_min=21.0
+ min_max=3225.0
+ max_min=21.0
+ max_max=3225.0"""
+ #info.run()
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py 2014-11-11 23:36:14 UTC (rev 62711)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py 2014-11-12 00:19:19 UTC (rev 62712)
@@ -13,7 +13,7 @@
+class TestAggregationRelative(TestCase):
@classmethod
