[GRASS-SVN] r62743 - grass/trunk/general/g.gisenv
svn_grass at osgeo.org
Fri Nov 14 09:18:29 PST 2014
Author: martinl
Date: 2014-11-14 09:18:29 -0800 (Fri, 14 Nov 2014)
New Revision: 62743
grass/trunk/general/g.gisenv/g.gisenv.html
g.gisenv: document store=mapset
Modified: grass/trunk/general/g.gisenv/g.gisenv.html
--- grass/trunk/general/g.gisenv/g.gisenv.html 2014-11-14 16:48:30 UTC (rev 62742)
+++ grass/trunk/general/g.gisenv/g.gisenv.html 2014-11-14 17:18:29 UTC (rev 62743)
@@ -124,9 +124,15 @@
This works only for <em>Bash</em>. The format of the output is not
compatible with other UNIX shells.
+<p>
+By default the GRASS variables are stored in <em>gisrc</em> file
+(defined by environmental
+variable <tt>GISRC</tt>). If <b>store=mapset</b> is given than the
+variables are stored in <tt>$GISDBASE/$LOCATION_NAME/$MAPSET/VAR</tt>.
<h3>GRASS Debugging</h3>
-To print debugging messages, the variable DEBUG must be set to level
+To print debugging messages, the variable <tt>DEBUG</tt> must be set to level
equal or greater than 0:
<div class="code"><pre>
@@ -151,7 +157,7 @@
and modules.
<p>
-Similarly WX_DEBUG controls debugging messages
+Similarly <tt>WX_DEBUG</tt> controls debugging messages
from <a href="wxGUI.html">wxGUI</a>.
<h2>SEE ALSO</h2>
