[GRASS-SVN] r62744 - in grass/branches/releasebranch_7_0: . general/g.gisenv
svn_grass at osgeo.org
Fri Nov 14 09:19:55 PST 2014
Author: martinl
Date: 2014-11-14 09:19:55 -0800 (Fri, 14 Nov 2014)
New Revision: 62744
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/general/g.gisenv/g.gisenv.html
g.gisenv: document store=mapset
(merge r62743 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62723,62730,62739,62741
+ /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62723,62730,62739,62741,62743
Modified: grass/branches/releasebranch_7_0/general/g.gisenv/g.gisenv.html
--- grass/branches/releasebranch_7_0/general/g.gisenv/g.gisenv.html 2014-11-14 17:18:29 UTC (rev 62743)
+++ grass/branches/releasebranch_7_0/general/g.gisenv/g.gisenv.html 2014-11-14 17:19:55 UTC (rev 62744)
@@ -124,9 +124,15 @@
This works only for <em>Bash</em>. The format of the output is not
compatible with other UNIX shells.
+<p>
+By default the GRASS variables are stored in <em>gisrc</em> file
+(defined by environmental
+variable <tt>GISRC</tt>). If <b>store=mapset</b> is given than the
+variables are stored in <tt>$GISDBASE/$LOCATION_NAME/$MAPSET/VAR</tt>.
<h3>GRASS Debugging</h3>
-To print debugging messages, the variable DEBUG must be set to level
+To print debugging messages, the variable <tt>DEBUG</tt> must be set to level
equal or greater than 0:
<div class="code"><pre>
@@ -151,7 +157,7 @@
and modules.
<p>
-Similarly WX_DEBUG controls debugging messages
+Similarly <tt>WX_DEBUG</tt> controls debugging messages
from <a href="wxGUI.html">wxGUI</a>.
<h2>SEE ALSO</h2>
