[GRASS-SVN] r62745 - grass/trunk/vector/v.neighbors
svn_grass at osgeo.org
Fri Nov 14 10:08:15 PST 2014
Author: neteler
Date: 2014-11-14 10:08:15 -0800 (Fri, 14 Nov 2014)
New Revision: 62745
grass/trunk/vector/v.neighbors/main.c
grass/trunk/vector/v.neighbors/v.neighbors.html
v.neighbors: more reasonable warnings
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c 2014-11-14 17:19:55 UTC (rev 62744)
+++ grass/trunk/vector/v.neighbors/main.c 2014-11-14 18:08:15 UTC (rev 62745)
@@ -8,7 +8,7 @@
* PURPOSE: Category manipulations
- * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2014 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -36,7 +36,7 @@
struct Option *in_opt, *out_opt, *field_opt;
struct Option *method_opt, *size_opt;
struct Map_info In;
- double radius, raster_res;
+ double radius, grid_res;
struct boxlist *List;
struct Cell_head region;
struct bound_box box;
@@ -91,6 +91,10 @@
G_get_set_window(®ion);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
+ grid_res = (region.ew_res + region.ns_res)/2.;
+ if ( atof(size_opt->answer) < grid_res)
+ G_warning(_("Neighborhood diameter smaller than cell resolution: %.1f < %.1f "),
+ radius * 2., grid_res);
result = Rast_allocate_buf(CELL_TYPE);
Points = Vect_new_line_struct();
@@ -157,9 +161,8 @@
Rast_close(out_fd);
if (count_sum < 1) {
- raster_res = (region.ew_res + region.ns_res)/2.;
- G_warning(_("No points found (using raster resolution: %.1f, moving window size: %.1f)"),
- raster_res, (box.E - box.W) * raster_res );
+ G_warning(_("No points found (using cell resolution: %.1f, neighborhood diameter: %.1f)"),
+ grid_res, radius * 2.);
G_message(_("You can calculate the distance statistics between the vector point using:\nv.univar -d %s"), in_opt->answer);
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.neighbors/v.neighbors.html
--- grass/trunk/vector/v.neighbors/v.neighbors.html 2014-11-14 17:19:55 UTC (rev 62744)
+++ grass/trunk/vector/v.neighbors/v.neighbors.html 2014-11-14 18:08:15 UTC (rev 62745)
@@ -10,7 +10,7 @@
dataset):
<div class="code"><pre>
-g.region vect=schools_wake res=10 -p
+g.region vect=schools_wake res=100 -p -a
v.neighbors input=schools_wake output=schools_wake_3000m method=count size=3000
d.mon wx0
