[GRASS-SVN] r62746 - grass/trunk/vector/v.neighbors
svn_grass at osgeo.org
Sat Nov 15 12:24:15 PST 2014
Author: mmetz
Date: 2014-11-15 12:24:15 -0800 (Sat, 15 Nov 2014)
New Revision: 62746
grass/trunk/vector/v.neighbors/main.c
v.neighbors: add messages
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c 2014-11-14 18:08:15 UTC (rev 62745)
+++ grass/trunk/vector/v.neighbors/main.c 2014-11-15 20:24:15 UTC (rev 62746)
@@ -19,6 +19,7 @@
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
@@ -36,7 +37,7 @@
struct Option *in_opt, *out_opt, *field_opt;
struct Option *method_opt, *size_opt;
struct Map_info In;
- double radius, grid_res;
+ double radius, dia;
struct boxlist *List;
struct Cell_head region;
struct bound_box box;
@@ -89,12 +90,23 @@
field = Vect_get_field_number(&In, field_opt->answer);
G_get_set_window(®ion);
+ Vect_get_map_box(&In, &box);
+ if (box.N > region.north + radius || box.S < region.south - radius ||
+ box.E > region.east + radius || box.W < region.west - radius) {
+ Vect_close(&In);
+ G_fatal_error(_("Input vector and computational region do not overlap"));
+ exit(EXIT_FAILURE);
+ dia = sqrt(region.ns_res * region.ns_res + region.ew_res * region.ew_res);
+ if (radius * 2.0 < dia) {
+ G_warning(_("The search diameter %g is smaller than cell diagonal %g: some points could not be detected"),
+ radius * 2, dia);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- grid_res = (region.ew_res + region.ns_res)/2.;
- if ( atof(size_opt->answer) < grid_res)
- G_warning(_("Neighborhood diameter smaller than cell resolution: %.1f < %.1f "),
- radius * 2., grid_res);
result = Rast_allocate_buf(CELL_TYPE);
Points = Vect_new_line_struct();
@@ -160,12 +172,8 @@
Vect_close(&In);
Rast_close(out_fd);
- if (count_sum < 1) {
- G_warning(_("No points found (using cell resolution: %.1f, neighborhood diameter: %.1f)"),
- grid_res, radius * 2.);
- G_message(_("You can calculate the distance statistics between the vector point using:\nv.univar -d %s"), in_opt->answer);
- exit(EXIT_FAILURE);
+ if (count_sum < 1)
+ G_warning(_("No points found"));
exit(EXIT_SUCCESS);
