[GRASS-SVN] r62750 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Sat Nov 15 15:14:09 PST 2014
Author: martinl
Date: 2014-11-15 15:14:09 -0800 (Sat, 15 Nov 2014)
New Revision: 62750
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: add r|v.pack a r|v.unpack to layer manager's contextual menu
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-11-15 20:44:27 UTC (rev 62749)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-11-15 23:14:09 UTC (rev 62750)
@@ -1131,10 +1131,12 @@
self._popupMenu((('rastImport', self.OnImportGdalLayers),
('rastLink', self.OnLinkGdalLayers),
+ ('rastUnpack', self.OnUnpackRaster),
('rastOut', self.OnRasterOutputFormat),
(None, None),
('vectImport', self.OnImportOgrLayers),
('vectLink', self.OnLinkOgrLayers),
+ ('vectUnpack', self.OnUnpackVector),
('vectOut', self.OnVectorOutputFormat)))
def OnWorkspaceNew(self, event = None):
@@ -1648,7 +1650,15 @@
dlg = GdalOutputDialog(parent = self, ogr = True)
dlg.CentreOnScreen()
dlg.Show()
+ def OnUnpackRaster(self, event):
+ """Unpack raster map handler"""
+ self.OnMenuCmd(cmd = ['r.unpack'])
+ def OnUnpackVector(self, event):
+ """Unpack vector map handler"""
+ self.OnMenuCmd(cmd = ['v.unpack'])
def OnImportDxfFile(self, event, cmd = None):
"""Convert multiple DXF layers to GRASS vector map layers"""
dlg = DxfImportDialog(parent = self, giface = self._giface)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2014-11-15 20:44:27 UTC (rev 62749)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2014-11-15 23:14:09 UTC (rev 62750)
@@ -6,7 +6,7 @@
Classes:
- layertree::LayerTree
-(C) 2007-2013 by the GRASS Development Team
+(C) 2007-2014 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -56,12 +56,16 @@
label = _('Import raster data')),
'rastLink' : MetaIcon(img = 'layer-import',
label = _('Link external raster data')),
+ 'rastUnpack' : MetaIcon(img = 'layer-import',
+ label = _('Unpack raster map')),
'rastOut' : MetaIcon(img = 'layer-export',
label = _('Set raster output format')),
'vectImport' : MetaIcon(img = 'layer-import',
label = _('Import vector data')),
'vectLink' : MetaIcon(img = 'layer-import',
label = _('Link external vector data')),
+ 'vectUnpack' : MetaIcon(img = 'layer-import',
+ label = _('Unpack vector map')),
'vectOut' : MetaIcon(img = 'layer-export',
label = _('Set vector output format')),
'wmsImport' : MetaIcon(img = 'layer-wms-add',
@@ -384,7 +388,7 @@
'region', 'export', 'attr', 'edit', 'save_ws',
'bgmap', 'topo', 'meta', 'null', 'zoom1', 'region1',
'color', 'hist', 'univar', 'prof', 'properties', 'sql', 'copy',
- 'report', 'export-pg'):
+ 'report', 'export-pg', 'pack'):
self.popupID[key] = wx.NewId()
# get current mapset
@@ -467,6 +471,12 @@
id = self.popupID['export-pg'])
if 'v.out.postgis' not in globalvar.grassCmd:
self.popupMenu.Enable(self.popupID['export-pg'], False)
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['pack'], text = _("Create pack"))
+ self.popupMenu.AppendItem(item)
+ self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.pack',
+ 'input=%s' % mapLayer.GetName()]),
+ id = self.popupID['pack'])
lmapset = self.GetLayerInfo(self.layer_selected, key = 'maplayer').GetMapset()
if lmapset != currentMapset:
@@ -562,6 +572,12 @@
id = self.popupID['export'])
+ self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.pack',
self.popupMenu.Append(self.popupID['copy'], text = _("Make a copy in the current mapset"))
