[GRASS-SVN] r62751 - in grass/trunk/imagery: i.cluster i.maxlik
svn_grass at osgeo.org
Sat Nov 15 15:58:18 PST 2014
Author: wenzeslaus
Date: 2014-11-15 15:58:18 -0800 (Sat, 15 Nov 2014)
New Revision: 62751
Added:
grass/trunk/imagery/i.maxlik/i_maxlik_classes.png
grass/trunk/imagery/i.cluster/i.cluster.html
grass/trunk/imagery/i.maxlik/i.maxlik.html
i.maxlik: add example image, add rejection handling suggestion, change map names (do the same for i.cluster example)
Modified: grass/trunk/imagery/i.cluster/i.cluster.html
--- grass/trunk/imagery/i.cluster/i.cluster.html 2014-11-15 23:14:09 UTC (rev 62750)
+++ grass/trunk/imagery/i.cluster/i.cluster.html 2014-11-15 23:58:18 UTC (rev 62751)
@@ -222,19 +222,24 @@
g.region rast=lsat7_2002_10 -p
# store VIZ, NIR, MIR into group/subgroup
-i.group group=my_lsat7_2002 subgroup=my_lsat7_2002 \
+i.group group=lsat7_2002 subgroup=lsat7_2002 \
input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
i.cluster group=my_lsat7_2002 subgroup=my_lsat7_2002 \
- signaturefile=sig_clust_lsat2002 \
+ signaturefile=sig_cluster_lsat2002 \
classes=10 report=rep_clust_lsat2002.txt
</pre></div>
To complete the unsupervised classification, <em>i.maxlik</em> is subsequently used.
+See example in its manual page.
<h2>SEE ALSO</h2>
-The GRASS GIS 4 <em>
+<a href="http://grasswiki.osgeo.org/wiki/Image_processing">Image processing</a>
+and
+<a href="http://grasswiki.osgeo.org/wiki/Image_classification">Image classification</a>
+wiki pages and for historical reference also
+the GRASS GIS 4<em>
<a href="http://grass.osgeo.org/gdp/imagery/grass4_image_processing.pdf">Image
Processing manual</a></em>
Modified: grass/trunk/imagery/i.maxlik/i.maxlik.html
--- grass/trunk/imagery/i.maxlik/i.maxlik.html 2014-11-15 23:14:09 UTC (rev 62750)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html 2014-11-15 23:58:18 UTC (rev 62751)
@@ -83,19 +83,41 @@
(see <em><a href="i.cluster.html">i.cluster</a></em> manual page for the first part):
<div class="code"><pre>
-i.maxlik group=my_lsat7_2002 subgroup=my_lsat7_2002 \
- class=lsat7_2002_clust_classes reject=lsat7_2002_clust_classes.rej
+i.maxlik group=lsat7_2002 subgroup=lsat7_2002 \
+ output=lsat7_2002_cluster_classes reject=lsat7_2002_cluster_reject
-# Visually check result
+# visually check result
d.mon wx0
-d.rast.leg lsat7_2002_clust_classes
-d.rast.leg lsat7_2002_clust_classes.rej
+d.rast.leg lsat7_2002_cluster_classes
+d.rast.leg lsat7_2002_cluster_reject
+# see how many pixels were rejected at given levels
+r.report lsat7_2002_cluster_reject units=k,p
+# optionally, filter out pixels with high level of rejection
+# here we select 90% which is category 12
+r.mapcalc "lsat7_2002_cluster_classes_filtered = if(lsat7_2002_cluster_reject < 12, lsat7_2002_cluster_classes, null())"
</pre></div>
+saved using d.mon wx0; d.rast lsat7_2002_cluster_classes; and save
+<p>
+<center>
+<img src="i_maxlik_classes.png"><br>
+Resulting raster with classified pixels
+</center>
<h2>SEE ALSO</h2>
+and
Added: grass/trunk/imagery/i.maxlik/i_maxlik_classes.png
(Binary files differ)
Property changes on: grass/trunk/imagery/i.maxlik/i_maxlik_classes.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
