[GRASS-SVN] r62753 - in grass/branches/releasebranch_7_0: . gui/wxpython/lmgr gui/wxpython/nviz
svn_grass at osgeo.org
Sat Nov 15 16:06:54 PST 2014
Author: annakrat
Date: 2014-11-15 16:06:54 -0800 (Sat, 15 Nov 2014)
New Revision: 62753
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/lmgr/layertree.py
grass/branches/releasebranch_7_0/gui/wxpython/nviz/mapwindow.py
wxGUI/layertree: fix weird behavior when there is a lot of layers caused by wrong CustomTreeCtrl API usage, fixed also #2257 and partially groups drag and drop problem
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62723,62730,62739,62741,62743,62746
+ /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62723,62730,62739,62741,62743,62746,62752
Modified: grass/branches/releasebranch_7_0/gui/wxpython/lmgr/layertree.py
--- grass/branches/releasebranch_7_0/gui/wxpython/lmgr/layertree.py 2014-11-16 00:05:50 UTC (rev 62752)
+++ grass/branches/releasebranch_7_0/gui/wxpython/lmgr/layertree.py 2014-11-16 00:06:54 UTC (rev 62753)
@@ -264,6 +264,23 @@
return None
+ def GetNextItem(self, item):
+ """!Returns next item from tree (flattened expanded tree)"""
+ # this is a not empty group
+ if self.GetChildrenCount(item):
+ return self.GetFirstChild(item)[0]
+ # this is a layer outside group
+ if self.GetItemParent(item) == self.root:
+ return self.GetNextSibling(item)
+ # this is a layer inside group
+ sibling = self.GetNextSibling(item)
+ if sibling:
+ return sibling
+ # skip one up the hierarchy
+ return self.GetNextSibling(self.GetItemParent(item))
def SetItemIcon(self, item, iconName=None):
if not iconName:
iconName = self.GetLayerInfo(item, key = 'maplayer').GetType()
@@ -1008,13 +1025,13 @@
if lname and not multiple:
# check for duplicates
- item = self.GetFirstVisibleItem()
+ item = self.GetFirstChild(self.root)[0]
while item and item.IsOk():
if self.GetLayerInfo(item, key = 'type') == 'vector':
name = self.GetLayerInfo(item, key = 'maplayer').GetName()
if name == lname:
return
- item = self.GetNextVisible(item)
+ item = self.GetNextItem(item)
selectedLayer = self.GetSelectedLayer()
# deselect active item
@@ -1134,7 +1151,7 @@
if self.GetLayerInfo(prevItem, key = 'maplayer'):
prevMapLayer = self.GetLayerInfo(prevItem, key = 'maplayer')
- prevItem = self.GetNextSibling(prevItem)
+ prevItem = self.GetNextItem(prevItem)
if prevMapLayer:
pos = self.Map.GetLayerIndex(prevMapLayer)
@@ -1232,15 +1249,17 @@
self.lmgr.WorkspaceChanged()
layer = event.GetItem()
- self.PropertiesDialog(layer)
- if self.GetLayerInfo(layer, key = 'type') == 'group':
+ if self.GetLayerInfo(layer, key='type') == 'group':
if self.IsExpanded(layer):
self.Collapse(layer)
else:
self.Expand(layer)
+ return
+ self.PropertiesDialog(layer)
def OnDeleteLayer(self, event):
"""Remove selected layer item from the layer tree"""
@@ -1364,11 +1383,11 @@
ctrl = event.GetEventObject().GetId()
# find layer tree item by ctrl
- layer = self.GetFirstVisibleItem()
+ layer = self.GetFirstChild(self.root)[0]
while layer and layer.IsOk():
if self.GetLayerInfo(layer, key = 'ctrl') == ctrl:
break
- layer = self.GetNextVisible(layer)
+ layer = self.GetNextItem(layer)
# change parameters for item in layers list in render.Map
self.ChangeLayer(layer)
@@ -1492,8 +1511,7 @@
if child:
while child:
self.RecreateItem(child, dropTarget, parent = newItem)
- self.Delete(child)
- child = self.GetNextChild(old, cookie)[0]
+ child, cookie = self.GetNextChild(old, cookie)
# delete layer at original position
try:
@@ -1682,7 +1700,7 @@
# make a list of visible layers
layers = []
- vislayer = self.GetFirstVisibleItem()
+ vislayer = self.GetFirstChild(self.root)[0]
if not vislayer or self.GetPyData(vislayer) is None:
return layers
@@ -1692,19 +1710,16 @@
digitToolbar = self.mapdisplay.GetToolbar('vdigit')
if digitToolbar:
vdigitLayer = digitToolbar.GetLayer()
itemList = ""
- for item in range(self.GetCount()):
+ while vislayer:
itemList += self.GetItemText(vislayer) + ','
lType = self.GetLayerInfo(vislayer, key='type')
mapLayer = self.GetLayerInfo(vislayer, key='maplayer')
if lType and lType != 'group' and mapLayer is not vdigitLayer:
layers.append(mapLayer)
- if not self.GetNextVisible(vislayer):
- break
- else:
- vislayer = self.GetNextVisible(vislayer)
+ vislayer = self.GetNextItem(vislayer)
Debug.msg(5, "LayerTree.GetVisibleLayers(): items=%s" %
(reversed(itemList)))
@@ -1782,7 +1797,7 @@
if i == index:
return item
i += 1
return None
@@ -1822,7 +1837,7 @@
except KeyError:
return None
- if value == itemLayer.GetName():
+ if itemLayer and value == itemLayer.GetName():
items.append(item)
if self.GetLayerInfo(item, key = 'type') == 'group':
subItem = self.GetFirstChild(item)[0]
Modified: grass/branches/releasebranch_7_0/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_7_0/gui/wxpython/nviz/mapwindow.py 2014-11-16 00:05:50 UTC (rev 62752)
+++ grass/branches/releasebranch_7_0/gui/wxpython/nviz/mapwindow.py 2014-11-16 00:06:54 UTC (rev 62753)
@@ -1297,18 +1297,17 @@
type = self.tree.GetLayerInfo(item, key = 'type')
if type == 'group':
- subItem = self.tree.GetFirstChild(item)[0]
- self._GetDataLayers(subItem, litems)
- item = self.tree.GetNextSibling(item)
+ item = self.tree.GetNextItem(item)
+ continue
if not item.IsChecked() or \
type not in ('raster', 'vector', '3d-raster'):
continue
litems.append(item)
def LoadDataLayers(self):
"""Load raster/vector from current layer tree
