[GRASS-SVN] r62754 - in grass/trunk: display/d.thematic.area vector/v.class
Sat Nov 15 19:08:22 PST 2014
Author: wenzeslaus
Date: 2014-11-15 19:08:22 -0800 (Sat, 15 Nov 2014)
New Revision: 62754
   grass/trunk/display/d.thematic.area/d.thematic.area.html
   grass/trunk/vector/v.class/v.class.html
d.thematic.area: option is key is column not data
Modified: grass/trunk/display/d.thematic.area/d.thematic.area.html
--- grass/trunk/display/d.thematic.area/d.thematic.area.html	2014-11-16 00:06:54 UTC (rev 62753)
+++ grass/trunk/display/d.thematic.area/d.thematic.area.html	2014-11-16 03:08:22 UTC (rev 62754)
@@ -25,7 +25,7 @@
 <h2>EXAMPLE</h2>
 <div class="code"><pre>
-d.thematic.area -l map=communes3 data=pop \
+d.thematic.area -l map=communes3 column=pop \
   breaks=111393.250000,222785.500000,334177.750000 \
   colors=255:0:0,0:255:0,0:0:255,0,0,0
 </pre></div>
@@ -35,7 +35,7 @@
 breaks for 5 classes:
-d.thematic.area -l map=communes2 data=pop/area algorithm=std \
+d.thematic.area -l map=communes2 column=pop/area algorithm=std \
   nbclasses=5 colors=0:0:255,50:100:255,255:100:50,255:0:0,156:0:0
 </pre></div>
Modified: grass/trunk/vector/v.class/v.class.html
--- grass/trunk/vector/v.class/v.class.html	2014-11-16 00:06:54 UTC (rev 62753)
+++ grass/trunk/vector/v.class/v.class.html	2014-11-16 03:08:22 UTC (rev 62754)
@@ -73,7 +73,7 @@
 The following example uses the output of d.class and feeds it directly
 into <em>d.thematic.area</em>:
-d.thematic.area -l map=communes2 data=pop/area \
+d.thematic.area -l map=communes2 column=pop/area \
     breaks=`v.class -g map=communes2 column=pop/area algo=std nbcla=5` \
 </pre></div>
