[GRASS-SVN] r62810 - in grass/trunk/raster/r.in.poly: . testsuite
svn_grass at osgeo.org
Tue Nov 18 20:17:15 PST 2014
Author: annakrat
Date: 2014-11-18 20:17:15 -0800 (Tue, 18 Nov 2014)
New Revision: 62810
Added:
grass/trunk/raster/r.in.poly/testsuite/
grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py
r.in.poly: added testsuite (showing unresolved bug with labels)
Added: grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py
--- grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py (rev 0)
+++ grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py 2014-11-19 04:17:15 UTC (rev 62810)
@@ -0,0 +1,111 @@
+import os
+import tempfile
+import grass.gunittest
+from grass.script.core import read_command
+input1 = \
+A
+634308.630394 223320.356473
+640640.712946 223092.401501
+641248.592871 217748.123827
+= 10.01 label1
+A
+639576.923077 222256.566604
+639045.028143 216329.737336
+637702.626642 224662.757974
+= -8
+L
+633523.452158 222231.238274
+642565.666041 221218.105066
+641957.786116 222585.834897
+= 3 label2
+class TestRInPoly(grass.gunittest.TestCase):
+ rinpoly = 'test_rinpoly'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', rast='elevation')
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ def setUp(self):
+ self.tmpFile = tempfile.NamedTemporaryFile(delete=False)
+ def tearDown(self):
+ """Remove rinpoly map after each test method"""
+ self.runModule('g.remove', flags='f', type='rast',
+ name=self.rinpoly)
+ os.unlink(self.tmpFile.name)
+ def testTypeCell(self):
+ """Test type of resulting map"""
+ self.tmpFile.write(input1)
+ self.tmpFile.close()
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='CELL')
+ minmax = 'min=-8\nmax=10\ndatatype=CELL'
+ self.assertRasterFitsInfo(raster=self.rinpoly, reference=minmax)
+ def testTypeFCell(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='FCELL')
+ minmax = 'min=-8\nmax=10.01\ndatatype=FCELL'
+ self.assertRasterFitsInfo(raster=self.rinpoly, reference=minmax, precision=1e-8)
+ def testTypeDCell(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='DCELL')
+ minmax = 'min=-8\nmax=10.01\ndatatype=DCELL'
+ def testTypeCellNull(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='CELL',
+ null=-8)
+ minmax = 'min=3\nmax=10\ndatatype=CELL'
+ def testTypeDCellNull(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='DCELL',
+ null=-8)
+ minmax = 'min=3\nmax=10.01\ndatatype=DCELL'
+ def testTypeDCellNull2(self):
+ null=0)
+ def testLabels(self):
+ category = read_command('r.category', map=self.rinpoly, vals=[-8, 3, 10.01]).strip()
+ self.assertEqual(first="-8\t\n3\tlabel2\n10.01\tlabel1", second=category,
+ msg="Labels do not match")
+if __name__ == '__main__':
+ grass.gunittest.test()
Property changes on: grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
