[GRASS-SVN] r62811 - grass/trunk/gui/wxpython/rdigit
    svn_grass at osgeo.org
    Tue Nov 18 21:05:07 PST 2014
Author: annakrat
Date: 2014-11-18 21:05:07 -0800 (Tue, 18 Nov 2014)
New Revision: 62811
   grass/trunk/gui/wxpython/rdigit/controller.py
   grass/trunk/gui/wxpython/rdigit/toolbars.py
wxGUI/rdigit: reflect recent changes in r.in.poly, small bugfixes including fixing drawing order, setting color table
Modified: grass/trunk/gui/wxpython/rdigit/controller.py
--- grass/trunk/gui/wxpython/rdigit/controller.py	2014-11-19 04:17:15 UTC (rev 62810)
+++ grass/trunk/gui/wxpython/rdigit/controller.py	2014-11-19 05:05:07 UTC (rev 62811)
@@ -55,6 +55,10 @@
         self._backgroundRaster = None
         # name of temporary raster used to backup original state
         self._backupRasterName = None
+        # if we edit an old raster or a new one (important for setting color table)
+        self._editOldRaster = False
+        # type of output raster map (CELL, FCELL, DCELL)
+        self._mapType = None
         # GraphicsSet for drawing areas, lines, points
         self._areas = None
         self._lines = None
@@ -335,6 +339,8 @@
             GError(parent=self._mapWindow, message=_("Failed to create backup copy of edited raster map."))
             return False
         self._editedRaster = name
+        self._mapType = grast.raster_info(map=name)['datatype']
+        self._editOldRaster = True
         return True
     def SelectNewMap(self):
@@ -374,7 +380,7 @@
                 gcore.run_command('r.colors', map=name, raster=self._backgroundRaster, quiet=True)
                 if mapType == 'CELL':
                     values = gcore.read_command('r.describe', flags='1n',
-                                                map=backgroundMap, quiet=True).strip()
+                                                map=name, quiet=True).strip()
                     if values:
                         self.uploadMapCategories.emit(values=values.split('\n'))
         except CalledModuleError:
@@ -383,6 +389,7 @@
         name = name + '@' + gcore.gisenv()['MAPSET']
+        self._mapType = mapType
         self.newRasterCreated.emit(name=name)
     def _backupRaster(self, name):
@@ -426,16 +433,17 @@
                 (lastCellValue != item.GetPropertyVal('cellValue') or
                 lastWidthValue != item.GetPropertyVal('widthValue')):
                 if text:
-                    out = self._rasterize(text, lastWidthValue, tempRaster)
+                    out = self._rasterize(text, lastWidthValue, self._mapType, tempRaster)
                     rastersToPatch.append(out)
                     text = []
                 self._writeItem(item, text)
                 out = self._rasterize(text, item.GetPropertyVal('widthValue'),
-                                      tempRaster)
+                                      self._mapType, tempRaster)
                 text = []
             else:
             lastCellValue = item.GetPropertyVal('cellValue')
             lastWidthValue = item.GetPropertyVal('widthValue')
@@ -444,14 +452,17 @@
             wx.PostEvent(self, evt)
         if text:
-                                  tempRaster)
-        gcore.run_command('r.patch', input=sorted(rastersToPatch, reverse=True) + [self._backupRasterName],
+        gcore.run_command('r.patch', input=rastersToPatch[::-1] + [self._backupRasterName],
                           output=self._editedRaster, overwrite=True, quiet=True)
         gcore.run_command('g.remove', type='rast', flags='f', name=rastersToPatch + [tempRaster],
                           quiet=True)
         try:
+            # setting the right color table
+            if self._editOldRaster:
+                return
             if not self._backgroundRaster:
                 table = UserSettings.Get(group='rasterLayer', key='colorTable', subkey='selection')
                 gcore.run_command('r.colors', color=table, map=self._editedRaster, quiet=True)
@@ -484,12 +495,13 @@
         elif item in self._points.GetAllItems():
             self._writeFeature(item, vtype='P', text=text)
-    def _rasterize(self, text, bufferDist, tempRaster):
+    def _rasterize(self, text, bufferDist, mapType, tempRaster):
         """Performs the actual rasterization using r.in.poly
         and buffering with r.grow if required.
         :param str text: string in r.in.poly format
         :param float bufferDist: buffer distance in map units
+        :param str mapType: CELL, FCELL, DCELL
         :param str tempRaster: name of temporary raster used in computation
         :return: output raster map name as a result of digitization
@@ -498,13 +510,15 @@
         asciiFile = tempfile.NamedTemporaryFile(delete=False)
         asciiFile.write('\n'.join(text))
         asciiFile.close()
         if bufferDist:
+            bufferDist /= 2.
             gcore.run_command('r.in.poly', input=asciiFile.name, output=tempRaster,
-                              overwrite=True, quiet=True)
+                              type_=mapType, overwrite=True, quiet=True)
             gcore.run_command('r.grow', input=tempRaster, output=output,
                               flags='m', radius=bufferDist, quiet=True)
         else:
             gcore.run_command('r.in.poly', input=asciiFile.name, output=output,
-                              quiet=True)
+                              type_=mapType, quiet=True)
         os.unlink(asciiFile.name)
         return output
Modified: grass/trunk/gui/wxpython/rdigit/toolbars.py
--- grass/trunk/gui/wxpython/rdigit/toolbars.py	2014-11-19 04:17:15 UTC (rev 62810)
+++ grass/trunk/gui/wxpython/rdigit/toolbars.py	2014-11-19 05:05:07 UTC (rev 62811)
@@ -79,7 +79,8 @@
                                        size=(80, -1), validator=FloatValidator())
         self._widthValue.Bind(wx.EVT_TEXT, lambda evt: self._widthValueChanged())
-        self._widthValue.SetToolTipString(_("Width of currently digitized line/point in map units."))
+        self._widthValue.SetToolTipString(
+            _("Width of currently digitized line or diameter of a digitized point in map units."))
         self.InsertControl(8, wx.StaticText(self, label=" %s" % _("Width:")))
         self.InsertControl(9, self._widthValue)
@@ -111,7 +112,6 @@
                                       lambda event: self._controller.Stop())))
     def CheckSelectedTool(self, id):
-        print self.toolSwitcher.IsToolInGroup(tool=id, group='mouseUse')
         if self.toolSwitcher.IsToolInGroup(tool=id, group='mouseUse') \
                 and id not in (self.area, self.line, self.point):
             self._controller.SelectType(None)
