[GRASS-SVN] r62924 - grass/trunk/scripts/r.tileset
Tue Nov 25 02:46:52 PST 2014
Author: lucadelu
Date: 2014-11-25 02:46:52 -0800 (Tue, 25 Nov 2014)
New Revision: 62924
   grass/trunk/scripts/r.tileset/r.tileset.py
r.tileset: catch m.proj error if the proj string is wrong
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py	2014-11-25 10:30:11 UTC (rev 62923)
+++ grass/trunk/scripts/r.tileset/r.tileset.py	2014-11-25 10:46:52 UTC (rev 62924)
@@ -113,6 +113,7 @@
 from grass.script.utils import separator
 from grass.script import core as grass
+from grass.exceptions import CalledModuleError
 def bboxToPoints(bbox):
@@ -156,13 +157,16 @@
     """Projects point (x, y) using projector"""
     errors = 0
     points = []
-    ret = grass.read_command('m.proj',
-                             quiet=True,
-                             flags='d',
-                             proj_in=source['proj'],
-                             proj_out=dest['proj'],
-                             sep=';',
-                             input=file)
+    try:
+        ret = grass.read_command('m.proj',
+                                 quiet=True,
+                                 flags='d',
+                                 proj_in=source['proj'],
+                                 proj_out=dest['proj'],
+                                 sep=';',
+                                 input=file)
+    except CalledModuleError:
+        grass.fatal(cs2cs + ' failed')
     if not ret:
