[GRASS-SVN] r63082 - in grass/branches/releasebranch_7_0: . display/d.rast.num raster/r.out.ascii raster/r.out.vtk
Wed Nov 26 07:47:26 PST 2014
Author: martinl
Date: 2014-11-26 07:47:26 -0800 (Wed, 26 Nov 2014)
New Revision: 63082
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/display/d.rast.num/main.c
   grass/branches/releasebranch_7_0/raster/r.out.ascii/main.c
   grass/branches/releasebranch_7_0/raster/r.out.vtk/parameters.c
dp -> precision (#2049) - standardized options
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081
Modified: grass/branches/releasebranch_7_0/display/d.rast.num/main.c
--- grass/branches/releasebranch_7_0/display/d.rast.num/main.c	2014-11-26 15:45:06 UTC (rev 63081)
+++ grass/branches/releasebranch_7_0/display/d.rast.num/main.c	2014-11-26 15:47:26 UTC (rev 63082)
@@ -97,7 +97,7 @@
     opt.grid_color->guisection = _("Colors");
     opt.prec = G_define_option();
-    opt.prec->key = "dp";
+    opt.prec->key = "precision";
     opt.prec->type = TYPE_INTEGER;
     opt.prec->required = NO;
     opt.prec->answer = "1";
Modified: grass/branches/releasebranch_7_0/raster/r.out.ascii/main.c
--- grass/branches/releasebranch_7_0/raster/r.out.ascii/main.c	2014-11-26 15:45:06 UTC (rev 63081)
+++ grass/branches/releasebranch_7_0/raster/r.out.ascii/main.c	2014-11-26 15:47:26 UTC (rev 63082)
@@ -72,7 +72,7 @@
 	_("Name for output ASCII grid map (use out=- for stdout)");
     parm.dp = G_define_option();
-    parm.dp->key = "dp";
+    parm.dp->key = "precision";
     parm.dp->type = TYPE_INTEGER;
     parm.dp->required = NO;
     parm.dp->description =
Modified: grass/branches/releasebranch_7_0/raster/r.out.vtk/parameters.c
--- grass/branches/releasebranch_7_0/raster/r.out.vtk/parameters.c	2014-11-26 15:45:06 UTC (rev 63081)
+++ grass/branches/releasebranch_7_0/raster/r.out.vtk/parameters.c	2014-11-26 15:47:26 UTC (rev 63082)
@@ -79,7 +79,7 @@
 	_("Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]");
     param.elevscale = G_define_option();
-    param.elevscale->key = "elevscale";
+    param.elevscale->key = "zmultiplier";
     param.elevscale->type = TYPE_DOUBLE;
     param.elevscale->required = NO;
     param.elevscale->description = _("Scale factor for elevation");
@@ -87,7 +87,7 @@
     param.elevscale->answer = "1.0";
     param.decimals = G_define_option();
-    param.decimals->key = "dp";
+    param.decimals->key = "precision";
     param.decimals->type = TYPE_INTEGER;
     param.decimals->required = NO;
     param.decimals->multiple = NO;
