[GRASS-SVN] r63083 - grass/trunk/raster3d/r3.out.vtk
svn_grass at osgeo.org
Wed Nov 26 07:51:45 PST 2014
Author: martinl
Date: 2014-11-26 07:51:45 -0800 (Wed, 26 Nov 2014)
New Revision: 63083
grass/trunk/raster3d/r3.out.vtk/parameters.c
r3.out.vtk: use standardized options (#2409)
Modified: grass/trunk/raster3d/r3.out.vtk/parameters.c
--- grass/trunk/raster3d/r3.out.vtk/parameters.c 2014-11-26 15:47:26 UTC (rev 63082)
+++ grass/trunk/raster3d/r3.out.vtk/parameters.c 2014-11-26 15:51:45 UTC (rev 63083)
@@ -71,28 +71,24 @@
_("Create 3D elevation output with a top and a bottom surface, both raster maps are required.");
- param.rgbmaps = G_define_option();
+ param.rgbmaps = G_define_standard_option(G_OPT_R3_INPUT);
param.rgbmaps->key = "rgbmaps";
- param.rgbmaps->type = TYPE_STRING;
param.rgbmaps->required = NO;
- param.rgbmaps->gisprompt = "old,grid3,3d-raster";
param.rgbmaps->multiple = YES;
param.rgbmaps->guisection = "Advanced options";
param.rgbmaps->description =
_("Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]");
- param.vectormaps = G_define_option();
+ param.vectormaps = G_define_standard_option(G_OPT_V_OUTPUT);
param.vectormaps->key = "vectormaps";
- param.vectormaps->type = TYPE_STRING;
param.vectormaps->required = NO;
- param.vectormaps->gisprompt = "old,grid3,3d-raster";
param.vectormaps->multiple = YES;
param.vectormaps->guisection = "Advanced options";
param.vectormaps->description =
_("Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]");
param.elevscale = G_define_option();
- param.elevscale->key = "elevscale";
+ param.elevscale->key = "zmultiplier";
param.elevscale->type = TYPE_DOUBLE;
param.elevscale->required = NO;
param.elevscale->description = _("Scale factor for elevation");
@@ -100,7 +96,7 @@
param.elevscale->answer = "1.0";
param.decimals = G_define_option();
- param.decimals->key = "dp";
+ param.decimals->key = "precision";
param.decimals->type = TYPE_INTEGER;
param.decimals->required = NO;
param.decimals->multiple = NO;
