[GRASS-SVN] r63091 - grass/trunk/temporal/t.vect.export
svn_grass at osgeo.org
Wed Nov 26 08:02:41 PST 2014
Author: martinl
Date: 2014-11-26 08:02:41 -0800 (Wed, 26 Nov 2014)
New Revision: 63091
grass/trunk/temporal/t.vect.export/t.vect.export.py
t.vect.export: use standardized options (#2409)
Modified: grass/trunk/temporal/t.vect.export/t.vect.export.py
--- grass/trunk/temporal/t.vect.export/t.vect.export.py 2014-11-26 16:01:07 UTC (rev 63090)
+++ grass/trunk/temporal/t.vect.export/t.vect.export.py 2014-11-26 16:02:41 UTC (rev 63091)
@@ -28,7 +28,7 @@
#%end
#%option G_OPT_M_DIR
-#% key: workdir
+#% key: directory
#% description: Path to the work directory, default is /tmp
#% required: no
#% answer: /tmp
