[GRASS-SVN] r63092 - in grass/branches/releasebranch_7_0/temporal: . t.vect.export
svn_grass at osgeo.org
Wed Nov 26 08:03:11 PST 2014
Author: martinl
Date: 2014-11-26 08:03:10 -0800 (Wed, 26 Nov 2014)
New Revision: 63092
grass/branches/releasebranch_7_0/temporal/
grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py
t.vect.export: use standardized options (#2409) - (merge r63091 from trunk)
Property changes on: grass/branches/releasebranch_7_0/temporal
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:62868,62873
/grass/trunk/temporal:59684,59915-59916,60017-60018,60024,60026,60173-60174,60213,60547-60548,60732-60733,60817,61031,61066,61071-61072,61083,61096,61141,61157-61158,61179-61180,61186,61191-61194,61215,61239-61243,61274-61275,61282-61288,61301,61429-61433,61455,61457,61732,61734,61759-61762,61806-61807,61848,61885,61955-61957,61983-61985,61997-62000,62016,62021-62022,62025,62111-62113,62120-62121,62179-62180,62182,62343,62361,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62594-62597,62603,62606,62608-62609,62613-62614,62616,62618,62625-62628,62631-62632,62635-62638,62640-62642,62644,62646-62649,62652,62654-62657,62666,62691,62703-62705,62709-62712,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62775,62785,62798,62800-62801,62803,62805,62812,62814-62815,62822,62824,62831,62838,62847,62856,62868,62871,62873,62875,63035,63085,63087,63089
+ /grass/trunk:62868,62873
/grass/trunk/temporal:59684,59915-59916,60017-60018,60024,60026,60173-60174,60213,60547-60548,60732-60733,60817,61031,61066,61071-61072,61083,61096,61141,61157-61158,61179-61180,61186,61191-61194,61215,61239-61243,61274-61275,61282-61288,61301,61429-61433,61455,61457,61732,61734,61759-61762,61806-61807,61848,61885,61955-61957,61983-61985,61997-62000,62016,62021-62022,62025,62111-62113,62120-62121,62179-62180,62182,62343,62361,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62594-62597,62603,62606,62608-62609,62613-62614,62616,62618,62625-62628,62631-62632,62635-62638,62640-62642,62644,62646-62649,62652,62654-62657,62666,62691,62703-62705,62709-62712,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62775,62785,62798,62800-62801,62803,62805,62812,62814-62815,62822,62824,62831,62838,62847,62856,62868,62871,62873,62875,63035,63085,63087,63089,63
091
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py
--- grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py 2014-11-26 16:02:41 UTC (rev 63091)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py 2014-11-26 16:03:10 UTC (rev 63092)
@@ -28,7 +28,7 @@
#%end
#%option G_OPT_M_DIR
-#% key: workdir
+#% key: directory
#% description: Path to the work directory, default is /tmp
#% required: no
#% answer: /tmp
