[GRASS-SVN] r63143 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Wed Nov 26 09:02:44 PST 2014
Author: martinl
Date: 2014-11-26 09:02:44 -0800 (Wed, 26 Nov 2014)
New Revision: 63143
grass/trunk/vector/v.to.db/parse.c
v.to.db: use standardized options (#2409)
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c 2014-11-26 17:01:34 UTC (rev 63142)
+++ grass/trunk/vector/v.to.db/parse.c 2014-11-26 17:02:44 UTC (rev 63143)
@@ -82,9 +82,9 @@
_("line/boundary starting point coordinates, X,Y or X,Y,Z"),
_("line/boundary end point coordinates, X,Y or X,Y,Z"),
_("categories of areas on the left and right side of the boundary, "
- "'qlayer' is used for area category"),
+ "'query_layer' is used for area category"),
_("result of a database query for all records of the geometry"
- "(or geometries) from table specified by 'qlayer' option"),
+ "(or geometries) from table specified by 'query_layer' option"),
_("slope steepness of vector line or boundary"),
_("line sinuousity, calculated as line length / distance between end points"),
_("line azimuth, calculated as angle between North direction and endnode direction at startnode"));
@@ -99,13 +99,13 @@
"miles,feet,meters,kilometers,acres,hectares,radians,degrees";
parms.qfield = G_define_standard_option(G_OPT_V_FIELD);
- parms.qfield->key = "qlayer";
+ parms.qfield->key = "query_layer";
parms.qfield->label = _("Query layer number or name (read from)");
parms.qfield->guisection = _("Query");
parms.qfield->required = NO;
parms.qcol = G_define_standard_option(G_OPT_DB_COLUMN);
- parms.qcol->key = "qcolumn";
+ parms.qcol->key = "query_column";
parms.qcol->label = _("Name of attribute column used for 'query' option");
parms.qcol->description = _("E.g. 'cat', 'count(*)', 'sum(val)'");
parms.qcol->required = NO;
