[GRASS-SVN] r63144 - in grass/branches/releasebranch_7_0: . vector/v.to.db
Wed Nov 26 09:03:41 PST 2014
Author: martinl
Date: 2014-11-26 09:03:41 -0800 (Wed, 26 Nov 2014)
New Revision: 63144
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/vector/v.to.db/parse.c
v.to.db: use standardized options (#2409) - (merge r63143 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/parse.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/parse.c	2014-11-26 17:02:44 UTC (rev 63143)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/parse.c	2014-11-26 17:03:41 UTC (rev 63144)
@@ -82,9 +82,9 @@
 	       _("line/boundary starting point coordinates, X,Y or X,Y,Z"),
 	       _("line/boundary end point coordinates, X,Y or X,Y,Z"),
 	       _("categories of areas on the left and right side of the boundary, "
-		 "'qlayer' is used for area category"),
+		 "'query_layer' is used for area category"),
 	       _("result of a database query for all records of the geometry"
-		 "(or geometries) from table specified by 'qlayer' option"),
+		 "(or geometries) from table specified by 'query_layer' option"),
 	       _("slope steepness of vector line or boundary"),
 	       _("line sinuousity, calculated as line length / distance between end points"),
 	       _("line azimuth, calculated as angle between North direction and endnode direction at startnode"));
@@ -99,13 +99,13 @@
 	"miles,feet,meters,kilometers,acres,hectares,radians,degrees";
     parms.qfield = G_define_standard_option(G_OPT_V_FIELD);
-    parms.qfield->key = "qlayer";
+    parms.qfield->key = "query_layer";
     parms.qfield->label = _("Query layer number or name (read from)");
     parms.qfield->guisection = _("Query");
     parms.qfield->required = NO;
     parms.qcol = G_define_standard_option(G_OPT_DB_COLUMN);
-    parms.qcol->key = "qcolumn";
+    parms.qcol->key = "query_column";
     parms.qcol->label = _("Name of attribute column used for 'query' option");
     parms.qcol->description = _("E.g. 'cat', 'count(*)', 'sum(val)'");
     parms.qcol->required = NO;
