[GRASS-SVN] r63194 - grass/trunk/scripts/i.tasscap
svn_grass at osgeo.org
Thu Nov 27 06:24:18 PST 2014
Author: neteler
Date: 2014-11-27 06:24:18 -0800 (Thu, 27 Nov 2014)
New Revision: 63194
grass/trunk/scripts/i.tasscap/i.tasscap.py
i.tasscap: added support for Landsat8
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-11-27 14:18:29 UTC (rev 63193)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-11-27 14:24:18 UTC (rev 63194)
@@ -30,6 +30,10 @@
# Compare discussion:
# http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
+# Landsat8: Baig, M.H.A., Zhang, L., Shuai, T., Tong, Q., 2014. Derivation of a tasselled cap transformation
+# based on Landsat 8 at-satellite reflectance. Remote Sensing Letters 5, 423-431.
+# doi:10.1080/2150704X.2014.915434
# MODIS Tasselled Cap coefficients
# https://gis.stackexchange.com/questions/116107/tasseled-cap-transformation-on-modis-in-grass/116110
# Ref: Lobser & Cohen (2007). MODIS tasselled cap: land cover characteristics
@@ -49,10 +53,10 @@
#% keywords: Tasseled Cap transformation
#%end
#%option G_OPT_R_INPUTS
+#% description: For Landsat4-7: bands 1, 2, 3, 4, 5, and 7; for Landsat8: bands 2, 3, 4, 5, 6, and 7
#%end
#%option G_OPT_R_BASENAME_OUTPUT
#% label: Name for output basename raster map(s)
-#% description: For Landsat 4-7, the raster maps should be the bands 1, 2, 3, 4, 5, and 7.
#%end
#%option
#% key: sensor
@@ -60,15 +64,13 @@
#% description: Satellite sensor
#% required: yes
#% multiple: no
-#% options: landsat4_tm,landsat5_tm,landsat7_etm,modis
-#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;modis;Use transformation rules for MODIS
+#% options: landsat4_tm,landsat5_tm,landsat7_etm,landsat8,modis
+#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8;Use transformation rules for Landsat 8;modis;Use transformation rules for MODIS
#%end
-import sys
-import os
import grass.script as grass
-# weights for 6 Landsat bands: TM4, TM5, TM7
+# weights for 6 Landsat bands: TM4, TM5, TM7, OLI
# MODIS: Red, NIR1, Blue, Green, NIR2, SWIR1, SWIR2
parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
(-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
@@ -81,6 +83,10 @@
(-0.3344,-0.3544,-0.4556, 0.6966,-0.0242,-0.2630),
( 0.2626, 0.2141, 0.0926, 0.0656,-0.7629,-0.5388),
( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)],
+ [( 0.3029, 0.2786, 0.4733, 0.5599, 0.5080, 0.1872), # Landsat TM8
+ (-0.2941,-0.2430,-0.5424, 0.7276, 0.0713,-0.1608),
+ ( 0.1511, 0.1973, 0.3283, 0.3407,-0.7117,-0.4559),
+ (-0.8239, 0.0849, 0.4396, -0.058, 0.2013,-0.2773)],
[( 0.4395, 0.5945, 0.2460, 0.3918, 0.3506, 0.2136, 0.2678), # MODIS
(-0.4064, 0.5129,-0.2744,-0.2893, 0.4882,-0.0036,-0.4169),
( 0.1147, 0.2489, 0.2408, 0.3132,-0.3122,-0.6416,-0.5087)]]
@@ -108,8 +114,8 @@
def main():
options, flags = grass.parser()
- satellite = options['satellite']
- output_basename = options['basename']
+ satellite = options['sensor']
+ output_basename = options['output']
inputs = options['input'].split(',')
num_of_bands = 6
if len(inputs) != num_of_bands:
@@ -131,6 +137,8 @@
calcN(output_basename, bands, 1, 5)
elif satellite == 'landsat7_etm':
calcN(output_basename, bands, 2, 7)
+ elif satellite == 'landsat8':
+ calcN(output_basename, bands, 2, 7)
elif satellite == 'modis':
calcN(output_basename, bands, 3, 7)
else:
