[GRASS-SVN] r63195 - grass/branches/releasebranch_7_0/scripts/i.tasscap
svn_grass at osgeo.org
Thu Nov 27 06:28:14 PST 2014
Author: neteler
Date: 2014-11-27 06:28:14 -0800 (Thu, 27 Nov 2014)
New Revision: 63195
grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py
i.tasscap: fix updated parameters; minor msg updates
Modified: grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py
--- grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py 2014-11-27 14:24:18 UTC (rev 63194)
+++ grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py 2014-11-27 14:28:14 UTC (rev 63195)
@@ -6,7 +6,7 @@
# AUTHOR(S): Markus Neteler. neteler itc.it
# Converted to Python by Glynn Clements
# PURPOSE: At-satellite reflectance based tasseled cap transformation.
-# COPYRIGHT: (C) 1997-2004,2008 by the GRASS Development Team
+# COPYRIGHT: (C) 1997-2004,2008, 2014 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -42,10 +42,10 @@
#% keywords: Tasseled Cap transformation
#%end
#%option G_OPT_R_INPUTS
+#% description: For Landsat 4-7: bands 1, 2, 3, 4, 5, and 7
#%end
#%option G_OPT_R_BASENAME_OUTPUT
#% label: Name for output basename raster map(s)
-#% description: For Landsat 4-7, the raster maps should be the bands 1, 2, 3, 4, 5, and 7.
#%end
#%option
#% key: sensor
@@ -61,14 +61,15 @@
import os
import grass.script as grass
-parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863),
+# weights for 6 Landsat bands: TM4, TM5, TM7
+parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
(-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
( 0.1509, 0.1973, 0.3279, 0.3406,-0.7112,-0.4572)],
- [( 0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695),
+ [( 0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695), # Landsat TM5
(-0.2728,-0.2174,-0.5508, 0.7221, 0.0733,-0.1648, -0.7310),
( 0.1446, 0.1761, 0.3322, 0.3396,-0.6210,-0.4186, -3.3828),
( 0.8461,-0.0731,-0.4640,-0.0032,-0.0492,-0.0119, 0.7879)],
- [( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596),
+ [( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596), # Landsat TM7
(-0.3344,-0.3544,-0.4556, 0.6966,-0.0242,-0.2630),
( 0.2626, 0.2141, 0.0926, 0.0656,-0.7629,-0.5388),
( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)]]
@@ -82,7 +83,7 @@
grass.run_command('r.colors', map = out, color = 'grey')
def calcN(outpre, bands, i, n):
- grass.message(_("LANDSAT-%d...") % n)
+ grass.message(_("Satellite band-%d...") % n)
for j, p in enumerate(parms[i]):
out = "%s.%d" % (outpre, j + 1)
ord = ordinals[j]
@@ -96,12 +97,12 @@
def main():
options, flags = grass.parser()
- satellite = options['satellite']
- output_basename = options['basename']
+ satellite = options['sensor']
+ output_basename = options['output']
inputs = options['input'].split(',')
num_of_bands = 6
if len(inputs) != num_of_bands:
- grass.fatal(_("The number of input raster maps (bands) should be %s.") % num_of_bands)
+ grass.fatal(_("The number of input raster maps (bands) should be %s") % num_of_bands)
# this is here just for the compatibility with r.mapcalc expression
# remove this if not really needed in new implementation
@@ -122,7 +123,7 @@
else:
raise RuntimeError("Invalid satellite: " + satellite)
- grass.message(_("Tasseled Cap components calculated."))
+ grass.message(_("Tasseled Cap components calculated"))
if __name__ == "__main__":
main()
