[GRASS-SVN] r63232 - in grass/branches/releasebranch_7_0: db/db.columns db/db.connect db/db.copy db/db.createdb db/db.databases db/db.describe db/db.drivers db/db.dropdb db/db.execute db/db.login db/db.select db/db.tables display/d.geodesic display/d.grid display/d.path lib/cairodriver scripts/db.univar
Fri Nov 28 01:58:18 PST 2014
Author: neteler
Date: 2014-11-28 01:58:18 -0800 (Fri, 28 Nov 2014)
New Revision: 63232
   grass/branches/releasebranch_7_0/db/db.columns/db.columns.html
   grass/branches/releasebranch_7_0/db/db.connect/db.connect.html
   grass/branches/releasebranch_7_0/db/db.copy/db.copy.html
   grass/branches/releasebranch_7_0/db/db.createdb/db.createdb.html
   grass/branches/releasebranch_7_0/db/db.databases/db.databases.html
   grass/branches/releasebranch_7_0/db/db.describe/db.describe.html
   grass/branches/releasebranch_7_0/db/db.drivers/db.drivers.html
   grass/branches/releasebranch_7_0/db/db.dropdb/db.dropdb.html
   grass/branches/releasebranch_7_0/db/db.execute/db.execute.html
   grass/branches/releasebranch_7_0/db/db.login/db.login.html
   grass/branches/releasebranch_7_0/db/db.select/db.select.html
   grass/branches/releasebranch_7_0/db/db.tables/db.tables.html
   grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html
   grass/branches/releasebranch_7_0/display/d.grid/d.grid.html
   grass/branches/releasebranch_7_0/display/d.path/d.path.html
   grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
   grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html
manual: some examples updated; HTML cosmetics
Modified: grass/branches/releasebranch_7_0/db/db.columns/db.columns.html
--- grass/branches/releasebranch_7_0/db/db.columns/db.columns.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.columns/db.columns.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -5,33 +5,38 @@
 <h2>NOTE</h2>
-If parameters for database connection are already set with
-<a href="db.connect.html">db.connect</a>, they are taken as default values and
-do not need to be spcified each time.
+If parameters for database connection are already set with
+<a href="db.connect.html">db.connect</a>, they are taken as default values
+and do not need to be spcified each time.
 <h2>EXAMPLES</h2>
-<em>List columns of a PostgreSQL attribute table</em><br>
+<h3>List columns of a PostgreSQL attribute table</h3>
 <div class="code"><pre>
-db.columns table=markveggy driver=pg database=grass60test
+db.columns table=zipcodes_wake driver=pg database=grassdb
 </pre></div>
 <p>
-<em>If the database parameters are already set, the columns can be listed directly</em><br>
+<em>If the database parameters are already set, the columns can be listed
+directly</em><br>
 </pre></div>
-<p>
-<em>List columns from Shape file with DBF attribute table</em><br>
+<h3>List columns from Shape file with DBF attribute table</h3>
-db.columns table=network driver=dbf database=/daten/grassdata/fire/PERMANENT/dbf/
+db.columns table=zipcodes_wake driver=dbf database=/grassdata/nc_spm_08/PERMANENT/dbf/
 </pre></div>
-<p>
-<em>List columns of table in SQLite database (note that this is the default setting)</em><br>
+<h3>List columns of table in SQLite database</h3>
+Note that the SQLite backend is the default setting.
-db.columns driver=sqlite table=myarchsites database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+db.columns driver=sqlite table=archsites database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
 </pre></div>
 <h2>SEE ALSO</h2>
@@ -45,6 +50,8 @@
 <a href="db.tables.html">db.tables</a>,
 <a href="sql.html">GRASS SQL interface</a>
 </em>
+<p>
+<a href="sql.html">GRASS SQL interface</a>
 <h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/db/db.connect/db.connect.html
--- grass/branches/releasebranch_7_0/db/db.connect/db.connect.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.connect/db.connect.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -4,7 +4,7 @@
 These parameters are then taken as default values by modules so that the
 user does not need to enter the parameters each time.
 <p>
-The default database backend in GRASS 7 is SQLite.
+The default database backend in GRASS GIS 7 is SQLite.
 <h2>NOTES</h2>
@@ -71,7 +71,7 @@
 </pre></div>
-<h3>MySQL (local)</h3>
+<h3>MySQL (local connection)</h3>
 Local storage (<em><a href=db.login.html>db.login</a></em> may not be needed):
 <br>
@@ -95,7 +95,7 @@
 db.tables -p
 </pre></div>
-<h3>DBF (not recommended)</h3>
+<h3>DBF (local, not recommended)</h3>
 Local storage (the dbf/ subdirectory in the mapset must exist or must be
 created by the user):
Modified: grass/branches/releasebranch_7_0/db/db.copy/db.copy.html
--- grass/branches/releasebranch_7_0/db/db.copy/db.copy.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.copy/db.copy.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
 <em>db.copy</em> allows the user to copy a table between two databases.
-Databases can be connected through different drivers (see example).
+Databases can be connected through different drivers (see examples below).
 <h2>NOTES</h2>
@@ -12,7 +12,7 @@
 <h2>EXAMPLES</h2>
-<h3>DBF -> PG</h3>
+<h3>From DBF to PostgreSQL</h3>
 <em>Storing table 'geonames.dbf' (in current directory) into PostgreSQL
 through ODBC:</em><br>
@@ -24,7 +24,7 @@
 </pre></div>
-<h3>PG -> DBF</h3>
+<h3>From PostgreSQL to DBF</h3>
 db.copy from_driver=pg  from_database="host=pgserver.example.org,dbname=testdb" \
@@ -33,7 +33,7 @@
 </pre></div>
-<h3>PG -> PG with condition</h3>
+<h3>From PostgreSQL to PostgreSQL with condition</h3>
 db.copy from_driver=pg  from_database="host=localhost,dbname=testdb" \
@@ -41,8 +41,9 @@
   to_table=selection where="cat < 500"
 </pre></div>
-<h3>DBF -> SQLite</h3>
+<h3>From DBF to SQLite</h3>
 db.copy from_driver=dbf from_database='$GISDBASE/$LOCATION_NAME/PERMANENT/dbf' \
    from_table=geonames_features to_driver=sqlite \
@@ -52,7 +53,9 @@
 sqlitebrowser $HOME/grassdata/nc_spm_08/user1/sqlite/sqlite.db
 </pre></div>
-<h3>SQLite -> DBF</h3>
+<h3>From SQLite to DBF</h3>
 db.copy from_driver=sqlite from_database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db' \
    from_table=ammprv to_driver=dbf to_database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' \
@@ -67,9 +70,10 @@
 <a href="db.drivers.html">db.drivers</a>,
 <a href="db.login.html">db.login</a>,
 <a href="v.db.connect.html">v.db.connect</a>,
-<a href="v.clean.html">v.clean</a>,
+<a href="v.clean.html">v.clean</a>
+</em>
+<p>
-</em>
 <h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/db/db.createdb/db.createdb.html
--- grass/branches/releasebranch_7_0/db/db.createdb/db.createdb.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.createdb/db.createdb.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -23,19 +23,19 @@
 established through <em>odbc</em> driver):
-db.createdb driver=odbc database=grasstest
+db.createdb driver=odbc database=grassdb
 </pre></div>
 Create a new PostgreSQL database (if PostgreSQL connection is established
 through <em>pg</em> driver):
-db.createdb driver=pg database=grasstest
+db.createdb driver=pg database=grassdb
 </pre></div>
 <h2>TODO</h2>
-Support other database drivers too.
+Support other database drivers, too.
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/db/db.databases/db.databases.html
--- grass/branches/releasebranch_7_0/db/db.databases/db.databases.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.databases/db.databases.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -21,12 +21,14 @@
 db.databases driver=sqlite
 </pre></div>
+<p>
 List SQLite databases in the given directory:
 db.databases driver=sqlite location=/opt/sqlite
 </pre></div>
+<p>
 List PostgreSQL databases from database server running on given port:
@@ -35,7 +37,8 @@
 <h2>SEE ALSO</h2>
-<em><a href="db.columns.html">db.columns</a>,
+<em>
+<a href="db.columns.html">db.columns</a>,
 <a href="db.describe.html">db.describe</a>,
 <a href="db.execute.html">db.execute</a>,
Modified: grass/branches/releasebranch_7_0/db/db.describe/db.describe.html
--- grass/branches/releasebranch_7_0/db/db.describe/db.describe.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.describe/db.describe.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -1,7 +1,7 @@
-<em>db.describe</em> displays table information. If parameter <b>-c</b> is used
- only column names instead of full column descriptions is given.
+<em>db.describe</em> displays table information. If parameter <b>-c</b>
+is used only column names instead of full column descriptions is given.
 <h2>NOTE</h2>
@@ -11,9 +11,11 @@
 <h2>EXAMPLES</h2>
-<em>List column descriptions of table in SQLite database (note that this is the default setting)</em><br>
+<em>List column descriptions of table in SQLite database (note that this
+is the default setting)</em><br>
-db.describe driver=sqlite table=myarchsites \
+db.describe driver=sqlite table=hospitals \
 # or simply
@@ -22,21 +24,25 @@
 <h3>DBF example</h3>
-db.describe -c table=roads database='$GISDBASE/$LOCATION_NAME/PERMANENT/dbf/' \
+db.describe -c table=hospitals database='$GISDBASE/$LOCATION_NAME/PERMANENT/dbf/' \
             driver=dbf
-ncols:2
-Column 1:cat:INTEGER:11
-Column 2:label:CHARACTER:43
+ncols: 16
+nrows: 160
+Column 1: cat:INTEGER:11
+Column 2: OBJECTID:INTEGER:11
+Column 3: AREA:DOUBLE PRECISION:20
 </pre></div>
-db.describe table=roads database='$GISDBASE/$LOCATION_NAME/PERMANENT/dbf/' \
+db.describe table=hospitals database='$GISDBASE/$LOCATION_NAME/PERMANENT/dbf/' \
             driver=dbf
-table:roads
+table:hospitals
 description:
 insert:yes
 delete:yes
-ncols:2
+ncols:16
+nrows:160
 column:cat
 description:
@@ -48,6 +54,10 @@
 nullok:yes
 select:yes
 update:yes
+column:OBJECTID
+description:
+type:INTEGER
 </pre></div>
Modified: grass/branches/releasebranch_7_0/db/db.drivers/db.drivers.html
--- grass/branches/releasebranch_7_0/db/db.drivers/db.drivers.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.drivers/db.drivers.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -1,12 +1,17 @@
-<em>db.drivers</em> lists all database drivers.
+<em>db.drivers</em> lists all database drivers (DBMI backends).
 <h2>EXAMPLE</h2>
 Show all installed GRASS database drivers:
 <p><div class="code"><pre>
 db.drivers -p
+pg
+ogr
+sqlite
+dbf
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/db/db.dropdb/db.dropdb.html
--- grass/branches/releasebranch_7_0/db/db.dropdb/db.dropdb.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.dropdb/db.dropdb.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -1,14 +1,13 @@
-<em>db.dropdb</em> removes an existing database using given
-database <b>driver</b>. Currently
-only <a href="grass-sqlite.html">SQLite</a>
+<em>db.dropdb</em> removes an existing database using given database
+<b>driver</b>. Currently only <a href="grass-sqlite.html">SQLite</a>
 and <a href="grass-pg.html">PostgreSQL</a> database drivers are
 supported.
 <h2>EXAMPLES</h2>
-<h3>Drop an existing database connected through SQLite driver</h3>
+<h3>Drop (delete) an existing database connected through SQLite driver</h3>
 db.dropdb driver=sqlite database=/opt/sqlite.db
@@ -17,12 +16,12 @@
 <h3>Drop an existing database connected through PostgreSQL driver</h3>
-db.dropdb driver=pg database=grasstest
+db.dropdb driver=pg database=grassdb
 </pre></div>
 <h2>TODO</h2>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/db/db.execute/db.execute.html
--- grass/branches/releasebranch_7_0/db/db.execute/db.execute.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.execute/db.execute.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -5,11 +5,12 @@
 <h2>NOTES</h2>
 <em>db.execute</em> only executes SQL statements and does not return
-any data. If you need data returned from the database, use <em><a href="db.select.html">db.select</a></em>.
+any data. If you need data returned from the database, use
+<em><a href="db.select.html">db.select</a></em>.
 <p>
-<em><a href="db.connect.html">db.connect</a></em>, they are taken as default values and
-do not need to be specified each time.
+<em><a href="db.connect.html">db.connect</a></em>, they are taken as default
+values and do not need to be specified each time.
 <p>
 If you have a large number of SQL commands to process, it is much much
 faster to place all the SQL statements into a text file and
@@ -29,12 +30,12 @@
 Create a new table using a file with SQL statements
-db.execute driver=odbc database=g60test input=file.sql
+db.execute driver=odbc database=grassdb input=file.sql
 </pre></div>
 Insert new row into attribute table:
-db.execute sql="INSERT INTO nobugs (id,name,east_gb,north_gb) values (30,'Ala',1657340,5072301)"
+db.execute sql="INSERT INTO mysites (id,name,east,north) values (30,'Ala',1657340,5072301)"
 </pre></div>
 Update attribute entries to new value based on SQL rule:
@@ -57,7 +58,8 @@
 db.execute sql="ALTER TABLE roads ADD COLUMN length double"
 </pre></div>
-Column type conversion - update new column from existing column (all drivers except for DBF):
+Column type conversion - update new column from existing column (all
+drivers except for DBF):
 # 'z_value' is varchar and 'z' is double precision:
 echo "UPDATE geodetic_pts SET z = CAST(z_value AS numeric)" | db.execute input=-
@@ -82,17 +84,14 @@
 db.execute input=file.sql
 </pre></div>
-Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):
+Join table 'myroads' to table 'extratab' based on common 'cat' column
+values (not supported by DBF driver):
 db.execute sql="UPDATE extratab SET names=(SELECT label FROM myroads WHERE extratab.cat=myroads.cat)"
 </pre></div>
 <h2>SEE ALSO</h2>
-<em>
-<a href="sql.html">GRASS SQL interface</a>
-<em>
-<p>
 <em>
@@ -102,6 +101,10 @@
 <a href="db.select.html">db.select</a>,
 </em>
+<p>
+<em>
+<em>
 <h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/db/db.login/db.login.html
--- grass/branches/releasebranch_7_0/db/db.login/db.login.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.login/db.login.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -8,7 +8,7 @@
 This is only related to SQL database backends
 like <a href="grass-pg.html">PostgreSQL</a>, <a href="grass-mysql.html">MySQL</a>
 or <a href="grass-odbc.html">ODBC</a>. The passwords are stored in a
-hidden unencrypted file in the user account ('home' directory)
+hidden, unencrypted file in the user account ('home' directory)
 called <em>.grass7/dblogin</em>. Only the file owner can access this
 file.
@@ -37,6 +37,7 @@
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="db.test.html">db.test</a>
Modified: grass/branches/releasebranch_7_0/db/db.select/db.select.html
--- grass/branches/releasebranch_7_0/db/db.select/db.select.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.select/db.select.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -14,7 +14,7 @@
 <h2>EXAMPLES</h2>
-Basic usage:
+<h3>Basic usage</h3>
 db.select sql="select * from roads"
 </pre></div>
@@ -34,7 +34,7 @@
 <p>
 Select all from table roads:
-db.select -c driver=odbc database=mydb table=roads \
+db.select -c driver=odbc database=mydb table=hospitals \
           input=file.sql output=result.csv
 </pre></div>
@@ -56,7 +56,7 @@
 db.select sql="SELECT x(geo),y(geo) FROM localizzazione"
 </pre></div>
-<p>Execute multiple SQL statements:
+<h3>Execute multiple SQL statements</h3>
 cat file.sql
@@ -68,9 +68,12 @@
 <p>
-<em>Count number of cases falling into same position:</em><br>
-When multiple observation have the spatial coordinates, they can still be counted
-(if needed, coordinates can be uploaded to the attribute table by <em>v.to.db</em>:
+<h3>Count number of cases falling into same position</h3>
+When multiple observation have the spatial coordinates, they can still
+be counted (if needed, coordinates can be uploaded to the attribute
+table by <em>v.to.db</em>:
 db.select sql="SELECT long,lat,site_id,department,obs,COUNT(long) as count_cases \
                FROM diseases GROUP BY long,lat"
@@ -79,11 +82,6 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="sql.html">GRASS SQL interface</a>
-</em>
-<p>
-<em>
@@ -92,8 +90,12 @@
 </em>
+<p>
+<em>
+</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
 Original author unknown (probably CERL)<br>
 Modifications by Radim Blazek, ITC-Irst, Trento, Italy<br>
Modified: grass/branches/releasebranch_7_0/db/db.tables/db.tables.html
--- grass/branches/releasebranch_7_0/db/db.tables/db.tables.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/db/db.tables/db.tables.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -10,24 +10,26 @@
 <h2>EXAMPLES</h2>
-<em>List all tables if database connection is already set</em><br>
+<h3>List all tables if database connection is already set</h3>
 db.tables -p
 </pre></div>
-<p>
-<em>List all DBF tables</em><br>
+<h3>List all DBF tables</h3>
-db.tables driver=dbf database=/home/user/grassdata/fire/PERMANENT/dbf
+db.tables driver=dbf database=/grassdata/nc_spm_08/user1/PERMANENT/dbf
 </pre></div>
-<p>
-<em>List all tables in SQLite database (note that this is the default setting)</em><br>
+<h3>List all tables in SQLite database (note that this is the default setting)</h3>
 db.tables -p driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="db.droptable.html">db.droptable</a>,
Modified: grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html
--- grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/display/d.geodesic/d.geodesic.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -30,7 +30,8 @@
 g.region vect=world_political -p
 d.mon wx0
 d.vect world_political type=area
-d.geodesic coor=55:58W,33:18S,26:43E,60:37N lcolor=yellow tcolor=red
+d.geodesic coordinates=55:58W,33:18S,26:43E,60:37N \
+  line_color=yellow text_color=red
 </pre></div>
 <p><center>
Modified: grass/branches/releasebranch_7_0/display/d.grid/d.grid.html
--- grass/branches/releasebranch_7_0/display/d.grid/d.grid.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/display/d.grid/d.grid.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -56,34 +56,38 @@
 <h2>EXAMPLES</h2>
-To draw a red geographic grid with 30 minute grid spacing run
+To draw a red geographic grid with 30 minute grid spacing, run
 either of the following:
-<pre>
-  d.grid -g size=00:30:00 color=red
-</pre>
+<div class="code"><pre>
+d.grid -g size=00:30:00 color=red
+</pre></div>
 or
-<pre>
-  d.grid -g size=0.5 color=255:0:0
-</pre>
+d.grid -g size=0.5 color=255:0:0
+</pre></div>
 To draw a blue standard rectangular grid at a 500 (meter) spacing run the following:
-<pre>
-  d.grid size=500 color=blue
-</pre>
-<br>
+d.grid size=500 color=blue
+</pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="d.barscale.html">d.barscale</a></em><br>
-<em><a href="d.legend.html">d.legend</a></em><br>
-<em><a href="d.geodesic.html">d.geodesic</a></em><br>
-<em><a href="d.rhumbline.html">d.rhumbline</a></em><br>
-<em><a href="d.erase.html">d.erase</a></em><br>
-<em><a href="d.frame.html">d.frame</a></em><br>
-<em><a href="d.rast.html">d.rast</a></em><br>
+<em>
+<a href="d.barscale.html">d.barscale</a>,
+<a href="d.legend.html">d.legend</a>,
+<a href="d.geodesic.html">d.geodesic</a>,
+<a href="d.rhumbline.html">d.rhumbline</a>,
+<a href="d.erase.html">d.erase</a>,
+<a href="d.frame.html">d.frame</a>,
+<a href="d.rast.html">d.rast</a>
+</em>
 <h2>AUTHORS</h2>
 James Westervelt, U.S. Army Construction Engineering Research Laboratory<br>
Modified: grass/branches/releasebranch_7_0/display/d.path/d.path.html
--- grass/branches/releasebranch_7_0/display/d.path/d.path.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/display/d.path/d.path.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -16,18 +16,19 @@
 <p>To calculate shortest path non-interactively and save the path to a new vector
 map, use the <em>v.net.path</em> module.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
-Interactive shortest path routing on road network (Spearfish region):
+Interactive shortest path routing on road network (North Carolina sample dataset):
-g.region vector=roads
-d.vect roads
-d.path roads
+g.region vect=roadsmajor
+d.vect roadsmajor
+d.path roadsmajor coordinates=668646.15,224447.16,668348.83,235894.02
 </pre></div>
-Non-interactive shortest path routing on road network (Spearfish region):
+<p>
+Non-interactive shortest path routing on road network (North Carolina sample dataset):
-d.path -b roads coor=601653.5,4922869.2,593330.8,4924096.6
+d.path -b roadsmajor coordinates=668646.15,224447.16,668348.83,235894.02
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
--- grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -114,7 +114,7 @@
 # activate vector font
 d.font Vera
-d.vect map=roadsmajor layer=1 display=shape,attr attrcolumn=ROAD_NAME lcolor=0:90:255
+d.vect map=roadsmajor layer=1 display=shape attrcolumn=ROAD_NAME lcolor=0:90:255
 </pre></div>
Modified: grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html
--- grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html	2014-11-28 09:57:47 UTC (rev 63231)
+++ grass/branches/releasebranch_7_0/scripts/db.univar/db.univar.html	2014-11-28 09:58:18 UTC (rev 63232)
@@ -15,6 +15,7 @@
 In this example, random points are sampled from the elevation map
 (North Carolina sample dataset) and univariate statistics performed:
 g.region rast=elevation -p
 v.random output=samples n=100
