[GRASS-SVN] r63233 - in grass/trunk/gui/wxpython: . animation core gmodeler gui_core iclass iscatt lmgr mapdisp mapwin modules psmap rdigit rlisetup vnet web_services
svn_grass at osgeo.org
Fri Nov 28 02:04:27 PST 2014
Author: martinl
Date: 2014-11-28 02:04:27 -0800 (Fri, 28 Nov 2014)
New Revision: 63233
grass/trunk/gui/wxpython/animation/dialogs.py
grass/trunk/gui/wxpython/animation/g.gui.animation.py
grass/trunk/gui/wxpython/animation/provider.py
grass/trunk/gui/wxpython/animation/temporal_manager.py
grass/trunk/gui/wxpython/core/layerlist.py
grass/trunk/gui/wxpython/core/render.py
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gmodeler/model.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/gui_core/prompt.py
grass/trunk/gui/wxpython/gui_core/simplelmgr.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/iscatt/iscatt_core.py
grass/trunk/gui/wxpython/lmgr/datacatalog.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapwin/decorations.py
grass/trunk/gui/wxpython/modules/mcalc_builder.py
grass/trunk/gui/wxpython/psmap/dialogs.py
grass/trunk/gui/wxpython/psmap/instructions.py
grass/trunk/gui/wxpython/rdigit/controller.py
grass/trunk/gui/wxpython/rdigit/dialogs.py
grass/trunk/gui/wxpython/rlisetup/functions.py
grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
grass/trunk/gui/wxpython/rlisetup/wizard.py
grass/trunk/gui/wxpython/vnet/vnet_core.py
grass/trunk/gui/wxpython/vnet/vnet_data.py
grass/trunk/gui/wxpython/web_services/dialogs.py
wxGUI: update to the new element names
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -1278,9 +1278,9 @@
self.addManyMapsButton = wx.BitmapButton(self, bitmap=bitmap)
self.addManyMapsButton.Bind(wx.EVT_BUTTON, self._onAddMaps)
- types = [('rast', _("Multiple raster maps")),
- ('vect', _("Multiple vector maps")),
- ('rast3d', _("Multiple 3D raster maps")),
+ types = [('raster', _("Multiple raster maps")),
+ ('vector', _("Multiple vector maps")),
+ ('3draster', _("Multiple 3D raster maps")),
('strds', _("Space time raster dataset")),
('stvds', _("Space time vector dataset")),
('str3ds', _("Space time 3D raster dataset"))]
@@ -1308,7 +1308,7 @@
if self.layer.mapType:
self._setType(self.layer.mapType)
else:
- self._setType('rast')
+ self._setType('raster')
if self.layer.name:
self.tselect.SetValue(self.layer.name)
if self.layer.cmd:
@@ -1377,14 +1377,14 @@
def _createDefaultCommand(self):
cmd = []
- if self._mapType in ('rast', 'strds'):
+ if self._mapType in ('raster', 'strds'):
cmd.append('d.rast')
- elif self._mapType in ('vect', 'stvds'):
+ elif self._mapType in ('vector', 'stvds'):
cmd.append('d.vect')
- elif self._mapType in ('rast3d', 'str3ds'):
+ elif self._mapType in ('3draster', 'str3ds'):
cmd.append('d.rast3d')
if self._name:
- if self._mapType in ('rast', 'vect', 'rast3d'):
+ if self._mapType in ('raster', 'vector', '3draster'):
cmd.append('map={name}'.format(name=self._name.split(',')[0]))
else:
try:
@@ -1401,9 +1401,9 @@
dlg = MapLayersDialog(self, title=_("Select raster/vector maps."))
dlg.applyAddingMapLayers.connect(lambda mapLayers:
self.tselect.SetValue(','.join(mapLayers)))
- if self._mapType == 'rast':
+ if self._mapType == 'raster':
index = 0
- elif self._mapType == 'vect':
+ elif self._mapType == 'vector':
index = 2
else: # rast3d
index = 1
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -66,8 +66,8 @@
def main():
- rast = options['rast']
- vect = options['vect']
+ rast = options['raster']
+ vect = options['vector']
strds = options['strds']
stvds = options['stvds']
@@ -96,13 +96,13 @@
layerList = LayerList()
if rast:
layer = AnimLayer()
- layer.mapType = 'rast'
+ layer.mapType = 'raster'
layer.name = rast
layer.cmd = ['d.rast', 'map={name}'.format(name=rast.split(',')[0])]
layerList.AddLayer(layer)
if vect:
layer = AnimLayer()
- layer.mapType = 'vect'
+ layer.mapType = 'vector'
layer.name = vect
layer.cmd = ['d.vect', 'map={name=}'.format(name=vect.split(',')[0])]
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/animation/provider.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -757,7 +757,7 @@
layer = Layer()
layer.name = 'buildings_2009_approx'
layer.cmd = ['d.vect', 'map=buildings_2009_approx',
'color=grey']
Modified: grass/trunk/gui/wxpython/animation/temporal_manager.py
--- grass/trunk/gui/wxpython/animation/temporal_manager.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/animation/temporal_manager.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -410,7 +410,7 @@
fd.close()
name1 = 'absinterval1'
name2 = 'absinterval2'
- grass.run_command('t.unregister', type='rast',
+ grass.run_command('t.unregister', type='raster',
maps='prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,'
'temp_1,temp_2,temp_3,temp_4,temp_5,temp_6')
for name, fname in zip((name1, name2), (n1, n2)):
@@ -465,7 +465,7 @@
fd.close()
name1 = 'relinterval1'
name2 = 'relinterval2'
Modified: grass/trunk/gui/wxpython/core/layerlist.py
--- grass/trunk/gui/wxpython/core/layerlist.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/core/layerlist.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -173,7 +173,7 @@
ValueError: To set layer name, the type of layer must be specified.
- >>> layer.mapType = 'rast'
+ >>> layer.mapType = 'raster'
>>> layer.name = 'blablabla'
@@ -191,10 +191,10 @@
self._hidden = False
self._initialized = False
- self._mapTypes = ['rast', 'vect', 'rast3d', 'rgb']
- self._internalTypes = {'rast': 'cell',
- 'vect': 'vector',
- 'rast3d': 'grid3',
+ self._mapTypes = ['raster', 'vector', '3draster', 'rgb']
+ self._internalTypes = {'raster': 'cell',
+ 'vector': 'vector',
+ '3draster': 'grid3',
'rgb': 'rgb'}
def GetName(self):
@@ -246,7 +246,7 @@
def SetMapType(self, mapType):
"""Sets map type of the layer.
- :param mapType: can be 'rast', 'vect', 'rast3'
+ :param mapType: can be 'raster', 'vector', 'rast3'
if mapType not in self._mapTypes:
raise ValueError("Wrong map type used: {mtype}".format(mtype=mapType))
@@ -358,11 +358,11 @@
def AddLayer(self, index, layer):
"""Adds layer to renderer (prepends)."""
mapType = None
- if layer.mapType == 'rast':
+ if layer.mapType == 'raster':
mapType = 'raster'
- elif layer.mapType == 'vect':
+ elif layer.mapType == 'vector':
mapType = 'vector'
- elif layer.mapType == 'rast3d':
+ elif layer.mapType == '3draster':
mapType = '3d-raster'
elif layer.mapType == 'rgb':
mapType = 'rgb'
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/core/render.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -644,13 +644,13 @@
if zoom:
cmd['zoom'] = rast[0]
else:
- cmd['rast'] = ','.join(rast)
+ cmd['raster'] = ','.join(rast)
if vect:
- cmd['vect'] = ','.join(vect)
+ cmd['vector'] = ','.join(vect)
if rast3d:
- cmd['rast3d'] = rast3d
+ cmd['3draster'] = rast3d
ret, reg, msg = RunCommand('g.region',
read = True,
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/core/workspace.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -1423,7 +1423,7 @@
"group" : self.inGroup,
"display" : 0})
- elif element == 'vect' and self.inVector:
+ elif element == 'vector' and self.inVector:
self.layers[-1]['cmd'].append('map=%s' % self._get_value(line))
elif element in ('display_shape',
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gis_set.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -540,9 +540,9 @@
message = _("Map <%s> not found.") % mapName)
else:
if mapName in vectors:
- args = {'vect' : mapName}
+ args = {'vector' : mapName}
else:
- args = {'rast' : mapName}
+ args = {'raster' : mapName}
RunCommand('g.region', flags = 's', parent = self, **args)
def OnManageLoc(self, event):
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -115,9 +115,9 @@
self.shape.SetValue(self.element.GetValue())
if self.etype:
elem = self.GetType()
- if elem == 'rast':
+ if elem == 'raster':
self.shape.SetPrompt('raster')
- elif elem == 'vect':
+ elif elem == 'vector':
self.parent.canvas.Refresh()
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -729,7 +729,7 @@
rast.append(name)
elif prompt == 'vector':
vect.append(name)
- elif prompt == 'rast3d':
+ elif prompt == '3draster':
rast3d.append(name)
msg = ''
@@ -2338,17 +2338,17 @@
if rast:
self.fd.write(
-r""" run_command('g.remove', flags='f', type='rast',
+r""" run_command('g.remove', flags='f', type='raster',
name=%s)
"""% ','.join(map(lambda x: "'" + x + "'", rast)))
if vect:
self.fd.write(
-r""" run_command('g.remove', flags='f', type='vect',
+r""" run_command('g.remove', flags='f', type='vector',
name=%s)
"""% ','.join(map(lambda x: "'" + x + "'", vect)))
if rast3d:
self.fd.write(
-r""" run_command('g.remove', flags='f', type='rast3d',
+r""" run_command('g.remove', flags='f', type='3draster',
name=%s)
"""% ','.join(map(lambda x: "'" + x + "'", rast3d)))
if not rast and not vect and not rast3d:
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -405,7 +405,7 @@
curMapset = grass.gisenv()['MAPSET']
if isNative:
- listOfVectors = grass.list_grouped('vect')[curMapset]
+ listOfVectors = grass.list_grouped('vector')[curMapset]
else:
listOfVectors = RunCommand('v.external',
quiet = True,
@@ -1521,11 +1521,11 @@
sel = self.layerType.GetSelection()
if sel == 0:
- ltype = 'rast'
+ ltype = 'raster'
elif sel == 1:
- ltype = 'rast3d'
+ ltype = '3draster'
else:
- ltype = 'vect'
+ ltype = 'vector'
return ltype
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -206,7 +206,7 @@
maps_param = self.task.get_param('maps', element='name', raiseError=False)
if self.task.get_name().startswith('t') and maps_param is not None:
if maps_param['wxId'][0] != uid:
- element_dict = {'rast': 'strds', 'vect': 'stvds', 'rast3d': 'str3ds'}
+ element_dict = {'raster': 'strds', 'vector': 'stvds', '3draster': 'str3ds'}
self.data[win.GetParent().SetType] = {'etype': element_dict[type_param.get('value')]}
map = layer = None
@@ -1195,7 +1195,7 @@
# for t.(un)register:
maps_param = self.task.get_param('maps', element = 'name', raiseError = False)
if maps_param and orig_elem == 'stds':
elem = element_dict[type_param.get('default')]
if self._giface and hasattr(self._giface, "_model"):
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -428,25 +428,23 @@
curr_mapset = grass.gisenv()['MAPSET']
# map element types to g.list types
- elementdict = {'cell':'rast',
- 'raster':'rast',
- 'rast':'rast',
- 'raster files':'rast',
- 'grid3':'rast3d',
- 'rast3d':'rast3d',
- '3d-raster':'rast3d',
- 'raster3D':'rast3d',
- 'raster3D files':'rast3d',
- 'vector':'vect',
- 'vect':'vect',
- 'binary vector files':'vect',
+ elementdict = {'cell':'raster',
+ 'raster': 'raster',
+ 'raster files':'raster',
+ 'grid3':'3draster',
+ '3draster':'3draster',
+ '3d-raster':'3draster',
+ 'raster3D':'3draster',
+ 'raster3D files':'3draster',
+ 'vector' : 'vector',
+ 'binary vector files':'vector',
'dig':'oldvect',
- 'oldvect':'oldvect',
- 'old vector':'oldvect',
- 'dig_ascii':'asciivect',
- 'asciivect':'asciivect',
- 'asciivector':'asciivect',
- 'ascii vector files':'asciivect',
+ 'oldvect':'oldvector',
+ 'old vector':'oldvector',
+ 'dig_ascii':'asciivector',
+ 'asciivect':'asciivector',
+ 'asciivector':'asciivector',
+ 'ascii vector files':'asciivector',
'icons':'icon',
'icon':'icon',
'paint icon files':'icon',
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -93,8 +93,8 @@
def _getListOfMaps(self):
"""Get list of maps"""
result = dict()
- result['raster'] = grass.list_strings('rast')
- result['vector'] = grass.list_strings('vect')
+ result['raster'] = grass.list_strings('raster')
+ result['vector'] = grass.list_strings('vector')
return result
Modified: grass/trunk/gui/wxpython/gui_core/simplelmgr.py
--- grass/trunk/gui/wxpython/gui_core/simplelmgr.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/gui_core/simplelmgr.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -341,21 +341,21 @@
def AddRaster(self, name, cmd, hidden, dialog):
"""Ads new raster layer."""
- layer = self._layerList.AddNewLayer(name=name, mapType='rast',
+ layer = self._layerList.AddNewLayer(name=name, mapType='raster',
active=True,
cmd=cmd, hidden=hidden)
return layer
def AddRast3d(self, name, cmd, hidden, dialog):
"""Ads new raster3d layer."""
- layer = self._layerList.AddNewLayer(name=name, mapType='rast3d',
+ layer = self._layerList.AddNewLayer(name=name, mapType='3draster',
active=True,
return layer
def AddVector(self, name, cmd, hidden, dialog):
"""Ads new vector layer."""
- layer = self._layerList.AddNewLayer(name=name, mapType='vect',
+ layer = self._layerList.AddNewLayer(name=name, mapType='vector',
active=True,
return layer
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -256,7 +256,7 @@
ret = RunCommand(prog = 'g.remove',
parent = self,
flags = 'f',
- type = 'vect',
+ type = 'vector',
name = self.trainingAreaVector)
if ret != 0:
return False
@@ -269,7 +269,7 @@
parent = self,
flags = 'f',
- type = 'rast',
+ type = 'raster',
name = raster)
if ret != 0:
return False
Modified: grass/trunk/gui/wxpython/iscatt/iscatt_core.py
--- grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -284,7 +284,7 @@
ret = UpdateCatRast(patch_rast, region, self.scatts_dt.GetCatRastCond(cat))
if ret < 0:
GException(_("Patching category raster conditions file failed."))
- RunCommand("g.remove", flags='f', type='rast', name=patch_rast)
+ RunCommand("g.remove", flags='f', type='raster', name=patch_rast)
def _rasterize(self, grass_region, layer, cat, out_rast):
@@ -597,7 +597,7 @@
grass.try_remove(self.cats_rasts_conds[cat_id])
del self.cats_rasts_conds[cat_id]
name=self.cats_rasts[cat_id])
del self.cats_rasts[cat_id]
@@ -709,7 +709,7 @@
grass.try_remove(tmp)
for tmp in self.cats_rasts.itervalues():
- type='rast', name=tmp,
+ type='raster', name=tmp,
getErrorMsg=True)
self.cats_rasts = {}
Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
--- grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -351,9 +351,9 @@
renamed = 0
label = _("Renaming") + " " + string + " ..."
self.showNotification.emit(message=label)
- if (self.GetItemText(self.selected_type)=='vect'):
+ if (self.GetItemText(self.selected_type)=='vector'):
renamed = RunCommand('g.rename', vect=string)
- elif (self.GetItemText(self.selected_type)=='rast'):
+ elif (self.GetItemText(self.selected_type)=='raster'):
renamed = RunCommand('g.rename', rast=string)
else:
renamed = RunCommand('g.rename', rast3d=string)
@@ -387,15 +387,15 @@
type = None
label = _("Copying") + " " + string + " ..."
- if (self.GetItemText(self.copy_type)=='vect'):
+ if (self.GetItemText(self.copy_type)=='vector'):
pasted = RunCommand('g.copy', vect=string)
- node = 'vect'
- elif (self.GetItemText(self.copy_type)=='rast'):
+ node = 'vector'
+ elif (self.GetItemText(self.copy_type)=='raster'):
pasted = RunCommand('g.copy', rast=string)
- node = 'rast'
+ node = 'raster'
else:
pasted = RunCommand('g.copy', rast3d=string)
- node = 'rast3d'
+ node = '3draster'
if pasted == 0:
if self.selected_type == None:
self.selected_type = self.getItemByName(node, self.selected_mapset)
@@ -429,14 +429,14 @@
title=_('Delete map')) == wx.ID_YES):
label = _("Deleting") + " " + string + " ..."
- removed = RunCommand('g.remove', flags='f', type='vect',
+ removed = RunCommand('g.remove', flags='f', type='vector',
name=string)
- removed = RunCommand('g.remove', flags='f', type='rast',
+ removed = RunCommand('g.remove', flags='f', type='raster',
name=string)
else:
- removed = RunCommand('g.remove', flags='f', type='rast3d',
+ removed = RunCommand('g.remove', flags='f', type='3draster',
name=string)
if (removed==0):
self.Delete(self.selected_layer)
@@ -454,12 +454,12 @@
label = _("Displaying") + " " + string + " ..."
label = "d."+self.GetItemText(self.selected_type)+" --q map="+string+" -- completed. Go to Map layers for further operations."
- self.parent.parent.AddMaps(layerName, 'vect', True)
- self.parent.parent.AddMaps(layerName, 'rast', True)
+ self.parent.parent.AddMaps(layerName, 'vector', True)
+ self.parent.parent.AddMaps(layerName, 'raster', True)
else:
- self.parent.parent.AddMaps(layerName, 'rast3d', True)
+ self.parent.parent.AddMaps(layerName, '3draster', True)
label = "d.rast --q map="+string+" -- completed. Go to 'Map layers' for further operations." # generate this message (command) automatically?
Debug.msg(1,"LAYER "+self.GetItemText(self.selected_layer)+" DISPLAYED")
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -1591,7 +1591,7 @@
from animation.data import AnimLayer
layer = AnimLayer()
layer.name = ','.join(rasters)
layer.cmd = ['d.rast', 'map=']
@@ -1840,7 +1840,7 @@
"""Add map layers to layer tree.
:param list mapLayers: list of map names
- :param str ltype: layer type ('rast', 'rast3d', 'vect')
+ :param str ltype: layer type ('raster', '3draster', 'vector')
:param bool check: True if new layers should be checked in
layer tree False otherwise
@@ -1851,13 +1851,13 @@
maptree = self.GetLayerTree()
for layerName in mapLayers:
- if ltype == 'rast':
+ if ltype == 'raster':
cmd = ['d.rast', 'map=%s' % layerName]
wxType = 'raster'
- elif ltype == 'rast3d':
+ elif ltype == '3draster':
cmd = ['d.rast3d', 'map=%s' % layerName]
wxType = '3d-raster'
- elif ltype == 'vect':
+ elif ltype == 'vector':
cmd = ['d.vect', 'map=%s' % layerName] + GetDisplayVectSettings()
wxType = 'vector'
else:
@@ -1899,9 +1899,9 @@
# start new map display if no display is available
# TODO: standardize type identifiers
- convertType = {'raster': 'rast',
- '3d-raster': 'rast3d',
- 'vector': 'vect'}
+ convertType = {'raster': 'raster',
+ '3d-raster': '3draster',
+ 'vector': 'vector'}
try:
grassType = convertType[ltype]
except KeyError:
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -795,13 +795,13 @@
lnameSrc = self.GetLayerInfo(layer, key = 'maplayer').GetName()
- key = 'rast'
+ key = 'raster'
label = _('Raster map')
- key = 'vect'
+ key = 'vector'
label = _('Vector map')
elif ltype == '3d-raster':
- key = 'rast3d'
+ key = '3draster'
label = _('3D raster map')
else:
GError(_("Unsupported map type <%s>") % ltype, parent = self)
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -691,7 +691,7 @@
output=outputRaster, quiet=True,
overwrite=overwrite, getErrorMsg=True)
grass.del_temp_region()
- RunCommand('g.remove', type='rast', flags='f', quiet=True,
+ RunCommand('g.remove', type='raster', flags='f', quiet=True,
name=[tmpName + '.red', tmpName + '.green', tmpName + '.blue'])
if not returncode == 0:
self._giface.WriteError(_('Failed to run d.to.rast:\n') + messages)
@@ -842,9 +842,9 @@
"""Activate query mode and set layers to query.
This method is used for querying in d.mon using d.what.rast/vect"""
self.toolbars['map'].SelectTool(self.toolbars['map'].query)
- if ltype == 'vect':
+ if ltype == 'vector':
self._vectQueryLayers = maps
- elif ltype == 'rast':
+ elif ltype == 'raster':
self._rastQueryLayers = maps
def QueryMap(self, east, north, qdist, rast, vect):
@@ -1171,7 +1171,7 @@
if len(param_val) != 2:
continue
param, val = param_val
- if param == 'rast':
+ if param == 'raster':
self.legend.cmd[idx] = 'rast={rast}'.format(rast=layer.maplayer.name)
isMap = True
elif param in ('use', 'range'):
Modified: grass/trunk/gui/wxpython/mapwin/decorations.py
--- grass/trunk/gui/wxpython/mapwin/decorations.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/mapwin/decorations.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -234,9 +234,9 @@
inputs = 0
for param in self._cmd:
param = param.split('=')
- if param[0] == 'rast' and len(param) == 2:
+ if param[0] == 'raster' and len(param) == 2:
inputs += 1
- elif param[0] == 'rast3d' and len(param) == 2:
+ elif param[0] == '3draster' and len(param) == 2:
inputs += 1
if inputs == 1:
return True
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -110,7 +110,7 @@
if self.rast3d:
self.funct_dict['z()'] = 'z()'
self.funct_dict['tbres()'] = 'tbres()'
- element = 'rast3d'
+ element = '3draster'
else:
element = 'cell'
@@ -601,9 +601,9 @@
if returncode != 0:
return
name = self.newmaptxt.GetValue().strip(' "') + '@' + grass.gisenv()['MAPSET']
- ltype = 'rast'
+ ltype = 'raster'
if self.rast3d:
- ltype = 'rast3d'
self._giface.mapCreated.emit(name=name, ltype=ltype, add=self.addbox.IsChecked())
def OnSaveExpression(self, event):
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -2501,7 +2501,7 @@
rasterType = getRasterType(map = self.currRaster)
self.rasterCurrent = wx.StaticText(panel, id = wx.ID_ANY,
- label = _("%(rast)s: type %(type)s") % { 'rast' : self.currRaster,
+ label = _("%(rast)s: type %(type)s") % { 'raster' : self.currRaster,
'type' : rasterType })
self.rasterSelect = Select(panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
type = 'raster', multiple = False,
@@ -3188,7 +3188,7 @@
rasterType = getRasterType(map = currRaster)
self.rasterCurrent.SetLabel(_("%(rast)s: type %(type)s") % \
- { 'rast' : currRaster, 'type' : str(rasterType) })
+ { 'raster' : currRaster, 'type' : str(rasterType) })
# vector legend
if 'rect' in self.vLegendDict:
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/psmap/instructions.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -443,14 +443,14 @@
# define scaleType
if len(cmd[1]) <= 3:
- if 'rast' in cmd[1]:
+ if 'raster' in cmd[1]:
map['scaleType'] = 0
map['mapType'] = 'raster'
- map['map'] = cmd[1]['rast']
- elif 'vect' in cmd[1]:
+ map['map'] = cmd[1]['raster']
+ elif 'vector' in cmd[1]:
map['mapType'] = 'vector'
- map['map'] = cmd[1]['vect']
+ map['map'] = cmd[1]['vector']
elif 'region' in cmd[1]:
map['scaleType'] = 1
map['region'] = cmd[1]['region']
Modified: grass/trunk/gui/wxpython/rdigit/controller.py
--- grass/trunk/gui/wxpython/rdigit/controller.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/rdigit/controller.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -304,7 +304,7 @@
:param restore: if restore previous cursor, mouse['use']
try:
- gcore.run_command('g.remove', type='rast', flags='f', name=self._backupRasterName, quiet=True)
+ gcore.run_command('g.remove', type='raster', flags='f', name=self._backupRasterName, quiet=True)
except CalledModuleError:
pass
@@ -465,7 +465,7 @@
gcore.run_command('r.patch', input=rastersToPatch[::-1] + [self._backupRasterName],
output=self._editedRaster, overwrite=True, quiet=True)
- gcore.run_command('g.remove', type='rast', flags='f', name=rastersToPatch + [tempRaster],
+ gcore.run_command('g.remove', type='raster', flags='f', name=rastersToPatch + [tempRaster],
quiet=True)
try:
# setting the right color table
Modified: grass/trunk/gui/wxpython/rdigit/dialogs.py
--- grass/trunk/gui/wxpython/rdigit/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/rdigit/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -35,8 +35,8 @@
self._type = None
# create widgets
- self._mapSelect = Select(parent=self, type='rast')
- self._backgroundSelect = Select(parent=self, type='rast')
+ self._mapSelect = Select(parent=self, type='raster')
+ self._backgroundSelect = Select(parent=self, type='raster')
self._typeChoice = wx.Choice(self, choices=['CELL', 'FCELL', 'DCELL'])
self._typeChoice.SetSelection(0)
self._mapSelect.SetFocus()
Modified: grass/trunk/gui/wxpython/rlisetup/functions.py
--- grass/trunk/gui/wxpython/rlisetup/functions.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/rlisetup/functions.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -27,7 +27,7 @@
WHOLE = 'whole'
REGIONS = 'regions'
UNITS = 'units'
- VECT = 'vect'
+ VECT = 'vector'
MVWIN = 'moving'
KMVWINC = 'kmvwin_circle'
@@ -67,7 +67,7 @@
return rlipath
-def checkMapExists(name, typ='rast'):
+def checkMapExists(name, typ='raster'):
"""Check if a map already exist in the working mapset"""
env = grass.gisenv()
mapset = env['MAPSET']
@@ -90,7 +90,7 @@
grass.run_command('v.to.rast', input=tmp_vect, type='area',
layer=layer, use='val', value=cat, output=outrast,
overwrite=overwrite, quiet=True)
- grass.run_command('g.remove', flags='f', type='vect',
+ grass.run_command('g.remove', flags='f', type='vector',
name=tmp_vect, quiet=True)
@@ -133,7 +133,7 @@
rast_name = "{pref}{cat}".format(pref=outpref, cat=cat)
# check if raster already axist
- if len(grass.list_strings('rast', pattern=rast_name, mapset='.')) == 1 \
+ if len(grass.list_strings('raster', pattern=rast_name, mapset='.')) == 1 \
and not overwrite:
GError(message=_("The raster map <%s> already exists."
" Please remove or rename the maps "
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -263,8 +263,8 @@
marea = MaskedArea(region, rasterName)
- RunCommand('g.remove', flags='f', type='rast', name=tmpraster)
- RunCommand('g.remove', flags='f', type='vect', name=tmpvector)
+ RunCommand('g.remove', flags='f', type='raster', name=tmpraster)
+ RunCommand('g.remove', flags='f', type='vector', name=tmpvector)
os.unlink(polyfile.name)
return marea
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -1573,7 +1573,7 @@
self.outname = "{pref}{cat}".format(pref=self.outpref, cat=cat)
- if len(grass.list_strings('rast', pattern=self.outname, mapset='.')) == 1 \
+ if len(grass.list_strings('raster', pattern=self.outname, mapset='.')) == 1 \
and not self.parent.samplingareapage.overwriteTemp:
GError(parent=self, message=_("The raster map <%s> already exists."
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -121,7 +121,7 @@
# for case there is some map with same name
# (when analysis does not produce any map, this map would have been shown as result)
- RunCommand('g.remove', flags = 'f', type = 'vect',
+ RunCommand('g.remove', flags = 'f', type = 'vector',
name = self.results["vect_map"].GetVectMapName())
# save data from
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -611,8 +611,8 @@
# check vector map
if params["input"]:
mapName, mapSet = params["input"].split("@")
- if grass.list_grouped('vect').has_key(mapSet):
- vectMaps = grass.list_grouped('vect')[mapSet]
+ if grass.list_grouped('vector').has_key(mapSet):
+ vectMaps = grass.list_grouped('vector')[mapSet]
if not params["input"] or mapName not in vectMaps:
invParams = params.keys()[:]
@@ -938,7 +938,7 @@
if vectMap:
vectMap.DeleteRenderLayer()
name = vectMap.GetVectMapName())
self.RemoveFromTmpMaps(vectMap)
return True
@@ -948,7 +948,7 @@
"""Delete all temporary maps in the class"""
update = False
for tmpMap in self.tmpMaps:
name = tmpMap.GetVectMapName())
if tmpMap.DeleteRenderLayer():
update = True
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py 2014-11-28 09:58:18 UTC (rev 63232)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py 2014-11-28 10:04:27 UTC (rev 63233)
@@ -792,7 +792,7 @@
self.labels['output'] = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Name for output raster map:"))
- self.params['output'] = Select(parent = self, type = 'rast', mapsets = [grass.gisenv()['MAPSET']],
+ self.params['output'] = Select(parent = self, type = 'raster', mapsets = [grass.gisenv()['MAPSET']],
size = globalvar.DIALOG_GSELECT_SIZE)
self.regionStBoxLabel = wx.StaticBox(parent = self, id = wx.ID_ANY,
