[GRASS-SVN] r63249 - grass/branches/releasebranch_7_0/lib/db/sqlp
svn_grass at osgeo.org
Fri Nov 28 07:32:29 PST 2014
Author: neteler
Date: 2014-11-28 07:32:29 -0800 (Fri, 28 Nov 2014)
New Revision: 63249
grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
SQL manual: examples updated
Modified: grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
--- grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2014-11-28 15:32:24 UTC (rev 63248)
+++ grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2014-11-28 15:32:29 UTC (rev 63249)
@@ -2,7 +2,13 @@
<!-- this file is lib/db/sqlp/sql.html -->
-GRASS can use various RDBMS
+Vector points, lines and areas usually have attribute data that are
+stored in DBMS. The attributes are linked to each vector object using a
+category number (attribute ID, usually the "cat" integer column). The
+category numbers are stored both in the vector geometry and the
+attribute table.
+<p>
+GRASS GIS supports various RDBMS
(<a href="http://en.wikipedia.org/wiki/Relational_database_management_system">Relational
database management system</a>) and embedded databases. SQL
(<a href="http://en.wikipedia.org/wiki/Sql">Structured Query
@@ -12,57 +18,68 @@
<h2>Database drivers</h2>
-The list of available database drivers can vary in various binary
-distributions of GRASS:<br><br>
+The default database driver used by GRASS GIS 7 is SQLite. GRASS GIS
+handles multiattribute vector data by default. The <em>db.*</em> set of
+commands provides basic SQL support for attribute management, while the
+<em>v.db.*</em> set of commands operates on vector maps.
+<p>
+Note: The list of available database drivers can vary in various binary
+distributions of GRASS GIS:
+<p>
<table class="border">
-<tr><td><a href="grass-dbf.html">dbf</a></td><td>DBF files. Data are stored in DBF files.</td>
+<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>Data storage in SQLite database files (default DB backend)</td>
+<td><a href="http://sqlite.org/">http://sqlite.org/</a></td></tr>
+<tr><td><a href="grass-dbf.html">dbf</a></td><td>Data storage in DBF files</td>
<td><a href="http://shapelib.maptools.org/dbf_api.html">http://shapelib.maptools.org/dbf_api.html</a></td></tr>
-<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>SQLite embedded database (GRASS 7 default DB backend).</td>
-<td><a href="http://sqlite.org/">http://sqlite.org/</a></td></tr>
-<tr><td><a href="grass-pg.html">pg</a></td><td>PostgreSQL RDBMS.</td>
+<tr><td><a href="grass-pg.html">pg</a></td><td>Data storage in PostgreSQL RDBMS</td>
<td><a href="http://postgresql.org/">http://postgresql.org/</a></td></tr>
-<tr><td><a href="grass-mysql.html">mysql</a></td><td>MySQL RDBMS.</td>
+<tr><td><a href="grass-mysql.html">mysql</a></td><td>Data storage in MySQL RDBMS</td>
<td><a href="http://mysql.org/">http://mysql.org/</a></td></tr>
-<tr><td><a href="grass-mesql.html">mesql</a></td><td>MySQL embedded database.</td>
+<tr><td><a href="grass-mesql.html">mesql</a></td><td>Data are stored in MySQL embedded database</td>
-<tr><td><a href="grass-odbc.html">odbc</a></td><td>UnixODBC. (PostgreSQL, Oracle, etc.)</td>
+<tr><td><a href="grass-odbc.html">odbc</a></td><td>Data storage via UnixODBC (PostgreSQL, Oracle, etc.)</td>
<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
-<tr><td><a href="grass-ogr.html">ogr</a></td><td>OGR files.</td>
-<td><a href="http://gdal.org/ogr">http://gdal.org/ogr</a></td></tr>
+<tr><td><a href="grass-ogr.html">ogr</a></td><td>Data storage in OGR files</td>
+<td><a href="http://gdal.org/ogr">http://gdal.org/ogr/</a></td></tr>
</table>
<h2>NOTES</h2>
+<h3>Database table name restrictions</h3>
<ul>
-<li> SQL does not support '.' (dots) in table names.
+<li> No dots allowed as SQL does not support '.' (dots) in table names.</li>
<li> Supported table name characters are only: <br>
-<div class="code"><pre>[A-Za-z][A-Za-z0-9_]*</pre></div>
-<li> A table name must start with a character, not a number.
+<div class="code"><pre>
+[A-Za-z][A-Za-z0-9_]*
+</pre></div></li>
+<li> A table name must start with a character, not a number.</li>
<li> Text-string matching requires the text part to be 'single quoted'.
When run from the command line multiple queries should be contained
in "double quotes". e.g.<br>
d.vect map where="individual='juvenile' and area='beach'"
-</pre></div>
+</pre></div></li>
+<li> Attempts to use a reserved SQL word (depends on database backend) as
+ column or table name will cause a "SQL syntax error".</li>
<li> An error message such as "<tt>dbmi: Protocol
error</tt>" either indicates an invalid column name or an
unsupported column type (then the GRASS SQL parser needs to be
extended).</li>
<li> DBF column names are limited to 10 characters (DBF API definition).</li>
-<li> Attempts to use a reserved SQL word (depends on database backend) as
- column or table name will cause a "SQL syntax error".</li>
</ul>
<h2>EXAMPLES</h2>
+<h3>Display of vector feature selected by attribute query</h3>
Display all vector points except for <i>LAMAR</i> valley
and <i>extensive trapping</i> (brackets are superfluous in this
example):
@@ -81,17 +98,16 @@
</pre></div>
<p>
-<p>Example of subquery expressions from a list (does not work
-for DBF driver):
+<p>
+Example of subquery expressions from a list (not supported for DBF driver):
v.db.select mysites where="id IN ('P04', 'P05')"
</pre></div>
-<p>Example of pattern matching:
+<h3>Example of pattern matching</h3>
# field contains string:
# for DBF driver:
v.extract rivers out=rivers_noce where="DES LIKE 'NOCE'"
@@ -105,7 +121,7 @@
v.db.select mysites where="id LIKE 'P%'"
</pre></div>
-<p>Example of null handling:
+<h3>Example of null handling</h3>
v.db.addcolumn map=roads col="nulltest int"
@@ -114,7 +130,9 @@
v.db.update map=roads col=nulltest value=2 where="cat <= 2"
</pre></div>
-<p>Examples of complex expressions in updates (using <tt>v.db.*</tt>
+<h3>Update of attributes</h3>
+Examples of complex expressions in updates (using <tt>v.db.*</tt>
modules):
@@ -123,7 +141,8 @@
v.db.update map=roads col=exprtest value=cat/nulltest+cat where=cat=1
</pre></div>
-<p>Examples of complex expressions in updates (using <tt>db.*</tt>
+<p>
+Examples of complex expressions in updates (using <tt>db.*</tt>
modules):
@@ -143,12 +162,14 @@
d.vect roads where="cat>exprtest"
</pre></div>
-<p>Example of changing a SQL type (type casting, does not work
-for DBF driver):
+<h3>Example of changing a SQL type (type casting)</h3>
+<i>Note: not supported for DBF driver.</i>
+<p>
+North Carolina data set: convert string column to double precision:
+<p>
-# North Carolina data set: convert string column to double precision
-# copy map into current mapset
+# first copy map into current mapset
g.copy vect=geodetic_pts,mygeodetic_pts
v.db.addcolumn mygeodetic_pts col="zval double precision"
@@ -158,9 +179,10 @@
where="z_value <> 'N/A'"
</pre></div>
-<p>Example of concatenating fields (does not work for DBF
-driver):
+<h3>Example of concatenating fields</h3>
v.db.update vectormap column=column3 qcolumn="column1 || column2"
</pre></div>
