[GRASS-SVN] r63250 - in grass/trunk: display/d.colortable display/d.vect display/d.vect.chart imagery/i.fft misc/m.transform raster/r.cost raster/r.drain raster/r.out.mpeg raster/r.slope.aspect raster/r.spreadpath raster/r.topmodel scripts/d.polar scripts/v.what.vect vector/v.edit vector/v.kcv vector/v.kernel vector/v.out.postgis vector/v.qcount vector/v.surf.rst vector/v.to.points vector/v.vol.rst
svn_grass at osgeo.org
Fri Nov 28 07:43:22 PST 2014
Author: martinl
Date: 2014-11-28 07:43:22 -0800 (Fri, 28 Nov 2014)
New Revision: 63250
grass/trunk/display/d.colortable/d.colortable.html
grass/trunk/display/d.vect.chart/d.vect.chart.html
grass/trunk/display/d.vect/d.vect.html
grass/trunk/imagery/i.fft/i.fft.html
grass/trunk/misc/m.transform/m.transform.html
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.drain/r.drain.html
grass/trunk/raster/r.out.mpeg/r.out.mpeg.html
grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
grass/trunk/raster/r.spreadpath/r.spreadpath.html
grass/trunk/raster/r.topmodel/r.topmodel.html
grass/trunk/scripts/d.polar/d.polar.html
grass/trunk/scripts/v.what.vect/v.what.vect.html
grass/trunk/vector/v.edit/v.edit.html
grass/trunk/vector/v.kcv/v.kcv.html
grass/trunk/vector/v.kernel/v.kernel.html
grass/trunk/vector/v.out.postgis/v.out.postgis.html
grass/trunk/vector/v.qcount/v.qcount.html
grass/trunk/vector/v.surf.rst/v.surf.rst.html
grass/trunk/vector/v.to.points/v.to.points.html
grass/trunk/vector/v.vol.rst/v.vol.rst.html
update manual pages (#2409)
Modified: grass/trunk/display/d.colortable/d.colortable.html
--- grass/trunk/display/d.colortable/d.colortable.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/display/d.colortable/d.colortable.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -28,7 +28,7 @@
<b>d.colortable map=</b><em>soils</em>
<b>color=</b><em>red</em>
<b>lines=</b><em>1</em>
- <b>cols=</b><em>3</em>
+ <b>columns =</b><em>3</em>
</dl>
would see the active graphics frame divided into three columns
extending the full frame height. The lines dividing the color table
Modified: grass/trunk/display/d.vect/d.vect.html
--- grass/trunk/display/d.vect/d.vect.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/display/d.vect/d.vect.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -10,7 +10,7 @@
which allow the user to specify vector type, colors, data fields, SQL
queries, label size and justification, etc.
-<p>By default <em>d.vect</em> areas are filled with <b>fcolor</b> and
+<p>By default <em>d.vect</em> areas are filled with <b>fill_color</b> and
outlined with <b>color</b>. Area outlines can be suppressed with
<div class="code"><pre>
d.vect map=vector_map color=none
Modified: grass/trunk/display/d.vect.chart/d.vect.chart.html
--- grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -22,7 +22,7 @@
The optional <b>max_ref</b> parameter accepts a list of values that
represent the maximum value for each column listed in the values for the
parameter <b>columns</b>. These values are used to create a framed bar
-plot if <b>ctype</b> is <em>bar</em> (See Example 2).
+plot if <b>chart_type</b> is <em>bar</em> (See Example 2).
<h2>EXAMPLES</h2>
Modified: grass/trunk/imagery/i.fft/i.fft.html
--- grass/trunk/imagery/i.fft/i.fft.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/imagery/i.fft/i.fft.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -2,17 +2,17 @@
<em>i.fft</em> is an image processing program based on the FFT algorithm
given by Frigo et al. (1998), that processes a single input raster map layer
-(<b>input_image</b>) and constructs the real and imaginary Fourier
+(<b>input</b>) and constructs the real and imaginary Fourier
components in frequency space.
<h2>NOTES</h2>
The real and imaginary components are stored into the
-<b>real_image</b> and <b>imaginary_image</b> raster map
+<b>real</b> and <b>imaginary</b> raster map
layers. In these raster map
layers the low frequency components are in the center and
the high frequency components are toward the edges. The
-<b>input_image</b> need not be square. A
+<b>input</b> need not be square. A
color table is assigned to the resultant map layer.
Modified: grass/trunk/misc/m.transform/m.transform.html
--- grass/trunk/misc/m.transform/m.transform.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/misc/m.transform/m.transform.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -6,7 +6,7 @@
<h2>NOTES</h2>
-For coordinates given with the <b>coords</b> file option or fed from
+For coordinates given with the <b>input</b> file option or fed from
<tt>stdin</tt>, the input format is "x y" with one coordinate pair per
line.
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.cost/r.cost.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -24,18 +24,18 @@
<p>
<em>r.cost</em> can be run with three different methods of identifying the
starting point(s). One or more points (geographic coordinate pairs) can be
-provided as specified <b>start_coordinate</b> on the command line, from a vector
+provided as specified <b>start_coordinates</b> on the command line, from a vector
points file, or from a raster map.
All non-NULL cells are considered to be starting points.
<p>
-Each <em>x,y</em> <b>start_coordinate</b> pair gives the geographic location of a
+Each <em>x,y</em> <b>start_coordinates</b> pair gives the geographic location of a
point from which the transportation cost should be figured. As many points as
desired can be entered by the user. These starting points can also be read
from a vector points file through the <b>start_points</b> option or from a
raster map through the <b>start_rast</b> option.
<p>
<em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
-or one of the stop points given with <b>stop_coordinate</b> is reached.
+or one of the stop points given with <b>stop_coordinates</b> is reached.
Alternatively, the stop points can be read from a vector points file with the
<b>stop_points</b> option. During execution, once the cumulative cost to all
stopping points has been determined, processing stops.<br>
Modified: grass/trunk/raster/r.drain/r.drain.html
--- grass/trunk/raster/r.drain/r.drain.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.drain/r.drain.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -3,7 +3,7 @@
<em>r.drain</em> traces a flow through a least-cost path in an
elevation model or cost surface. For cost surfaces, a movement
direction map must be specified with the
-<b>indir</b> option and the <b>-d</b> flag to trace a flow path following
+<b>direction</b> option and the <b>-d</b> flag to trace a flow path following
the given directions. Such a movement direction map can be generated with
<em><a href="r.walk.html">r.walk</a></em>,
<em><a href="r.cost.html">r.cost</a></em>,
Modified: grass/trunk/raster/r.out.mpeg/r.out.mpeg.html
--- grass/trunk/raster/r.out.mpeg/r.out.mpeg.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.out.mpeg/r.out.mpeg.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -34,11 +34,11 @@
<p>UNIX - style wild cards may be used with the command line version
in place of a raster map name, but wild cards must be quoted.
-<p>A quality value of <b>qual=1</b> will yield higher quality images,
+<p>A quality value of <b>quality=1</b> will yield higher quality images,
but with less compression (larger MPEG file size). Compression ratios
will vary depending on the number of frames in the animation, but an
-MPEG produced using <b>qual=5</b> will usually be about 60% the size
-of the MPEG produced using <b>qual=1</b>.
+MPEG produced using <b>quality=5</b> will usually be about 60% the size
+of the MPEG produced using <b>quality=1</b>.
<h2>Example</h2>
Modified: grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
--- grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -5,7 +5,7 @@
elevation values. The user must specify the input <b>elevation</b> raster map
and at least one output raster maps. The user can also specify the
<b>format</b> for slope (degrees, percent; default=degrees), and the
-<b>zfactor</b>: multiplicative factor to convert elevation units to meters;
+<b>zscale</b>: multiplicative factor to convert elevation units to meters;
(default 1.0).
<p>
@@ -13,7 +13,7 @@
elevation values, <em>not</em> rescaled or categorized data. If the elevation
values are in feet or other units than meters (with a conversion factor
<i>meters:</i>, defined in PROJ_UNITS), they must be converted to meters using
-the parameter <b>zfactor</b>.
+the parameter <b>zscale</b>.
<p>
The <b>aspect</b> output raster map indicates the direction that slopes are
Modified: grass/trunk/raster/r.spreadpath/r.spreadpath.html
--- grass/trunk/raster/r.spreadpath/r.spreadpath.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.spreadpath/r.spreadpath.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -29,7 +29,7 @@
<dt><b>y_input=</b><em>name</em>
<dd>Name of input raster map layer containing backlink UTM northing coordinates.
-<dt><b>coordinate=</b><em>x,y[,x,y,x,y, ...]</em>
+<dt><b>coordinates =</b><em>x,y[,x,y,x,y, ...]</em>
<dd>Each x,y coordinate pair gives the easting and northing
(respectively) geographic coordinates of a target point from which to
backwards trace the least cost path. As many points as desired can be
Modified: grass/trunk/raster/r.topmodel/r.topmodel.html
--- grass/trunk/raster/r.topmodel/r.topmodel.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -110,20 +110,20 @@
for all the topographic index classes.
</dd>
-<dt><b>topidxclass</b></dt>
+<dt><b>toptopidxclass</b></dt>
<dd>
If a topographic index class is specified, output will be generated for the
given topographic index class. This parameter can be combined with timestep. If
no timestep is given, output will be generated for all the time steps.
</dd>
-<dt><b>topidx</b>, <b>ntopidxclasses</b>, <b>outtopidxstats</b></dt>
+<dt><b>topidx</b>, <b>ntoptopidxclasses</b>, <b>outtoptopidxstats</b></dt>
<dd>
The <b>topidx</b> map can optionally be used for creating a new topographic
index statistics file. This map has to be already clipped to the catchment
boundary. The entire range of topographic index values will be divided into
-<b>ntopidxclasses</b> and the area ratio of each class will be reported in the
-<b>outtopidxstats</b> file. These three parameters can be omitted unless a new
+<b>ntoptopidxclasses</b> and the area ratio of each class will be reported in the
+<b>outtoptopidxstats</b> file. These three parameters can be omitted unless a new
topidxstats file needs to be created.
</dd>
</dl>
Modified: grass/trunk/scripts/d.polar/d.polar.html
--- grass/trunk/scripts/d.polar/d.polar.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/scripts/d.polar/d.polar.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -19,7 +19,7 @@
<h2>NOTES</h2>
-If the <b>eps</b> parameter is used, the diagram is generated
+If the <b>output</b> parameter is used, the diagram is generated
as EPS file. If the <b>-x</b> flag is used <em>xgraph</em> is lauched.
Otherwise <em>d.polar</em> will use <em>d.graph</em> to draw the plot
in the current display frame.
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.html
--- grass/trunk/scripts/v.what.vect/v.what.vect.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -1,19 +1,19 @@
<h2>DESCRIPTION</h2>
-<em>v.what.vect</em> transfers attributes from the <b>qvector</b>'s map
+<em>v.what.vect</em> transfers attributes from the <b>query_map</b>'s map
attribute table into the attribute table of <u>points</u> present in the
-<b>vector</b> map. The script is based on <em>v.distance</em>.
+<b>map</b> map. The script is based on <em>v.distance</em>.
<h2>NOTES</h2>
The upload <b>column</b>, into which the query results are stored, must be
-present in the <b>vector</b> map. Use <em>v.db.addcolumn</em> to add one if needed.
+present in the <b>map</b> map. Use <em>v.db.addcolumn</em> to add one if needed.
<p>Use dmax parameter to control query distance tolerance (how far points/centroids
-can be from <b>qvector</b> features). For more options, use
+can be from <b>query_map</b> features). For more options, use
<em>v.distance</em> instead.
-<p>In case of a multipoint input <b>vector</b> map, with several points having the
+<p>In case of a multipoint input <b>map</b> map, with several points having the
same category number, it can happen, that the query result is NULL, if the same
-category number falls into different <b>qvector</b> polygons.
+category number falls into different <b>query_map</b> polygons.
<p>When transferring attributes from a point map to a polygon map, usually <b>dmax</b>
has to be larger than zero (determined by distance between query points and
polygon centroids).
Modified: grass/trunk/vector/v.edit/v.edit.html
--- grass/trunk/vector/v.edit/v.edit.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.edit/v.edit.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -15,7 +15,7 @@
box <b>bbox</b>, <b>polygon</b>, <b>where</b> statement (attribute
data) or by <b>query</b>. Selecting features by coordinates is
affected by the current 2D resolution or by the threshold distance
-given by <b>thresh</b>. The options are <em>orthogonal</em>, i.e. can
+given by <b>threshold</b>. The options are <em>orthogonal</em>, i.e. can
be used in various combinations. For example:
@@ -43,7 +43,7 @@
<li><b>ids</b> - using internal (unique) feature id's</li>
<li><b>cats</b> - using category numbers</li>
<li><b>coords</b> - using x,y coordinate pairs (center of bounding
- box, size defined by <b>thresh</b>)</li>
+ box, size defined by <b>threshold</b>)</li>
<li><b>bbox</b> - using bounding box</li>
<li><b>polygon</b> - using polygon (at least 3 coordinate pairs have to be set)</li>
<li><b>where</b> - using where statement (attribute data)
@@ -54,7 +54,7 @@
<ul>
<li><b>layer</b> - layer number (currently used only
with <b>cats</b> or <b>where</b> option)</li>
- <li><b>thresh</b> - threshold distance used for selecting vector
+ <li><b>threshold</b> - threshold distance used for selecting vector
features by coordinates</li>
</ul>
@@ -73,7 +73,7 @@
from the given text file (<b>input</b> option). If no header is
given, the <b>-n</b> flag must be used. Added features can be
snapped (defined by <b>snap</b> parameter) to nodes or vertices
- based on threshold distance <b>thresh</b>.</li>
+ based on threshold distance <b>threshold</b>.</li>
<li><b>delete</b> - Delete selected vector features from existing
vector map.</li>
@@ -87,7 +87,7 @@
<b>move</b> option. The option defines coordinates of the movement
direction. Moved features can be snapped (defined by <b>snap</b>
parameter) to nodes or vertices based on threshold
- distance <b>thresh</b>.</li>
+ distance <b>threshold</b>.</li>
<li><b>flip</b> - Flip direction of selected vector lines
(lines or boundaries).</li>
@@ -119,7 +119,7 @@
first given line is connected to the second one. The second line
is broken if necessary. The lines are connected only if distance
between them is not greater than snapping threshold
<li><b>chtype</b> - Change feature type of selected geometry
objects. Points are converted to centroids, centroids to points,
@@ -139,7 +139,7 @@
the <b>move</b> option. If -1 is given only first found
line or boundary in bounding box is modified. Moved vertex can be
snapped (defined <b>snap</b>) to nodes or vertices based on
- threshold distance <b>thresh</b>.</li>
+ threshold distance <b>threshold</b>.</li>
<li><b>zbulk</b> - Assign z coordinate to 3D vector lines in given
bounding box. The first found line will get z coordinate based on
Modified: grass/trunk/vector/v.kcv/v.kcv.html
--- grass/trunk/vector/v.kcv/v.kcv.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.kcv/v.kcv.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -1,7 +1,7 @@
<em>v.kcv</em> randomly divides a points lists into <em>k</em> sets of
-test/train data (for <b>k</b>-fold <b>c</b>ross <b>v</b>alidation).
+test/train data (for <b>npartitions</b>-fold <b>c</b>ross <b>v</b>alidation).
Test partitions are mutually exclusive. That is, a point will appear in
only one test partition and <em>k-1</em> training partitions.
Modified: grass/trunk/vector/v.kernel/v.kernel.html
--- grass/trunk/vector/v.kernel/v.kernel.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.kernel/v.kernel.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -15,7 +15,7 @@
<h2>NOTES</h2>
-The <b>mult</b> option is needed to overcome the limitation that
+The <b>multiplier</b> option is needed to overcome the limitation that
the resulting density in case of a vector map output is stored as category
(integer). The density result stored as category may be multiplied by this number.
<p>
Modified: grass/trunk/vector/v.out.postgis/v.out.postgis.html
--- grass/trunk/vector/v.out.postgis/v.out.postgis.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.out.postgis/v.out.postgis.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -54,7 +54,7 @@
<p>
<em>v.out.postgis</em> optionally also creates a new vector map in the
-current mapset if <b>olink</b> is defined.
+current mapset if <b>output_link</b> is defined.
<h2>NOTES</h2>
@@ -161,7 +161,7 @@
<h3>Export data into specific database schema</h3>
Database schema for storing exported data can be defined
-by <b>olayer</b> as
+by <b>output_layer</b> as
<tt><schema_name>.<table_name></tt>. If the specified
schema doesn't exist in the database, then it's automatically created.
@@ -187,7 +187,7 @@
<h3>Link exported data</h3>
Exported data can be linked as vector map created in the current
-mapset by specifying <b>olink</b> parameter. In the example below
+mapset by specifying <b>output_link</b> parameter. In the example below
vector map "busstopsall" from PERMANENT mapset is exported
into "grass" PostGIS database. <em>v.out.postgis</em> after
successful export also creates in the current mapset GRASS vector map
Modified: grass/trunk/vector/v.qcount/v.qcount.html
--- grass/trunk/vector/v.qcount/v.qcount.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.qcount/v.qcount.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -1,7 +1,7 @@
-<em>v.qcount</em> chooses <b>n</b> circular quadrats of
-radius <b>r</b> such that they are completely within the
+<em>v.qcount</em> chooses <b>nquadradius ants</b> circular quadrats of
+radius <b>radius</b> such that they are completely within the
bounds of the current region and no two quadrats overlap.
The number of points falling within each quadrat are counted
and indices are calculated to estimate the departure of
Modified: grass/trunk/vector/v.surf.rst/v.surf.rst.html
--- grass/trunk/vector/v.surf.rst/v.surf.rst.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.surf.rst/v.surf.rst.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -47,7 +47,7 @@
smoothing parameter set to zero (<b>smooth=0</b>) the resulting
surface passes exactly through the data points (spatial interpolation
is performed). When smoothing parameter is used, it is also possible
-to output a vector point map <b>devi</b> containing deviations of the
+to output a vector point map <b>deviations</b> containing deviations of the
resulting surface from the given data.
<p>
@@ -162,7 +162,7 @@
depend on the actual scale (distances) of the original data (which
can be km for regional applications or cm for field
experiments).</li>
- <li>Flag<b> -t </b>: The given <b>tension</b> is applied to
+ <li>Flag<b>-t</b>: The given <b>tension</b> is applied to
un-normalized data (rescaled <em>tension = tension*dnorm/1000</em>
is applied to normalized data (<em>x/dnorm</em>) and
therefore <b>dnorm</b> cancels out) so here <b>tension</b> truly
@@ -262,7 +262,7 @@
<p>
The "optimal" approximation parameters for given data can be
-found using a cross-validation (CV) procedure (<b>-c </b>flag). The
+found using a cross-validation (CV) procedure (<b>-c</b>flag). The
CV procedure is based on removing one input data point at a time,
performing the approximation for the location of the removed point
using the remaining data points and calculating the difference between
Modified: grass/trunk/vector/v.to.points/v.to.points.html
--- grass/trunk/vector/v.to.points/v.to.points.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.to.points/v.to.points.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -15,7 +15,7 @@
<p>
By default only features with category are processed,
-see <b>llayer</b> parameter for details.
+see <b>layer</b> parameter for details.
<h2>NOTES</h2>
@@ -25,9 +25,9 @@
<em><a href="v.segment.html">v.segment</a></em>.
<p>
-Set <b>llayer</b> to -1 to process features from all layers including
+Set <b>layer</b> to -1 to process features from all layers including
features without category. Features will be assigned new unique
-categories at layer 1. Option <b>llayer=-1</b> should be used to
+categories at layer 1. Option <b>layer=-1</b> should be used to
convert boundaries, as in most of cases boundaries lack category
values.
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html 2014-11-28 15:32:29 UTC (rev 63249)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html 2014-11-28 15:43:22 UTC (rev 63250)
@@ -4,21 +4,21 @@
3-dimensional point data (e.g. temperature, rainfall data from climatic
stations, concentrations from drill holes etc.) given in a 3-D vector
point file named <b>input</b>. The size of the output
-3D raster map <b>elev</b> is given by the current 3D region. Sometimes, the
+3D raster map <b>elevation</b> is given by the current 3D region. Sometimes, the
user
may want to get a 2-D map showing a modelled phenomenon at a
-crossection surface. In that case, <b>cellinp</b> and <b>cellout</b>
-options must be specified, with the output 2D raster map <b>cellout</b>
+crossection surface. In that case, <b>cross_input</b> and <b>cross_output</b>
+options must be specified, with the output 2D raster map <b>cross_output</b>
containing the crossection of the interpolated volume with a surface
-defined by <b>cellinp</b>
+defined by <b>cross_input</b>
2D raster map. As an option, simultaneously with interpolation,
geometric parameters of the interpolated
phenomenon can be computed (magnitude of gradient, direction of
gradient defined by horizontal and vertical angles), change of gradient,
Gauss-Kronecker curvature, or mean curvature). These geometric
parameteres are saved as
-3D raster maps <b>gradient, aspect1, aspect2, ncurv, gcurv, mcurv</b>,
-respectively. Maps <b>aspect1</b> and <b>aspect2</b> are in degrees.
+3D raster maps <b>gradient, aspect_horizontal, aspect_vertical, ncurvature, gcurvature, mcurvature</b>,
+respectively. Maps <b>aspect_horizontal</b> and <b>aspect_vertical</b> are in degrees.
<p>At first, data points are checked for identical positions and points
that are closer to each other than given <b>dmin</b> are removed.
@@ -43,7 +43,7 @@
With the
smoothing parameter set to zero (<b>smooth=0</b>) the resulting volume
passes exactly through the data points.
-When smoothing is used, it is possible to output a vector map <b>devi</b>
+When smoothing is used, it is possible to output a vector map <b>deviations</b>
containing deviations of the resulting volume from the given data.
<p>The user can define a 2D raster map named <b>maskmap</b>, which will
be used as a mask. The interpolation is skipped for 3-dimensional cells
@@ -127,9 +127,9 @@
on Oct-trees which enhances the efficiency for large data sets.
<p>Geometric parameters - magnitude of gradient (<b>gradient</b>),
-horizontal (<b>aspect1</b>) and vertical (<b>aspect2) </b>aspects,
-change of gradient (<b>ncurv</b>), Gauss-Kronecker (<b>gcurv</b>) and
-mean curvatures (<b>mcurv</b>) are computed directly from the
+horizontal (<b>aspect_horizontal</b>) and vertical (<b>aspect_vertical)</b>aspects,
+change of gradient (<b>ncurvature</b>), Gauss-Kronecker (<b>gcurvature</b>) and
+mean curvatures (<b>mcurvature</b>) are computed directly from the
interpolation function so that the important relationships between
these parameters are preserved. More information on these parameters
can be found in Mitasova et al., 1995 or Thorpe, 1979.
@@ -223,7 +223,7 @@
</pre></div>
<h2>BUGS</h2>
-<b>devi</b> file is written as 2D and deviations are not written as attributes.
+<b>deviations</b> file is written as 2D and deviations are not written as attributes.
<h2>REFERENCES</h2>
<p>Hofierka J., Parajka J., Mitasova H., Mitas L., 2002, Multivariate
