[GRASS-SVN] r63252 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Nov 28 07:50:10 PST 2014
Author: martinl
Date: 2014-11-28 07:50:10 -0800 (Fri, 28 Nov 2014)
New Revision: 63252
grass/trunk/lib/gis/renamed_options
renamed_options: remove spaces on the end of line
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options 2014-11-28 15:46:08 UTC (rev 63251)
+++ grass/trunk/lib/gis/renamed_options 2014-11-28 15:50:10 UTC (rev 63252)
@@ -12,59 +12,59 @@
# d.barscale
d.barscale|background_color:bgcolor
# d.correlate
-d.correlate|layers:map
+d.correlate|layers:map
# d.erase
-d.erase|background:bgcolor
+d.erase|background:bgcolor
# d.legend
-d.legend|map:rast
+d.legend|map:rast
# d.rast
d.rast|catlist:values
d.rast|vallist:values
# d.rast.leg
-d.rast.leg|rast:raster
+d.rast.leg|rast:raster
# d.vect
d.vect|wcolumn:width_column
d.vect|wscale:width_scale
d.vect|rot_column:rotation_column
-d.vect|attrcolumn:attribute_column
+d.vect|attrcolumn:attribute_column
# d.colortable
-d.colortable|cols:columns
+d.colortable|cols:columns
# d.geodesic
d.geodesic|lcolor:line_color
-d.geodesic|tcolor:text_color
+d.geodesic|tcolor:text_color
# d.grid
d.grid|bordercolor:border_color
-d.grid|textcolor:text_color
+d.grid|textcolor:text_color
# d.polar
-d.polar|eps:output
+d.polar|eps:output
# d.profile
d.profile|input:map
-d.profile|profile:coordinates
+d.profile|profile:coordinates
# d.rast.arrow
d.rast.arrow|arrow_color:color
-d.rast.arrow|x_color:null_color
+d.rast.arrow|x_color:null_color
# d.rhumbline
d.rhumbline|coord:coordinates
-d.rhumbline|lcolor:line_color
+d.rhumbline|lcolor:line_color
# d.vect
d.vect|fcolor:fill_color
d.vect|llayer:label_layer
d.vect|lcolor:label_color
d.vect|bgcolor:label_bgcolor
d.vect|bcolor:label_boundary_color
-d.vect|lsize:label_size
+d.vect|lsize:label_size
# d.thematic.area
d.thematic.area|bcolor:boundary_color
-d.thematic.area|bwidth:boundary_width
+d.thematic.area|bwidth:boundary_width
# d.vect.chart
d.vect.chart|ctype:chart_type
d.vect.chart|ocolor:outline_color
-d.vect.chart|sizecol:size_column
+d.vect.chart|sizecol:size_column
### Database management module changes
# db.out.ogr
-db.out.ogr|db_table:table
+db.out.ogr|db_table:table
# db.select
db.select|vs:vertical_separator
@@ -75,9 +75,9 @@
g.mapsets|removemapset:operation
g.mapsets|measure:method
# g.pnmcomp
-g.pnmcomp|background:bgcolor
+g.pnmcomp|background:bgcolor
# g.mapset
-g.mapset|gisdbase:dbase
+g.mapset|gisdbase:dbase
### Image processing module changes
@@ -89,138 +89,138 @@
i.atcorr|icnd:parameters
i.atcorr|oimg:output
i.atcorr|oscl:rescale
-i.atcorr|input:map
+i.atcorr|input:map
# i.biomass
i.biomass|lightuseefficiency:lightuse_efficiency
i.biomass|transmissivitysingleway:transmissivity_singleway
-i.biomass|wateravailability:water_availability
+i.biomass|wateravailability:water_availability
# i.evapo.mh
i.evapo.mh|averagetemperature:average_temperature
i.evapo.mh|maximumtemperature:maximum_temperature
i.evapo.mh|minimumtemperature:minimum_temperature
-i.evapo.mh|netradiationdiurnal:netradiation_diurnal
+i.evapo.mh|netradiationdiurnal:netradiation_diurnal
# i.evapo.pt
i.evapo.pt|airtemperature:air_temperature
i.evapo.pt|atmosphericpressure:atmospheric_pressure
i.evapo.pt|netradiation:net_radiation
i.evapo.pt|soilheatflux:soil_heatflux
-i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
+i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
# i.image.mosaic
-i.image.mosaic|images:input
+i.image.mosaic|images:input
# i.in.spotvgt
i.in.spotvgt|file:input
-i.in.spotvgt|rast:output
+i.in.spotvgt|rast:output
# i.maxlik
i.maxlik|sigfile:signaturefile
-i.maxlik|class:output
+i.maxlik|class:output
# i.spectral
i.spectral|raster:input
i.spectral|coord:coordinates
# i.tasscap
-i.tasscap|outprefix:basename
+i.tasscap|outprefix:basename
# i.pansharpen
i.pansharpen|ms1:blue
i.pansharpen|ms2:green
i.pansharpen|ms3:red
i.pansharpen|output_prefix:output
-i.pansharpen|sharpen:method
+i.pansharpen|sharpen:method
# i.fft
i.fft|input_image:input
i.fft|real_image:real
-i.fft|imaginary_image:imaginary
+i.fft|imaginary_image:imaginary
# i.his.rgb
i.his.rgb|hue_input:hue
i.his.rgb|intensity_input:intensity
i.his.rgb|saturation_input:saturation
i.his.rgb|red_output:red
i.his.rgb|green_output:green
-i.his.rgb|blue_output:blue
+i.his.rgb|blue_output:blue
# i.fft
-i.fft|output_image:output
+i.fft|output_image:output
# i.landsat.acca
-i.landsat.acca|input_prefix:input
+i.landsat.acca|input_prefix:input
# i.landsat.toar
i.landsat.toar|input_prefix:input
-i.landsat.toar|output_prefix:output
+i.landsat.toar|output_prefix:output
# i.pca
-i.pca|output_prefix:output
+i.pca|output_prefix:output
# i.rectify
-i.rectify|res:resolution
+i.rectify|res:resolution
# i.rgb.his
i.rgb.his|red_input:red
i.rgb.his|green_input:green
i.rgb.his|blue_input:blue
i.rgb.his|hue_output:hue
i.rgb.his|intensity_output:intensity
-i.rgb.his|saturation_output:saturation
+i.rgb.his|saturation_output:saturation
# i.tasscap
-i.tasscap|sattelite:sensor
+i.tasscap|sattelite:sensor
# i.vi
i.vi|chan5:band5
-i.vi|chan7:band7
+i.vi|chan7:band7
### Raster module changes
# r.basins.fill
r.basins.fill|c_map:cnetwork
r.basins.fill|t_map:tnetwork
-r.basins.fill|result:output
+r.basins.fill|result:output
# r.blend
-r.blend|output:output_prefix
+r.blend|output:output_prefix
# r.colors.stddev
-r.colors.stddev|input:map
+r.colors.stddev|input:map
# r.cost
-r.cost|coordinate:start_coordinates
+r.cost|coordinate:start_coordinates
# r.distance
r.distance|maps:map
# r.drain
r.drain|voutput:vector_output
r.drain|coordinates:start_coordinates
-r.drain|vector_points:start_points
+r.drain|vector_points:start_points
# r.fill.dir
r.fill.dir|elevation:input
r.fill.dir|depressionless:output
r.fill.dir|outdir:direction
-r.fill.dir|type:format
+r.fill.dir|type:format
# r.flow
r.flow|elevin:elevation
r.flow|aspin:aspect
r.flow|barin:barrier
r.flow|flout:flowline
r.flow|lgout:flowpath
-r.flow|dsout:density
+r.flow|dsout:density
# r.horizon
r.horizon|elevin:elevation
-r.horizon|horizonstep:step
+r.horizon|horizonstep:step
# r.in.wms
-r.in.wms|mapserver:url
+r.in.wms|mapserver:url
# r.lake
r.lake|wl:water_level
-r.lake|xy:coordinates
+r.lake|xy:coordinates
# r.li.*
-r.li.cwed|map:input
-r.li.edgedensity|map:input
-r.li.mps|map:input
-r.li.padrange|map:input
-r.li.patchdensity|map:input
-r.li.pielou|map:input
-r.li.richness|map:input
-r.li.shape|map:input
-r.li.dominance|map:input
-r.li.mpa|map:input
-r.li.padcv|map:input
-r.li.padsd|map:input
-r.li.patchnum|map:input
-r.li.renyi|map:input
-r.li.shannon|map:input
-r.li.simpson|map:input
+r.li.cwed|map:input
+r.li.edgedensity|map:input
+r.li.mps|map:input
+r.li.padrange|map:input
+r.li.patchdensity|map:input
+r.li.pielou|map:input
+r.li.richness|map:input
+r.li.shape|map:input
+r.li.dominance|map:input
+r.li.mpa|map:input
+r.li.padcv|map:input
+r.li.padsd|map:input
+r.li.patchnum|map:input
+r.li.renyi|map:input
+r.li.shannon|map:input
+r.li.simpson|map:input
# r.plane
-r.plane|name:output
+r.plane|name:output
# r.resamp.bspline
r.resamp.bspline|se:ew_step
-r.resamp.bspline|sn:ns_step
+r.resamp.bspline|sn:ns_step
# r.sim.sediment
r.sim.sediment|elevin:elevation
r.sim.sediment|dxin:dx
@@ -229,7 +229,7 @@
r.sim.sediment|tranin:tran
r.sim.sediment|tauin:tau
r.sim.sediment|manin:man
-r.sim.sediment|maninval:man_value
+r.sim.sediment|maninval:man_value
# r.sim.water
r.sim.water|elevin:elevation
r.sim.water|dxin:dx
@@ -238,7 +238,7 @@
r.sim.water|infil:infil
r.sim.water|infil_val:infil_value
r.sim.water|manin:man
-r.sim.water|manin_val:man_value
+r.sim.water|manin_val:man_value
# r.sun
r.sun|elevin:elevation
r.sun|aspin:aspect
@@ -255,13 +255,13 @@
r.sun|declin:declination
r.sun|dist:distance_step
r.sun|numpartitions:num_partitions
-r.sun|civiltime:civil_time
+r.sun|civiltime:civil_time
# r.surf.area
r.surf.area|input:map
# r.texture
-r.texture|measure:method
+r.texture|measure:method
# r.to.vect
-r.to.vect|feature:type
+r.to.vect|feature:type
# r.topmodel
r.topmodel|elevation:
r.topmodel|basin:
@@ -273,59 +273,59 @@
r.topmodel|idxclass:topidxclass
r.topmodel|qobs:
# r.uslek
-r.uslek|usle_k:output
+r.uslek|usle_k:output
# r.walk
-r.walk|coordinate:start_coordinates
+r.walk|coordinate:start_coordinates
# r.water.outlet
r.water.outlet|drainage:input
-r.water.outlet|basin:output
+r.water.outlet|basin:output
# r.watershed
r.watershed|disturbed.land:disturbed_land
r.watershed|half.basin:half_basin
r.watershed|length.slope:length_slope
r.watershed|slope.steepness:slope_steepness
-r.watershed|max.slope.length:max_slope_length
+r.watershed|max.slope.length:max_slope_length
# r.what
r.what|east_north:coordinates
# r.rgb:
-r.rgb:|output_prefix:output
+r.rgb:|output_prefix:output
# r.blend
-r.blend|output_prefix:output
+r.blend|output_prefix:output
# r.category
r.category|vals:values
# r.circle
r.circle|coordinate:coordinates
-r.circle|mult:multiplier
+r.circle|mult:multiplier
# r.coin
r.coin|map1:first
-r.coin|map2:second
+r.coin|map2:second
# r.composite
r.composite|lev_red:level_red
r.composite|lev_green:level_green
-r.composite|lev_blue:level_blue
+r.composite|lev_blue:level_blue
# r.drain
r.drain|indir:direction
-r.drain|vector_output:drain
+r.drain|vector_output:drain
# r.fill.dir
-r.fill.dir|outdir:direction
+r.fill.dir|outdir:direction
# r.horizon
r.horizon|output:file
r.horizon|basename:output
-r.horizon|coordinate:coordinates
+r.horizon|coordinate:coordinates
# r.out.mpeg
-r.out.mpeg|qual:quality
+r.out.mpeg|qual:quality
# r.out.vrml
r.out.vrml|elev:elevation
-r.out.vrml|exag:exaggeration
+r.out.vrml|exag:exaggeration
# r.param.scale
r.param.scale|s_tol:slope_tol
r.param.scale|c_tol:curvature_tol
-r.param.scale|exp:exponent
+r.param.scale|exp:exponent
# r.random
r.random|raster_output:raster
-r.random|vector_output:vector
+r.random|vector_output:vector
# r.reclass.area
-r.reclass.area|lesser,greater:value, mode
+r.reclass.area|lesser,greater:value, mode
# r.report
r.report|pl:page_length
r.report|pw:page_width
@@ -335,18 +335,18 @@
r.resamp.rst|pcurv:pcurvature
r.resamp.rst|mcurv:mcurvature
r.resamp.rst|tcurv:trucravture
-r.resamp.rst|zmult:zscale
+r.resamp.rst|zmult:zscale
# r.slope.aspect
r.slope.aspect|pcurv:pcurvature
r.slope.aspect|tcurv:tcurvature
r.slope.aspect|zfactor:zscale
-r.slope.aspect|min_slp_allowed:min_slope
+r.slope.aspect|min_slp_allowed:min_slope
# r.spreadpath
-r.spreadpath|coordinate:coordinates
+r.spreadpath|coordinate:coordinates
# r.terraflow
-r.terraflow|stream_dir:directory
+r.terraflow|stream_dir:directory
# r.out.vtk
-r.out.vtk|elevscale:zscale
+r.out.vtk|elevscale:zscale
### Raster 3D module changes
@@ -356,7 +356,7 @@
r3.gwflow|r:recharge
r3.gwflow|vx:velocity_x
r3.gwflow|vy:velocity_y
-r3.gwflow|vz:velocity_z
+r3.gwflow|vz:velocity_z
# r3.out.ascii
r3.out.ascii|null:null_value
# r3.out.vtk
@@ -365,110 +365,110 @@
### Vector module changes
# v.clean
-v.clean|thresh:threshold
+v.clean|thresh:threshold
# v.drape
-v.drape|rast:elevation
+v.drape|rast:elevation
# v.edit
v.edit|measure:method
-v.edit|thresh:threshold
+v.edit|thresh:threshold
# v.extract
-v.extract|list:cats
+v.extract|list:cats
# v.in.e00
v.in.e00|file:input
-v.in.e00|vect:output
+v.in.e00|vect:output
# v.in.wfs
v.in.wfs|wfs:url
-v.in.wfs|input:map
+v.in.wfs|input:map
# v.lrs.create
-v.lrs.create|thresh:threshold
+v.lrs.create|thresh:threshold
# v.lrs.where
-v.lrs.where|thresh:threshold
+v.lrs.where|thresh:threshold
# v.mkgrid
-v.mkgrid|coor:coordinates
+v.mkgrid|coor:coordinates
# v.net
-v.net|thresh:threshold
+v.net|thresh:threshold
# v.outlier
v.outlier|soe:ew_step
-v.outlier|son:ns_step
+v.outlier|son:ns_step
# v.rast.stats
v.rast.stats|colprefix:column_prefix
-v.rast.stats|input:map
+v.rast.stats|input:map
# v.support
-v.support|thresh:threshold
+v.support|thresh:threshold
# v.surf.bspline
v.surf.bspline|sie:ew_step
-v.surf.bspline|sin:ns_step
+v.surf.bspline|sin:ns_step
# v.surf.rst
v.surf.rst|devi:deviations
v.surf.rst|maskmap:mask
v.surf.rst|treefile:treeseg
v.surf.rst|overfile:overwin
-v.surf.rst|elev:elevation
+v.surf.rst|elev:elevation
# v.what.vect
v.what.vect|vector:map
v.what.vect|qvector:query_map
v.what.vect|qlayer:query_layer
v.what.vect|qcolumn:query_column
# v.label
-v.label|background:bgcolor
+v.label|background:bgcolor
# v.lrs.label
-v.lrs.label|background:bgcolor
+v.lrs.label|background:bgcolor
# v.buffer
-v.buffer|bufcolumn:column
+v.buffer|bufcolumn:column
# v.db.join
v.db.join|otable:other_table
v.db.join|ocolumn:other_column
-v.db.join|scolumns:subset_columns
+v.db.join|scolumns:subset_columns
# v.db.select
-v.db.select|vs:vertical separator
+v.db.select|vs:vertical separator
# v.db.update
-v.db.update|qcolumn:query_column
+v.db.update|qcolumn:query_column
# v.extrude
-v.extrude|hcolumn:height_column
+v.extrude|hcolumn:height_column
# v.kcv
-v.kcv|k:npartitions
+v.kcv|k:npartitions
# v.kernel
-v.kernel|mult:multiplier
+v.kernel|mult:multiplier
# v.out.ogr
v.out.ogr|dsn:output
v.out.ogr|olayer:output_layer
-v.out.ogr|otype:output_type
+v.out.ogr|otype:output_type
# v.out.postgis
v.out.postgis|dsn:output
v.out.postgis|olayer:output_layer
-v.out.postgis|olink:output_link
+v.out.postgis|olink:output_link
# v.out.vtk
v.out.vtk|scale:zscale
# v.qcount
v.qcount|n:nquadrants
-v.qcount|r:radius
+v.qcount|r:radius
# v.sample
-v.sample|z:zscale
+v.sample|z:zscale
# v.segment
-v.segment|file:segments
+v.segment|file:segments
# v.surf.rst
v.surf.rst|pcurv:pcurvature
v.surf.rst|tcurv:tcurvature
v.surf.rst|mcurv:mcurvature
v.surf.rst|scolumn:smooth_column
-v.surf.rst|zmulti:zscale
+v.surf.rst|zmulti:zscale
# v.to.db
v.to.db|qlayer:query_layer
-v.to.db|qcolumn:query_column
+v.to.db|qcolumn:query_column
# v.to.points
-v.to.points|llayer:layer
+v.to.points|llayer:layer
# v.transform
v.transform|attrcolumn:attribute_column
v.transform|rgbcolumn:rgb_column
-v.transform|labelcolumn:label_column
+v.transform|labelcolumn:label_column
# v.transform
-v.transform|zrot:zrotation
+v.transform|zrot:zrotation
# v.vect.stats
v.vect.stats|player:points_layer
v.vect.stats|alayer:areas_layer
v.vect.stats|pcolumn:points_column
v.vect.stats|ccolumn:count_column
-v.vect.stats|scolumn:stats_column
+v.vect.stats|scolumn:stats_column
# v.vol.rst
v.vol.rst|cellinp:cross_input
v.vol.rst|devi:deviations
@@ -481,7 +481,7 @@
v.vol.rst|aspect2:aspect_vertical
v.vol.rst|ncurv:ncurvature
v.vol.rst|gcurv:gcurvature
-v.vol.rst|mcurv:mcurvature
+v.vol.rst|mcurv:mcurvature
# v.what.vect
v.what.vect|qmap:query_map
@@ -490,8 +490,8 @@
### Miscellaneous module changes
# m.measure
-m.measure|coords:coordinates
+m.measure|coords:coordinates
# m.cogo
-m.cogo|coords:coordinates
+m.cogo|coords:coordinates
# m.transform
m.transform|coords:input
