[GRASS-SVN] r63253 - grass/branches/releasebranch_7_0/lib/gis
Fri Nov 28 07:51:42 PST 2014
Author: martinl
Date: 2014-11-28 07:51:42 -0800 (Fri, 28 Nov 2014)
New Revision: 63253
   grass/branches/releasebranch_7_0/lib/gis/renamed_options
renamed_options: remove spaces on the end of line
Modified: grass/branches/releasebranch_7_0/lib/gis/renamed_options
--- grass/branches/releasebranch_7_0/lib/gis/renamed_options	2014-11-28 15:50:10 UTC (rev 63252)
+++ grass/branches/releasebranch_7_0/lib/gis/renamed_options	2014-11-28 15:51:42 UTC (rev 63253)
@@ -12,59 +12,59 @@
 # d.barscale
 d.barscale|background_color:bgcolor
 # d.correlate
-d.correlate|layers:map
+d.correlate|layers:map
 # d.erase
-d.erase|background:bgcolor
+d.erase|background:bgcolor
 # d.legend
-d.legend|map:rast
+d.legend|map:rast
 # d.rast
 d.rast|catlist:values
 d.rast|vallist:values
 # d.rast.leg
-d.rast.leg|rast:raster
+d.rast.leg|rast:raster
 # d.vect
 d.vect|wcolumn:width_column
 d.vect|wscale:width_scale
 d.vect|rot_column:rotation_column
-d.vect|attrcolumn:attribute_column
+d.vect|attrcolumn:attribute_column
 # d.colortable
-d.colortable|cols:columns
-# d.geodetic
-d.geodetic|lcolor:line_color
-d.geodetic|tcolor:text_color
+d.colortable|cols:columns
+# d.geodesic
+d.geodesic|lcolor:line_color
+d.geodesic|tcolor:text_color
 # d.grid
 d.grid|bordercolor:border_color
-d.grid|textcolor:text_color
+d.grid|textcolor:text_color
 # d.polar
-d.polar|eps:output
+d.polar|eps:output
 # d.profile
 d.profile|input:map
-d.profile|profile:coordinates
+d.profile|profile:coordinates
 # d.rast.arrow
 d.rast.arrow|arrow_color:color
-d.rast.arrow|x_color:null_color
+d.rast.arrow|x_color:null_color
 # d.rhumbline
 d.rhumbline|coord:coordinates
-d.rhumbline|lcolor:line_color
+d.rhumbline|lcolor:line_color
 # d.vect
 d.vect|fcolor:fill_color
 d.vect|llayer:label_layer
 d.vect|lcolor:label_color
 d.vect|bgcolor:label_bgcolor
 d.vect|bcolor:label_boundary_color
-d.vect|lsize:label_size
+d.vect|lsize:label_size
 # d.thematic.area
 d.thematic.area|bcolor:boundary_color
-d.thematic.area|bwidth:boundary_width
+d.thematic.area|bwidth:boundary_width
 # d.vect.chart
 d.vect.chart|ctype:chart_type
 d.vect.chart|ocolor:outline_color
-d.vect.chart|sizecol:size_column
+d.vect.chart|sizecol:size_column
 ### Database management module changes
 # db.out.ogr
-db.out.ogr|db_table:table
+db.out.ogr|db_table:table
 # db.select
 db.select|vs:vertical_separator
@@ -75,9 +75,9 @@
 g.mapsets|removemapset:operation
 g.mapsets|measure:method
 # g.pnmcomp
-g.pnmcomp|background:bgcolor
+g.pnmcomp|background:bgcolor
 # g.mapset
-g.mapset|gisdbase:dbase
+g.mapset|gisdbase:dbase
 ### Image processing module changes
@@ -89,125 +89,138 @@
 i.atcorr|icnd:parameters
 i.atcorr|oimg:output
 i.atcorr|oscl:rescale
-i.atcorr|input:map
+i.atcorr|input:map
 # i.biomass
 i.biomass|lightuseefficiency:lightuse_efficiency
 i.biomass|transmissivitysingleway:transmissivity_singleway
-i.biomass|wateravailability:water_availability
+i.biomass|wateravailability:water_availability
 # i.evapo.mh
 i.evapo.mh|averagetemperature:average_temperature
 i.evapo.mh|maximumtemperature:maximum_temperature
 i.evapo.mh|minimumtemperature:minimum_temperature
-i.evapo.mh|netradiationdiurnal:netradiation_diurnal
+i.evapo.mh|netradiationdiurnal:netradiation_diurnal
 # i.evapo.pt
 i.evapo.pt|airtemperature:air_temperature
 i.evapo.pt|atmosphericpressure:atmospheric_pressure
 i.evapo.pt|netradiation:net_radiation
 i.evapo.pt|soilheatflux:soil_heatflux
-i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
+i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
 # i.image.mosaic
-i.image.mosaic|images:input
+i.image.mosaic|images:input
 # i.in.spotvgt
 i.in.spotvgt|file:input
-i.in.spotvgt|rast:output
+i.in.spotvgt|rast:output
 # i.maxlik
 i.maxlik|sigfile:signaturefile
-i.maxlik|class:output
+i.maxlik|class:output
 # i.spectral
 i.spectral|raster:input
 i.spectral|coord:coordinates
 # i.tasscap
-i.tasscap|outprefix:basename
+i.tasscap|outprefix:basename
 # i.pansharpen
 i.pansharpen|ms1:blue
 i.pansharpen|ms2:green
 i.pansharpen|ms3:red
 i.pansharpen|output_prefix:output
-i.pansharpen|sharpen:method
+i.pansharpen|sharpen:method
 # i.fft
 i.fft|input_image:input
 i.fft|real_image:real
-i.fft|imaginary_image:imaginary
+i.fft|imaginary_image:imaginary
 # i.his.rgb
 i.his.rgb|hue_input:hue
 i.his.rgb|intensity_input:intensity
 i.his.rgb|saturation_input:saturation
 i.his.rgb|red_output:red
 i.his.rgb|green_output:green
-i.his.rgb|blue_output:blue
+i.his.rgb|blue_output:blue
 # i.fft
-i.fft|output_image:output
+i.fft|output_image:output
 # i.landsat.acca
-i.landsat.acca|input_prefix:input
+i.landsat.acca|input_prefix:input
 # i.landsat.toar
 i.landsat.toar|input_prefix:input
-i.landsat.toar|output_prefix:output
+i.landsat.toar|output_prefix:output
 # i.pca
-i.pca|output_prefix:output
+i.pca|output_prefix:output
 # i.rectify
-i.rectify|res:resolution
+i.rectify|res:resolution
 # i.rgb.his
 i.rgb.his|red_input:red
 i.rgb.his|green_input:green
 i.rgb.his|blue_input:blue
 i.rgb.his|hue_output:hue
 i.rgb.his|intensity_output:intensity
-i.rgb.his|saturation_output:saturation
+i.rgb.his|saturation_output:saturation
 # i.tasscap
-i.tasscap|sattelite:sensor
+i.tasscap|sattelite:sensor
 # i.vi
 i.vi|chan5:band5
-i.vi|chan7:band7
+i.vi|chan7:band7
 ### Raster module changes
 # r.basins.fill
 r.basins.fill|c_map:cnetwork
 r.basins.fill|t_map:tnetwork
-r.basins.fill|result:output
+r.basins.fill|result:output
 # r.blend
-r.blend|output:output_prefix
+r.blend|output:output_prefix
 # r.colors.stddev
-r.colors.stddev|input:map
+r.colors.stddev|input:map
 # r.cost
-r.cost|coordinate:start_coordinates
+r.cost|coordinate:start_coordinates
 # r.distance
 r.distance|maps:map
 # r.drain
 r.drain|voutput:vector_output
 r.drain|coordinates:start_coordinates
-r.drain|vector_points:start_points
+r.drain|vector_points:start_points
 # r.fill.dir
 r.fill.dir|elevation:input
 r.fill.dir|depressionless:output
 r.fill.dir|outdir:direction
-r.fill.dir|type:format
+r.fill.dir|type:format
 # r.flow
 r.flow|elevin:elevation
 r.flow|aspin:aspect
 r.flow|barin:barrier
 r.flow|flout:flowline
 r.flow|lgout:flowpath
-r.flow|dsout:density
+r.flow|dsout:density
 # r.horizon
 r.horizon|elevin:elevation
-r.horizon|horizonstep:step
+r.horizon|horizonstep:step
 # r.in.wms
-r.in.wms|mapserver:url
+r.in.wms|mapserver:url
 # r.lake
 r.lake|wl:water_level
-r.lake|xy:coordinates
+r.lake|xy:coordinates
 # r.li.*
-r.li.*|map:input
-# r.los
-r.los|coodinate:coordinates
+r.li.cwed|map:input
+r.li.edgedensity|map:input
+r.li.mps|map:input
+r.li.padrange|map:input
+r.li.patchdensity|map:input
+r.li.pielou|map:input
+r.li.richness|map:input
+r.li.shape|map:input
+r.li.dominance|map:input
+r.li.mpa|map:input
+r.li.padcv|map:input
+r.li.padsd|map:input
+r.li.patchnum|map:input
+r.li.renyi|map:input
+r.li.shannon|map:input
+r.li.simpson|map:input
 # r.plane
-r.plane|name:output
+r.plane|name:output
 # r.resamp.bspline
 r.resamp.bspline|se:ew_step
-r.resamp.bspline|sn:ns_step
+r.resamp.bspline|sn:ns_step
 # r.sim.sediment
 r.sim.sediment|elevin:elevation
 r.sim.sediment|dxin:dx
@@ -216,7 +229,7 @@
 r.sim.sediment|tranin:tran
 r.sim.sediment|tauin:tau
 r.sim.sediment|manin:man
-r.sim.sediment|maninval:man_value
+r.sim.sediment|maninval:man_value
 # r.sim.water
 r.sim.water|elevin:elevation
 r.sim.water|dxin:dx
@@ -225,7 +238,7 @@
 r.sim.water|infil:infil
 r.sim.water|infil_val:infil_value
 r.sim.water|manin:man
-r.sim.water|manin_val:man_value
+r.sim.water|manin_val:man_value
 # r.sun
 r.sun|elevin:elevation
 r.sun|aspin:aspect
@@ -242,13 +255,13 @@
 r.sun|declin:declination
 r.sun|dist:distance_step
 r.sun|numpartitions:num_partitions
-r.sun|civiltime:civil_time
+r.sun|civiltime:civil_time
 # r.surf.area
 r.surf.area|input:map
 # r.texture
-r.texture|measure:method
+r.texture|measure:method
 # r.to.vect
-r.to.vect|feature:type
+r.to.vect|feature:type
 # r.topmodel
 r.topmodel|elevation:
 r.topmodel|basin:
@@ -260,59 +273,59 @@
 r.topmodel|idxclass:topidxclass
 r.topmodel|qobs:
 # r.uslek
-r.uslek|usle_k:output
+r.uslek|usle_k:output
 # r.walk
-r.walk|coordinate:start_coordinates
+r.walk|coordinate:start_coordinates
 # r.water.outlet
 r.water.outlet|drainage:input
-r.water.outlet|basin:output
+r.water.outlet|basin:output
 # r.watershed
 r.watershed|disturbed.land:disturbed_land
 r.watershed|half.basin:half_basin
 r.watershed|length.slope:length_slope
 r.watershed|slope.steepness:slope_steepness
-r.watershed|max.slope.length:max_slope_length
+r.watershed|max.slope.length:max_slope_length
 # r.what
 r.what|east_north:coordinates
 # r.rgb:
-r.rgb:|output_prefix:output
+r.rgb:|output_prefix:output
 # r.blend
-r.blend|output_prefix:output
+r.blend|output_prefix:output
 # r.category
 r.category|vals:values
 # r.circle
 r.circle|coordinate:coordinates
-r.circle|mult:multiplier
+r.circle|mult:multiplier
 # r.coin
 r.coin|map1:first
-r.coin|map2:second
+r.coin|map2:second
 # r.composite
 r.composite|lev_red:level_red
 r.composite|lev_green:level_green
-r.composite|lev_blue:level_blue
+r.composite|lev_blue:level_blue
 # r.drain
 r.drain|indir:direction
-r.drain|vector_output:drain
+r.drain|vector_output:drain
 # r.fill.dir
-r.fill.dir|outdir:direction
+r.fill.dir|outdir:direction
 # r.horizon
 r.horizon|output:file
 r.horizon|basename:output
-r.horizon|coordinate:coordinates
+r.horizon|coordinate:coordinates
 # r.out.mpeg
-r.out.mpeg|qual:quality
+r.out.mpeg|qual:quality
 # r.out.vrml
 r.out.vrml|elev:elevation
-r.out.vrml|exag:exaggeration
+r.out.vrml|exag:exaggeration
 # r.param.scale
 r.param.scale|s_tol:slope_tol
 r.param.scale|c_tol:curvature_tol
-r.param.scale|exp:exponent
+r.param.scale|exp:exponent
 # r.random
 r.random|raster_output:raster
-r.random|vector_output:vector
+r.random|vector_output:vector
 # r.reclass.area
-r.reclass.area|lesser,greater:value, mode
+r.reclass.area|lesser,greater:value, mode
 # r.report
 r.report|pl:page_length
 r.report|pw:page_width
@@ -322,18 +335,18 @@
 r.resamp.rst|pcurv:pcurvature
 r.resamp.rst|mcurv:mcurvature
 r.resamp.rst|tcurv:trucravture
-r.resamp.rst|zmult:zscale
+r.resamp.rst|zmult:zscale
 # r.slope.aspect
 r.slope.aspect|pcurv:pcurvature
 r.slope.aspect|tcurv:tcurvature
 r.slope.aspect|zfactor:zscale
-r.slope.aspect|min_slp_allowed:min_slope
+r.slope.aspect|min_slp_allowed:min_slope
 # r.spreadpath
-r.spreadpath|coordinate:coordinates
+r.spreadpath|coordinate:coordinates
 # r.terraflow
-r.terraflow|stream_dir:directory
+r.terraflow|stream_dir:directory
 # r.out.vtk
-r.out.vtk|elevscale:zscale
+r.out.vtk|elevscale:zscale
 ### Raster 3D module changes
@@ -343,7 +356,7 @@
 r3.gwflow|r:recharge
 r3.gwflow|vx:velocity_x
 r3.gwflow|vy:velocity_y
-r3.gwflow|vz:velocity_z
+r3.gwflow|vz:velocity_z
 # r3.out.ascii
 r3.out.ascii|null:null_value
 # r3.out.vtk
@@ -352,113 +365,110 @@
 ### Vector module changes
 # v.clean
-v.clean|thresh:threshold
+v.clean|thresh:threshold
 # v.drape
-v.drape|rast:elevation
+v.drape|rast:elevation
 # v.edit
 v.edit|measure:method
-v.edit|thresh:threshold
+v.edit|thresh:threshold
 # v.extract
-v.extract|list:cats
+v.extract|list:cats
 # v.in.e00
 v.in.e00|file:input
-v.in.e00|vect:output
-# v.in.gns
-v.in.gns|file:input
-v.in.gns|vect:output
+v.in.e00|vect:output
 # v.in.wfs
 v.in.wfs|wfs:url
-v.in.wfs|input:map
+v.in.wfs|input:map
 # v.lrs.create
-v.lrs.create|thresh:threshold
+v.lrs.create|thresh:threshold
 # v.lrs.where
-v.lrs.where|thresh:threshold
+v.lrs.where|thresh:threshold
 # v.mkgrid
-v.mkgrid|coor:coordinates
+v.mkgrid|coor:coordinates
 # v.net
-v.net|thresh:threshold
+v.net|thresh:threshold
 # v.outlier
 v.outlier|soe:ew_step
-v.outlier|son:ns_step
+v.outlier|son:ns_step
 # v.rast.stats
 v.rast.stats|colprefix:column_prefix
-v.rast.stats|input:map
+v.rast.stats|input:map
 # v.support
-v.support|thresh:threshold
+v.support|thresh:threshold
 # v.surf.bspline
 v.surf.bspline|sie:ew_step
-v.surf.bspline|sin:ns_step
+v.surf.bspline|sin:ns_step
 # v.surf.rst
 v.surf.rst|devi:deviations
 v.surf.rst|maskmap:mask
 v.surf.rst|treefile:treeseg
 v.surf.rst|overfile:overwin
-v.surf.rst|elev:elevation
+v.surf.rst|elev:elevation
 # v.what.vect
 v.what.vect|vector:map
 v.what.vect|qvector:query_map
 v.what.vect|qlayer:query_layer
 v.what.vect|qcolumn:query_column
 # v.label
-v.label|background:bgcolor
+v.label|background:bgcolor
 # v.lrs.label
-v.lrs.label|background:bgcolor
+v.lrs.label|background:bgcolor
 # v.buffer
-v.buffer|bufcolumn:column
+v.buffer|bufcolumn:column
 # v.db.join
 v.db.join|otable:other_table
 v.db.join|ocolumn:other_column
-v.db.join|scolumns:subset_columns
+v.db.join|scolumns:subset_columns
 # v.db.select
-v.db.select|vs:vertical separator
+v.db.select|vs:vertical separator
 # v.db.update
-v.db.update|qcolumn:query_column
+v.db.update|qcolumn:query_column
 # v.extrude
-v.extrude|hcolumn:height_column
+v.extrude|hcolumn:height_column
 # v.kcv
-v.kcv|k:npartitions
+v.kcv|k:npartitions
 # v.kernel
-v.kernel|mult:multiplier
+v.kernel|mult:multiplier
 # v.out.ogr
 v.out.ogr|dsn:output
 v.out.ogr|olayer:output_layer
-v.out.ogr|otype:output_type
+v.out.ogr|otype:output_type
 # v.out.postgis
 v.out.postgis|dsn:output
 v.out.postgis|olayer:output_layer
-v.out.postgis|olink:output_link
+v.out.postgis|olink:output_link
 # v.out.vtk
 v.out.vtk|scale:zscale
 # v.qcount
 v.qcount|n:nquadrants
-v.qcount|r:radius
+v.qcount|r:radius
 # v.sample
-v.sample|z:zscale
-# v.segments
-v.segments|file:segments
+v.sample|z:zscale
+# v.segment
+v.segment|file:segments
 # v.surf.rst
 v.surf.rst|pcurv:pcurvature
 v.surf.rst|tcurv:tcurvature
 v.surf.rst|mcurv:mcurvature
 v.surf.rst|scolumn:smooth_column
-v.surf.rst|zmulti:zscale
+v.surf.rst|zmulti:zscale
 # v.to.db
 v.to.db|qlayer:query_layer
-v.to.db|qcolumn:query_column
+v.to.db|qcolumn:query_column
 # v.to.points
-v.to.points|llayer:layer
+v.to.points|llayer:layer
 # v.transform
 v.transform|attrcolumn:attribute_column
 v.transform|rgbcolumn:rgb_column
-v.transform|labelcolumn:label_column
+v.transform|labelcolumn:label_column
 # v.transform
-v.transform|zrot:zrotation
+v.transform|zrot:zrotation
 # v.vect.stats
 v.vect.stats|player:points_layer
 v.vect.stats|alayer:areas_layer
 v.vect.stats|pcolumn:points_column
 v.vect.stats|ccolumn:count_column
-v.vect.stats|scolumn:stats_column
+v.vect.stats|scolumn:stats_column
 # v.vol.rst
 v.vol.rst|cellinp:cross_input
 v.vol.rst|devi:deviations
@@ -471,7 +481,7 @@
 v.vol.rst|aspect2:aspect_vertical
 v.vol.rst|ncurv:ncurvature
 v.vol.rst|gcurv:gcurvature
-v.vol.rst|mcurv:mcurvature
+v.vol.rst|mcurv:mcurvature
 # v.what.vect
 v.what.vect|qmap:query_map
@@ -480,8 +490,8 @@
 ### Miscellaneous module changes
 # m.measure
-m.measure|coords:coordinates
+m.measure|coords:coordinates
 # m.cogo
-m.cogo|coords:coordinates
+m.cogo|coords:coordinates
 # m.transform
 m.transform|coords:input
