[GRASS-SVN] r63279 - grass/trunk/raster/r.viewshed
svn_grass at osgeo.org
Fri Nov 28 19:08:02 PST 2014
Author: annakrat
Date: 2014-11-28 19:08:02 -0800 (Fri, 28 Nov 2014)
New Revision: 63279
grass/trunk/raster/r.viewshed/r.viewshed.html
r.viewshed: update manual
Modified: grass/trunk/raster/r.viewshed/r.viewshed.html
--- grass/trunk/raster/r.viewshed/r.viewshed.html 2014-11-29 03:03:22 UTC (rev 63278)
+++ grass/trunk/raster/r.viewshed/r.viewshed.html 2014-11-29 03:08:02 UTC (rev 63279)
@@ -68,19 +68,19 @@
<p>
By default the observer is assumed to have height 1.75 map units above
the terrain. The user can change this using option
-<b>obs_elev</b>. The value entered is in the same units as the
+<b>observer_elevation</b>. The value entered is in the same units as the
elevation.
<p>
By default the target is assumed to have height of 0 map units above the
-<b>tgt_elev</b> to determine if objects of a given height would be
+<b>target_elevation</b> to determine if objects of a given height would be
visible. The value entered is in the same units as the elevation.
<p>
By default there is no restriction on the maximum distance to which
the observer can see. The user can set a maximum distance of
-visibility using option <b>max_dist</b>. The value entered is in the
+visibility using option <b>max_distance</b>. The value entered is in the
same units as the cell size of the raster.
<p>
@@ -180,7 +180,7 @@
<div class="code"><pre>
g.region rast=elev_lid792_1m -p
r.viewshed input=elev_lid792_1m output=elev_lid792_1m_viewshed \
- coordinates=638728.087167,220609.261501 obs_elev=5.0
+ coordinates=638728.087167,220609.261501 observer_elevation=5.0
</pre></div>
<div align="center" style="margin: 10px">
