[GRASS-SVN] r63280 - in grass/branches/releasebranch_7_0: . raster/r.viewshed
Fri Nov 28 19:08:54 PST 2014
Author: annakrat
Date: 2014-11-28 19:08:53 -0800 (Fri, 28 Nov 2014)
New Revision: 63280
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
r.viewshed: update manual (merge from trunk, r63279)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279
Modified: grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
--- grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html	2014-11-29 03:08:02 UTC (rev 63279)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html	2014-11-29 03:08:53 UTC (rev 63280)
@@ -68,19 +68,19 @@
 <p>
 By default the observer is assumed to have height 1.75 map units above
 the terrain.  The user can change this using option
-<b>obs_elev</b>. The value entered is in the same units as the
+<b>observer_elevation</b>. The value entered is in the same units as the
 elevation.
 <p>
 By default the target is assumed to have height of 0 map units above the
-<b>tgt_elev</b> to determine if objects of a given height would be
+<b>target_elevation</b> to determine if objects of a given height would be
 visible. The value entered is in the same units as the elevation.
 <p>
 By default there is no restriction on the maximum distance to which
 the observer can see.  The user can set a maximum distance of
-visibility using option <b>max_dist</b>.  The value entered is in the
+visibility using option <b>max_distance</b>.  The value entered is in the
 same units as the cell size of the raster.
 <p>
@@ -180,7 +180,7 @@
 <div class="code"><pre>
 g.region rast=elev_lid792_1m -p
 r.viewshed input=elev_lid792_1m output=elev_lid792_1m_viewshed \
-  coordinates=638728.087167,220609.261501 obs_elev=5.0
+  coordinates=638728.087167,220609.261501 observer_elevation=5.0
 </pre></div>
 <div align="center" style="margin: 10px">
