[GRASS-SVN] r63296 - in grass-addons/grass7/raster: . r.futures
Sat Nov 29 21:05:19 PST 2014
Author: wenzeslaus
Date: 2014-11-29 21:05:19 -0800 (Sat, 29 Nov 2014)
New Revision: 63296
Added:
   grass-addons/grass7/raster/r.futures/
   grass-addons/grass7/raster/r.futures/Makefile
   grass-addons/grass7/raster/r.futures/main.cpp
   grass-addons/grass7/raster/r.futures/r.futures.html
   grass-addons/grass7/raster/r.futures/r_futures.png
   grass-addons/grass7/raster/r.futures/r_futures_detail.png
   grass-addons/grass7/raster/Makefile
r.futures: port of Meentemeyer et al. FUTURES model to GRASS GIS
Authors: Meentemeyer, R. K., Tang, W., Dorning, M. A, Vogler, J. B., Cunniffe, N. J., Shoemaker D. A., Koch J., Petras V. (see manual page for details)
Main differences to the original standalone version:
 * input and output rasters are GRASS rasters
 * color table and basic history for rasters
 * NULLs on input and output are handled using GRASS (original method used internally)
 * key-value parameters handled using GRASS parser (text files with values remain)
 * random number generator seed generated by GRASS
 * requires a lot of memory but memory handling itself was fixed
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2014-11-30 00:10:38 UTC (rev 63295)
+++ grass-addons/grass7/raster/Makefile	2014-11-30 05:05:19 UTC (rev 63296)
@@ -27,6 +27,7 @@
 	r.findtheriver \
 	r.flip \
 	r.forestfrag \
+	r.futures \
 	r.fuzzy.set \
 	r.fuzzy.logic \
 	r.fuzzy.system \
Added: grass-addons/grass7/raster/r.futures/Makefile
--- grass-addons/grass7/raster/r.futures/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.futures/Makefile	2014-11-30 05:05:19 UTC (rev 63296)
@@ -0,0 +1,16 @@
+MODULE_TOPDIR = ../..
+PGM = r.futures
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+EXTRA_CFLAGS = -Wall
+LINK = $(CXX)
+ifneq ($(strip $(CXX)),)
+default: cmd
+endif
Property changes on: grass-addons/grass7/raster/r.futures/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.futures/main.cpp
--- grass-addons/grass7/raster/r.futures/main.cpp	                        (rev 0)
+++ grass-addons/grass7/raster/r.futures/main.cpp	2014-11-30 05:05:19 UTC (rev 63296)
@@ -0,0 +1,2754 @@
+ * MODULE:       r.futures
+ * AUTHOR(S):    Ross K. Meentemeyer
+ *               Wenwu Tang
+ *               Monica A. Dorning
+ *               John B. Vogler
+ *               Nik J. Cunniffe
+ *               Douglas A. Shoemaker
+ *               Jennifer A. Koch
+ *               Vaclav Petras <wenzeslaus gmail com>
+ *               (See the manual page for details and references.)
+ * PURPOSE:      Simulation of urban-rural landscape structure (FUTURES model)
+ * COPYRIGHT:    (C) 2013-2014 by Meentemeyer et al.
+ *               This program is free software: you can redistribute it and/or
+ *               modify it under the terms of the GNU General Public License
+ *               as published by the Free Software Foundation, either version 3
+ *               of the License, or (at your option) any later version.
+ *               This program is distributed in the hope that it will be useful,
+ *               but WITHOUT ANY WARRANTY; without even the implied warranty of
+ *               MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ *               GNU General Public License for more details.
+ *               You should have received a copy of the GNU General Public
+ *               License along with this program. If not, see
+ *               <http://www.gnu.org/licenses/> or read the file COPYING that
+ *               comes with GRASS GIS for details.
+    \file main.c
+    The main file containing both the model code and the data handing part.
+    A lot of parts of the code are dead code. May be useful as an alternative
+    algorithms. Some of the dead code is commented out and might need to
+    be revived if other parts will show as useful.
+    The language of the code is subject to change. The goal is to use either
+    C or C++, not both mixed as it is now.
+    Major refactoring of the code is expected.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <sys/time.h>
+#include <iostream>
+#include <fstream>
+#include <vector>
+extern "C"
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+//#include "distance.h"
+/** used to flag cells that are off the lattice */
+#define _CELL_OUT_OF_RANGE -2
+/** used to flag cells that are not in this county */
+#define _CELL_OUT_OF_COUNTY -1
+/** used to flag cells that are valid */
+#define _CELL_VALID 1
+/** need to dynamically allocate this as putting all on stack will crash most compilers */
+#define _N_MAX_DYNAMIC_BUFF_LEN (1024*1024)
+#define _N_MAX_FILENAME_LEN 1024
+/** Max length of input line */
+#define N_MAXREADINLEN 8192
+/** for working out where to start reading data */
+#define _GIS_HEADER_LENGTH 6
+/** strictly-speaking, should probably parse these from GIS files */
+#define _GIS_NO_DATA_STRING "-9999"
+/** Value used to represent NULL (NoData) in some parts of the model */
+#define _GIS_NO_DATA_INT -9999
+/** use this for tDeveloped if cell still undeveloped */
+#define _N_NOT_YET_DEVELOPED -1
+/* algorithm to use */
+/** deterministic model */
+#define _N_ALGORITHM_DETERMINISTIC 1
+/** stochastic model with downweighting of logit probabilities and of devPressure over time */
+#define _N_ALGORITHM_STOCHASTIC_I 2
+#define _N_ALGORITHM_STOCHASTIC_II 3
+#define _MAX_RAND_FIND_SEED_FACTOR 25
+#define maxNumAddVariables 6
+/** maximal number of counties allowed */
+#define MAXNUM_COUNTY 50
+#define MAX_YEARS 100
+/// maximum array size for undev cells (maximum: 1840198 for a county within 16 counties)
+#define MAX_UNDEV_SIZE 2000000
+using namespace std;
+/* Wenwu Tang */
+/// use absolute paths
+char dirName[100];
+/// string for temporarily storage
+char tempStr[100];
+typedef struct
+    /** see #define's starting _CELL_ above */
+    int nCellType;
+    /** attraction to employment base; static */
+    double employAttraction;
+    /** distance to interchange; static */
+    double interchangeDistance;
+    /** road density; static */
+    double roadDensity;
+    /** x position on the lattice; static */
+    int thisX;
+    /** y position on the lattice; static */
+    int thisY;
+    /** whether this site is still undeveloped; varies.  Note if bUndeveloped = 0 the values of employAttraction etc. are not to be trusted */
+    int bUndeveloped;
+    // TODO: is the following int or double (defined as double but usually casting to int in assignment, was as int in some print)
+    /** development pressure; varies */
+    double devPressure;
+    /** stores whether this site has been considered for development, to handle "protection" */
+    int bUntouched;
+    /** timestep on which developed (0 for developed at start, _N_NOT_YET_DEVELOPED for not developed yet ) */
+    int tDeveloped;
+    /** multiplicative factor on the probabilities */
+    double consWeight;
+    /** additional variables */
+    double additionVariable[maxNumAddVariables];
+    int index_region;
+    float devProba;
+} t_Cell;
+typedef struct
+    /** id of this cell */
+    int cellID;
+    /** value of the logit */
+    double logitVal;
+    /** whether or not cell previously considered...need to use this in the sort */
+    int bUntouched;
+    /** to support random pick based on their logitVal */
+    double cumulProb;
+} t_Undev;
+typedef struct
+    /** array of cells (see posFromXY for how they are indexed) */
+    t_Cell *asCells;
+    /** number of columns in the grid */
+    int maxX;
+    /** number of rows in the grid */
+    int maxY;
+    /** total number of cells */
+    int totalCells;
+    /** array of information on undeveloped cells */
+    t_Undev *asUndev;
+    /** number of cells which have not yet converted */
+    int undevSites;
+    /** posterior sample from parcel size distribution */
+    int *aParcelSizes;
+    /** number in that sample */
+    int parcelSizes;
+      std::vector < std::vector < t_Undev > >asUndevs;  //WT
+    int num_undevSites[MAXNUM_COUNTY];  //WT
+} t_Landscape;
+typedef struct
+    /** size of the grids */
+    int xSize;
+    int ySize;
+    /** file containing information on how many cells to transition and when */
+    char *controlFile;
+    /** files containing the information to read in */
+    char *employAttractionFile;
+    char *interchangeDistanceFile;
+    char *roadDensityFile;
+    char *undevelopedFile;
+    char *devPressureFile;
+    char *consWeightFile;
+    char *probLookupFile;
+    int nProbLookup;
+    double *adProbLookup;
+    // parameters provided in other ways
+    //      /* parameters that go into regression formula */
+    //      double          dIntercept;        /* 0.038884 */
+    //      double          dEmployAttraction;                                                              /* -0.0000091946 */
+    //      double          dInterchangeDistance;                                                   /* 0.000042021 */
+    //      double          dRoadDensity;        /* 0.00065813 */
+    //      double          dDevPressure;        /* -0.026190 */
+    /* size of square used to recalculate development pressure */
+    int nDevNeighbourhood;  /** 8 (i.e. 8 in each direction, leading to 17 x 17 = 289 in total) */
+    /** used in writing rasters */
+    char *dumpFile;
+    char *outputSeries;
+    /** 1 deterministic, 2 old stochastic, 3 new stochastic */
+    int nAlgorithm;
+    /** use this to downweight probabilities */
+    double dProbWeight;
+    /** and this to downweight old dev pressure */
+    double dDevPersistence;
+    /** file containing parcel size information */
+    char *parcelSizeFile;
+    double discountFactor;      ///< for calibrate patch size
+    /** give up spiralling around when examined this number of times too many cells */
+    double giveUpRatio;
+    /** these parameters only relevant for new stochastic algorithm */
+    int sortProbs;
+    double patchFactor;
+    double patchMean;
+    double patchRange;
+    /// 4 or 8 neighbors only
+    int numNeighbors;
+    /// 1: uniform distribution 2: based on dev. proba.
+    int seedSearch;
+    int numAddVariables;
+    /** parameters for additional variables */
+    double addParameters[maxNumAddVariables][MAXNUM_COUNTY];
+    char *addVariableFile[maxNumAddVariables];
+    /// 1: #occurrence; 2: gravity (need to define alpha and scaling factor); 3: kernel, need to define alpha and scaling factor
+    /// for 2: formula-> scalingFactor/power(dist,alpha)
+    /// for 3: formula-> scalingFactor*exp(-2*dist/alpha)
+    int devPressureApproach;
+    /// scale distance-based force
+    double scalingFactor;
+    ///< constraint on distance
+    double alpha;
+    /** parameters that go into regression formula */
+    double dIntercepts[MAXNUM_COUNTY];
+    double dV1[MAXNUM_COUNTY];
+    double dV2[MAXNUM_COUNTY];
+    double dV3[MAXNUM_COUNTY];
+    double dV4[MAXNUM_COUNTY];
+    int num_Regions;
+    /** index file to run multiple regions */
+    char *indexFile;
+    /// control files for all regions
+    /// development demand for multiple regions
+    char *controlFileAll;
+    int devDemand[MAX_YEARS];
+    int devDemands[MAXNUM_COUNTY][MAX_YEARS];
+    /// number of simulation steps
+    int nSteps;
+} t_Params;
+//From WT: move here to be global variables
+t_Params sParams;
+t_Landscape sLandscape;
+int getUnDevIndex(t_Landscape * pLandscape);
+void Shuffle4(int *mat);
+double getDistance1(double x1, double y1, double x2, double y2);
+void readDevPotParams(t_Params * pParams, char *fn);
+void readIndexData(t_Landscape * pLandscape, t_Params * pParams);
+void findAndSortProbsAll(t_Landscape * pLandscape, t_Params * pParams,
+                         int step);
+void updateMap1(t_Landscape * pLandscape, t_Params * pParams, int step,
+                int regionID);
+int getUnDevIndex1(t_Landscape * pLandscape, int regionID);
+    char str[200];
+    int id;
+    double di, d1, d2, d3, d4, val;
+    // TODO: d5 is in file but unused
+    int i, j;
+    ifstream f;
+    f.open(fn);
+    if (!f.is_open())
+        G_fatal_error(_("Cannot open development potential parameters file <%s>"),
+                      fn);
+    f.getline(str, 200);
+    for (i = 0; i < pParams->num_Regions; i++) {
+        // TODO: read by lines to count the variables
+        f >> id >> di >> d1 >> d2 >> d3 >> d4;
+        cout << id << "\t" << di << "\t" << d1 << "\t" << d2 << "\t" << d3 <<
+            "\t" << d4;
+        pParams->dIntercepts[i] = di;
+        pParams->dV1[i] = d1;
+        pParams->dV2[i] = d2;
+        pParams->dV3[i] = d3;
+        pParams->dV4[i] = d4;
+        for (j = 0; j < pParams->numAddVariables; j++) {
+            f >> val;
+            cout << "\t" << val;
+            pParams->addParameters[j][i] = val;
+        cout << endl;
+    f.close();
+    Generate uniform number on [0,1).
+    Encapsulated to allow easy replacement if necessary.
+double uniformRandom()
+    int nRet;
+    nRet = RAND_MAX;
+    while (nRet == RAND_MAX) {  /* make sure never get 1.0 */
+        nRet = rand();
+    return ((double)nRet / (double)(RAND_MAX));
+    Seed random number generator.
+void seedRandom(struct timeval ttime)
+    srand((ttime.tv_sec * 100) + (ttime.tv_usec / 100));
+    //srand((unsigned int)time(NULL));
+    Work out x and y position on the grid from index into siteMapping/landscape array.
+void xyFromPos(int nPos, int *pnX, int *pnY, t_Landscape * pLandscape)
+    /* integer division just gives whole number part */
+    *pnX = nPos % pLandscape->maxX;
+    *pnY = nPos / pLandscape->maxX;
+    Work out index into asCells array from location.
+int posFromXY(int nX, int nY, t_Landscape * pLandscape)
+    int nPos;
+       0   1         2              .... nX-1
+       nX  nX+1 nX+2   .... 2*nX-1
+       (nY-1)*nX            ...  nX*nY-1
+    nPos = _CELL_OUT_OF_RANGE;
+    if (nX >= 0 && nX < pLandscape->maxX && nY >= 0 && nY < pLandscape->maxY) {
+        nPos = nX * pLandscape->maxY + nY;
+    return nPos;
+    Allocate memory to store information on cells.
+int buildLandscape(t_Landscape * pLandscape, t_Params * pParams)
+    int bRet;
+    /* blank everything out */
+    fprintf(stdout, "entered buildLandscape()\n");
+    bRet = 0;
+    pLandscape->asCells = NULL;
+    pLandscape->asUndev = NULL;
+    pLandscape->undevSites = 0;
+    pLandscape->aParcelSizes = NULL;
+    pLandscape->parcelSizes = 0;
+    /* set initial values across the landscape */
+    pLandscape->maxX = pParams->xSize;
+    pLandscape->maxY = pParams->ySize;
+    pLandscape->totalCells = pLandscape->maxX * pLandscape->maxY;
+        (t_Cell *) malloc(sizeof(t_Cell) * pLandscape->totalCells);
+    if (pLandscape->asCells) {
+        if (pParams->num_Regions > 1) {
+            /* just allocate enough space for every cell to be undev */
+            pLandscape->asUndev = (t_Undev *) malloc(sizeof(t_Undev) * pLandscape->totalCells);
+            if (pLandscape->asUndev) {
+                bRet = 1;
+        else
+            bRet = 1;
+    return bRet;
+void readData4AdditionalVariables(t_Landscape * pLandscape,
+                                  t_Params * pParams)
+    int i;
+    int ii;
+    double val;
+    for (i = 0; i < pParams->numAddVariables; i++) {
+        cout << "reading additional variables File: " <<
+            pParams->addVariableFile[i] << "...";
+        /* open raster map */
+        int fd = Rast_open_old(pParams->addVariableFile[i], "");
+        RASTER_MAP_TYPE data_type = Rast_get_map_type(fd);
+        void *buffer = Rast_allocate_buf(data_type);
+        ii = 0;
+        for (int row = 0; row < pParams->xSize; row++) {
+            Rast_get_row(fd, buffer, row, data_type);
+            void *ptr = buffer;
+            for (int col = 0; col < pParams->ySize; col++,
+                 ptr = G_incr_void_ptr(ptr, Rast_cell_size(data_type))) {
+                if (data_type == DCELL_TYPE)
+                    val = *(DCELL *) ptr;
+                else if (data_type == FCELL_TYPE)
+                    val = *(FCELL *) ptr;
+                else {
+                    val = *(CELL *) ptr;
+                if (pLandscape->asCells[ii].nCellType == _CELL_VALID)
+                    pLandscape->asCells[ii].additionVariable[i] = val;
+                else
+                    pLandscape->asCells[ii].additionVariable[i] = 0.0;
+                ii++;
+        Rast_close(fd);
+        cout << "done" << endl;
+    int ii;
+    int val;
+    ii = 0;
+    int fd = Rast_open_old(pParams->indexFile, "");
+    /* TODO: data type should always be CELL */
+    cout << "reading index File: " << pParams->indexFile << "...";
+            if (Rast_is_null_value(ptr, data_type))
+                val = _GIS_NO_DATA_INT; // assign FUTURES representation of NULL value
+            else {
+                if (val > pParams->num_Regions)
+                    G_fatal_error(_("Region ID (%d) inconsistent with number of regions (%d) in map <%s>"),
+                                  val, pParams->num_Regions,
+                                  pParams->indexFile);
+                if (val < 1)
+                    G_fatal_error(_("Region ID (%d) is smaller then 1 in map <%s>"),
+                                  val, pParams->indexFile);
+            pLandscape->asCells[ii].index_region = val;
+            ii++;
+    Read data from GIS rasters and put in correct places in memory.
+int readData(t_Landscape * pLandscape, t_Params * pParams)
+    // TODO: this function should be rewritten to be nicer (unless storing in memorey will change completely)
+    // TODO: fix null handling somewhere
+    char *szBuff;
+    char szFName[_N_MAX_FILENAME_LEN];
+    int bRet, x, y, i, j;
+    double dVal;
+    fprintf(stdout, "entered readData()\n");
+    bRet = 0;
+    szBuff = (char *)malloc(_N_MAX_DYNAMIC_BUFF_LEN * sizeof(char));
+    if (szBuff) {
+        for (j = 0; j < 6; j++) {
+            switch (j) {        /* get correct filename */
+            case 0:
+                strcpy(szFName, pParams->undevelopedFile);
+                break;
+            case 1:
+                strcpy(szFName, pParams->employAttractionFile);
+                break;
+            case 2:
+                strcpy(szFName, pParams->interchangeDistanceFile);
+                break;
+            case 3:
+                strcpy(szFName, pParams->roadDensityFile);
+                break;
+            case 4:
+                strcpy(szFName, pParams->devPressureFile);
+                break;
+            case 5:
+                strcpy(szFName, pParams->consWeightFile);
+                break;
+            default:
+                fprintf(stderr, "readData(): shouldn't get here...\n");
+                break;
+            fprintf(stdout, "\t%s...", szFName);
+            int fd = Rast_open_old(szFName, "");
+            i = 0;
+            x = 0;
+            bRet = 1;  /* can only get worse from here on in */
+                y = 0;
+                    CELL iVal;
+                        dVal = *(DCELL *) ptr;
+                        dVal = *(FCELL *) ptr;
+                    else {
+                        iVal = *(CELL *) ptr;  // integer value for some rasters
+                        dVal = iVal;
+                    if (j == 0) {
+                        /* check for NO_DATA */
+                        if (Rast_is_null_value(ptr, data_type)) {
+                            pLandscape->asCells[i].nCellType =
+                                _CELL_OUT_OF_COUNTY;
+                        else {
+                            pLandscape->asCells[i].nCellType = _CELL_VALID;
+                        /* and put in the correct place */
+                        pLandscape->asCells[i].thisX = x;
+                        pLandscape->asCells[i].thisY = y;
+                        /* and set the time of development */
+                        pLandscape->asCells[i].tDeveloped = _GIS_NO_DATA_INT;
+                    else {
+                        /* clean up missing data */
+                            dVal = 0.0;
+                    // TODO: how do we know that this is set?
+                    if (pLandscape->asCells[i].nCellType == _CELL_VALID) {
+                        /* put data into a correct place */
+                        switch (j) {
+                        case 0:
+                            pLandscape->asCells[i].bUndeveloped = iVal;
+                            pLandscape->asCells[i].bUntouched = 1;
+                            if (pLandscape->asCells[i].bUndeveloped == 1) {
+                                    _N_NOT_YET_DEVELOPED;
+                            else {
+                                /* already developed at the start */
+                                pLandscape->asCells[i].tDeveloped = 0;
+                            break;
+                        case 1:
+                            pLandscape->asCells[i].employAttraction = dVal;
+                            break;
+                        case 2:
+                            pLandscape->asCells[i].interchangeDistance = dVal;
+                            break;
+                        case 3:
+                            pLandscape->asCells[i].roadDensity = dVal;
+                            break;
+                        case 4:
+                            pLandscape->asCells[i].devPressure = (int)dVal;
+                            break;
+                        case 5:
+                            pLandscape->asCells[i].consWeight = dVal;
+                            break;
+                        default:
+                            fprintf(stderr,
+                                    "readData(): shouldn't get here...\n");
+                            break;
+                    y++;
+                    i++;
+                x++;
+            if (x == pLandscape->maxX) {
+            else {
+                if (bRet) {
+                    fprintf(stderr, "readData(): x too small\n");
+                    bRet = 0;
+            if (y != pLandscape->maxY) {
+                if (bRet) {
+                    G_message(_("x=%d y=%d"), x, y);
+                    G_message(_(" xSize=%d ySize=%d"), pParams->xSize,
+                              pParams->ySize);
+                    G_message(_(" maxX=%d minX=%d"), pLandscape->maxX,
+                              pLandscape->maxY);
+                    fprintf(stderr, "readData(): y too small\n");
+                    bRet = 0;
+            else {
+                if (bRet && i == pLandscape->totalCells) {
+                    fprintf(stdout, "done\n");;
+                else {
+                    if (bRet) {
+                                  pParams->ySize);
+                        fprintf(stderr,
+                                "readData(): not read in enough points\n");
+                        bRet = 0;
+            Rast_close(fd);
+        free(szBuff);
+    return bRet;
+    Compare two t_Undev structures.
+    To be used in qsort().
+    \note This sort function is in ascending order
+    (i.e. opposite to what we normally want).
+    \see undevCmpReverse()
+static int undevCmp(const void *a, const void *b)
+    double da = ((t_Undev *) a)->logitVal;
+    double db = ((t_Undev *) b)->logitVal;
+    /* make sure untouched cells preferentially go to top of sort when there is asymmetry between a and b */
+    if (((t_Undev *) a)->bUntouched && !((t_Undev *) b)->bUntouched)
+        return -1;
+    if (((t_Undev *) b)->bUntouched && !((t_Undev *) a)->bUntouched)
+        return 1;
+    /* then sort by value */
+    if (da > db)
+        return 1;
+    if (da < db)
+        return -1;
+    return 0;
+    This is the correct way around sorting with undevCmp() and qsort().
+static int undevCmpReverse(const void *a, const void *b)
+    return -1 * undevCmp(a, b);
+    Write current state of developed areas.
+    Called at end and dumps tDeveloped for all valid cells (NULL for all others)
+    \param undevelopedAsNull Represent undeveloped areas as NULLs instead of -1
+    \param developmentAsOne Represent all developed areas as 1 instead of number
+        representing the step when are was developed
+// TODO: add timestamp to maps
+void outputDevRasterStep(t_Landscape * pLandscape, t_Params * pParams,
+                         const char *rasterNameBase, bool undevelopedAsNull,
+                         bool developmentAsOne)
+    int out_fd = Rast_open_new(rasterNameBase, CELL_TYPE);
+    CELL *out_row = Rast_allocate_c_buf();
+    for (int x = 0; x < pLandscape->maxX; x++) {
+        Rast_set_c_null_value(out_row, pLandscape->maxY);
+        for (int y = 0; y < pLandscape->maxY; y++) {
+            // we don't check return values since we use landscape directly
+            int cellId = posFromXY(x, y, pLandscape);
+            // this handles NULLs on input
+            if (pLandscape->asCells[cellId].nCellType == _CELL_VALID) {
+                CELL value = pLandscape->asCells[cellId].tDeveloped;
+                // this handles undeveloped cells
+                if (undevelopedAsNull && value == -1)
+                    continue;
+                // this handles developed cells
+                if (developmentAsOne)
+                    value = 1;
+                out_row[y] = value;
+        Rast_put_c_row(out_fd, out_row);
+    Rast_close(out_fd);
+    struct Colors colors;
+    Rast_init_colors(&colors);
+    CELL val1 = 0;
+    // TODO: the map max is 36 for 36 steps, it is correct?
+    CELL val2 = pParams->nSteps;
+    if (developmentAsOne) {
+        val1 = 1;
+        val2 = 1;
+        Rast_add_c_color_rule(&val1, 255, 100, 50, &val2, 255, 100, 50,
+                              &colors);
+    else {
+        Rast_add_c_color_rule(&val1, 255, 100, 50, &val2, 255, 255, 0,
+                              &colors);
+    if (!undevelopedAsNull) {
+        val1 = -1;
+        val2 = -1;
+        Rast_add_c_color_rule(&val1, 100, 255, 100, &val2, 100, 255, 100,
+                              &colors);
+    const char *mapset = G_find_file2("cell", rasterNameBase, "");
+    if (mapset == NULL)
+        G_fatal_error(_("Raster map <%s> not found"), rasterNameBase);
+    Rast_write_colors(rasterNameBase, mapset, &colors);
+    Rast_free_colors(&colors);
+    struct History hist;
+    Rast_short_history(rasterNameBase, "raster", &hist);
+    Rast_command_history(&hist);
+    // TODO: store also random seed value (need to get it here, global? in Params?)
+    Rast_write_history(rasterNameBase, &hist);
+    G_message(_("Raster map <%s> created"), rasterNameBase);
+char *mapNameForStep(const char *basename, const int step, const int maxSteps)
+    int digits = log10(maxSteps) + 1;
+    return G_generate_basename(basename, step, digits, 0);
+    Work out how many cells to transition based on the control file.
+int parseControlLine(char *szBuff, char *szStepLabel, int *pnToConvert)
+    char *pPtr;
+    int i;
+    int bRet;
+    bRet = 0;
+    /* strip newline */
+    pPtr = strpbrk(szBuff, "\r\n");
+    if (pPtr) {
+        pPtr[0] = '\0';
+    *pnToConvert = 0;
+    i = 0;
+    pPtr = strtok(szBuff, " \t");
+    while (pPtr && i < 2) {
+        switch (i) {
+        case 0:
+            strcpy(szStepLabel, pPtr);
+            break;
+        case 1:
+            *pnToConvert = atoi(pPtr);
+            break;
+        pPtr = strtok(NULL, " \t");
+        i++;
+    /* only process this line of the control file if it is well formed */
+    if (i == 2) {
+        bRet = 1;
+    return bRet;
+    Calculate probability of development.
+double getDevProbability(t_Cell * pThis, t_Params * pParams)
+    double probAdd;
+    int i;
+    int id = pThis->index_region;
+    if (id == -9999)
+        return 0;
+    id = id - 1;
+    probAdd = pParams->dIntercepts[id];
+    //cout<<"intercept\t"<<probAdd<<endl;
+    probAdd += pParams->dV1[id] * pThis->employAttraction;
+    //cout<<"employAttraction: "<<pParams->dV1[id]<<endl;
+    //cout<<"employAttraction: "<<pThis->employAttraction<<endl;
+    //cout<<"employAttraction: "<<pParams->dV1[id] * pThis->employAttraction<<endl;
+    probAdd += pParams->dV2[id] * pThis->interchangeDistance;
+    //cout<<"interchangeDistance: "<<pParams->dV2[id]<<endl;
+    //cout<<"interchangeDistance: "<<pThis->interchangeDistance<<endl;
+    //cout<<"interchangeDistance: "<<pParams->dV2[id] * pThis->interchangeDistance<<endl;
+    probAdd += pParams->dV3[id] * pThis->roadDensity;
+    //cout<<"roadDensity: "<<pParams->dV3[id]<<endl;
+    //cout<<"roadDensity: "<<pThis->roadDensity<<endl;
+    //cout<<"roadDensity: "<<pParams->dV3[id] * pThis->roadDensity<<endl;
+    probAdd += pParams->dV4[id] * pThis->devPressure;
+    //cout<<"devPressure: "<<pParams->dV4[id]<<endl;
+    //cout<<"devPressure: "<<pThis->devPressure<<endl;
+    //cout<<"devPressure: "<<pParams->dV4[id] * pThis->devPressure<<endl;
+        probAdd += pParams->addParameters[i][id] * pThis->additionVariable[i];
+        //cout<<"additionVariable: "<<i<<"\t"<<pParams->addParameters[i][id]<<endl;
+        //cout<<"additionVariable: "<<i<<"\t"<<pThis->additionVariable[i]<<endl;
+        //cout<<"additionVariable: "<<i<<"\t"<<pParams->addParameters[i][id] * pThis->additionVariable[i]<<endl;
+    probAdd = 1.0 / (1.0 + exp(-probAdd));
+    //cout<<"The probability:";
+    //cout<<probAdd<<endl;
+    return probAdd;
+   double getDevProbability(t_Cell      *pThis, t_Params *pParams){
+   float probAdd; int i;
+   int id=pThis->index_region;
+   if(id==-9999)
+   return 0;
+   id=id-1;
+   for(i=0;i<2;i++){
+   probAdd+=pParams->addParameters[i][id]*pThis->additionVariable[i];
+   if (0<pThis->additionVariable[2]<=400)
+   probAdd = probAdd * 0.0005 ;
+   else {
+   if(400<pThis->additionVariable[2]<=600)
+   {probAdd = probAdd * 0.024;}
+   else {
+   if(600<pThis->additionVariable[2]<=800)
+   {probAdd = probAdd * 0.912 ;}
+   else{
+   if(800<pThis->additionVariable[2]<=1000)
+   {probAdd = probAdd * 0.055 ;}
+   else{
+   if(1000<pThis->additionVariable[2]<=1200)
+   {probAdd = probAdd * 0.006 ;}
+   else{
+   if(1200<pThis->additionVariable[2]<=1400)
+   {probAdd = probAdd * 0.002 ;}
+   else{
+   {probAdd = probAdd * 0.0005;}
+   probAdd = 1.0/(1.0 + exp(-probAdd));
+   return probAdd;
+    Recalculate probabilities for each unconverted cell.
+    Called each timestep.
+void findAndSortProbs(t_Landscape * pLandscape, t_Params * pParams,
+                      int nToConvert)
+    int i, lookupPos;
+    t_Cell *pThis;
+    /* update calcs */
+    fprintf(stdout, "\t\trecalculating probabilities\n");
+    for (i = 0; i < pLandscape->totalCells; i++) {
+        pThis = &(pLandscape->asCells[i]);
+        if (pThis->nCellType == _CELL_VALID) {
+            if (pThis->bUndeveloped) {
+                if (pThis->consWeight > 0.0) {
+                    /* note that are no longer just storing the logit value, but instead the probability (allows consWeight to affect sort order) */
+                    pLandscape->asUndev[pLandscape->undevSites].cellID = i;
+                    pLandscape->asUndev[pLandscape->undevSites].logitVal =
+                        getDevProbability(pThis, pParams);
+                    /* lookup table of probabilities is applied before consWeight */
+                    if (pParams->nAlgorithm == _N_ALGORITHM_STOCHASTIC_II) {
+                        /* replace with value from lookup table */
+                        lookupPos =
+                            (int)(pLandscape->asUndev[pLandscape->undevSites].
+                                  logitVal * (pParams->nProbLookup - 1));
+                            pParams->adProbLookup[lookupPos];
+                        // fprintf(stdout, "%f %d %f\n", pLandscape->asUndev[pLandscape->undevSites].logitVal, lookupPos, pParams->adProbLookup[lookupPos]);
+                    // multiply consweight
+                    pLandscape->asUndev[pLandscape->undevSites].logitVal *=
+                        pThis->consWeight;
+                    pLandscape->asUndev[pLandscape->undevSites].bUntouched = pThis->bUntouched; /* need to store this to put correct elements near top of list */
+                    if (pLandscape->asUndev[pLandscape->undevSites].logitVal >
+                        0.0) {
+                        /* only add one more to the list if have a positive probability */
+                        pLandscape->undevSites++;
+    /* downweight the devPressure if necessary (do not do in first step) */
+    /* doing it here means that last time step values have full weight */
+    if (pParams->nAlgorithm == _N_ALGORITHM_STOCHASTIC_I) {
+        if (pParams->dDevPersistence < 1.0) {
+            fprintf(stdout, "\t\tdownweighting development pressure\n");
+                    /* only need to bother downweighting on cells that can still convert */
+                        pThis->devPressure =
+                            (int)((double)pThis->devPressure *
+                                  pParams->dDevPersistence);
+    /* sort */
+    /* can only be zero for algorithm=stochastic_ii */
+    if (pParams->sortProbs) {
+        fprintf(stdout, "\t\tsorting %d unconserved undeveloped sites\n",
+                pLandscape->undevSites);
+        qsort(pLandscape->asUndev, pLandscape->undevSites, sizeof(t_Undev),
+              undevCmpReverse);
+    else {
+        fprintf(stdout, "\t\tskipping sort as choosing cells randomly\n");
+    //calculate cumulative probability
+    // From Wenwu Tang
+    double sum = pLandscape->asUndev[0].logitVal;
+    for (i = 1; i < pLandscape->undevSites; i++) {
+        pLandscape->asUndev[i].cumulProb =
+            pLandscape->asUndev[i - 1].cumulProb +
+            pLandscape->asUndev[i].logitVal;
+        sum = sum + pLandscape->asUndev[i].logitVal;
+    for (i = 0; i < pLandscape->undevSites; i++) {
+            pLandscape->asUndev[i].cumulProb / sum;
+    Create patches based on spiraling around.
+    \deprecated
+int fillValidNeighbourList(int nThisID, t_Landscape * pLandscape,
+                           t_Params * pParams, int *anToConvert,
+                           int nWantToConvert, int bAllowTouched,
+                           int bDeterministic)
+    int nTried, nFound, x, y, upDown, stopAt, countMove, stepMove, nPos,
+        nSkipped;
+    anToConvert[0] = nThisID;
+    nSkipped = 0;
+    nFound = 1;
+    nTried = 1;
+    x = pLandscape->asCells[nThisID].thisX;
+    y = pLandscape->asCells[nThisID].thisY;
+    stopAt = 0;
+    upDown = 0;
+    stepMove = -1;
+    while (nFound < nWantToConvert &&
+           ((double)nWantToConvert * pParams->giveUpRatio) > nTried) {
+        countMove = 0;
+        upDown = !upDown;
+        if (upDown) {
+            stopAt++;
+            stepMove *= -1;
+        while (countMove < stopAt && nFound < nWantToConvert &&
+            if (upDown) {
+                x += stepMove;
+            else {
+                y += stepMove;
+            // fprintf(stdout, "%d %d\n", x, y);
+            nPos = posFromXY(x, y, pLandscape);
+            if (nPos != _CELL_OUT_OF_RANGE) {
+                if (pLandscape->asCells[nPos].nCellType == _CELL_VALID) {
+                    if (pLandscape->asCells[nPos].bUndeveloped) {
+                        if (bAllowTouched ||
+                            pLandscape->asCells[nPos].bUntouched) {
+                            if (bDeterministic ||
+                                (uniformRandom() < pParams->dProbWeight)) {
+                                if (pLandscape->asCells[nPos].consWeight >
+                                    0.0) {
+                                    anToConvert[nFound] = nPos;
+                                    nFound++;
+                            else {
+                                pLandscape->asCells[nPos].bUntouched = 0;
+                                nSkipped++;
+            nTried++;
+            countMove++;
+    // fprintf(stdout, "\tskipped=%d\n", nSkipped);
+    return nFound;
+   Helper structur for neighbour grabbing algorithm
+typedef struct
+    double probAdd;
+    int cellID;
+    int newInList;
+    // Wenwu Tang
+    /// distance to the center
+    double distance;
+} t_candidateNeighbour;
+typedef struct
+    double maxProb;
+    int nCandidates;
+    int nSpace;
+    t_candidateNeighbour *aCandidates;
+} t_neighbourList;
+#define _N_NEIGHBOUR_LIST_BLOCK_SIZE 20
+int addNeighbourIfPoss(int x, int y, t_Landscape * pLandscape,
+                       t_neighbourList * pNeighbours, t_Params * pParams)
+    int i, thisPos, mustAdd, listChanged, lookupPos;
+    double probAdd;
+    t_Cell *pThis;
+    listChanged = 0;
+    thisPos = posFromXY(x, y, pLandscape);
+    if (thisPos != _CELL_OUT_OF_RANGE) {
+        pThis = &(pLandscape->asCells[thisPos]);
+            pThis->bUntouched = 0;
+                    /* need to add this cell... */
+                    /* ...either refresh its element in list if already there */
+                    mustAdd = 1;
+                    for (i = 0; mustAdd && i < pNeighbours->nCandidates; i++) {
+                        if (pNeighbours->aCandidates[i].cellID == thisPos) {
+                            pNeighbours->aCandidates[i].newInList = 1;
+                            mustAdd = 0;
+                            listChanged = 1;
+                    /* or add it on the end, allocating space if necessary */
+                    if (mustAdd) {
+                        if (pNeighbours->nCandidates == pNeighbours->nSpace) {
+                            pNeighbours->nSpace +=
+                                _N_NEIGHBOUR_LIST_BLOCK_SIZE;
+                            pNeighbours->aCandidates =
+                                (t_candidateNeighbour *)
+                                realloc(pNeighbours->aCandidates,
+                                        pNeighbours->nSpace *
+                                        sizeof(t_candidateNeighbour));
+                            if (!pNeighbours->aCandidates) {
+                                fprintf(stderr,
+                                        "memory error in addNeighbourIfPoss()\n...exiting\n");
+                                exit(EXIT_FAILURE);
+                        pNeighbours->aCandidates[pNeighbours->nCandidates].
+                            cellID = thisPos;
+                            newInList = 1;
+                        /* note duplication of effort in here recalculating the probabilities, but didn't store them in an accessible way */
+                           probAdd = pParams->dIntercept;
+                           probAdd += pParams->dDevPressure * pThis->devPressure;
+                           probAdd += pParams->dEmployAttraction * pThis->employAttraction;
+                           probAdd += pParams->dInterchangeDistance * pThis->interchangeDistance;
+                           probAdd += pParams->dRoadDensity * pThis->roadDensity;
+                           probAdd = 1.0/(1.0 + exp(probAdd));
+                        probAdd = getDevProbability(pThis, pParams);
+                        lookupPos =
+                            (int)(probAdd * (pParams->nProbLookup - 1));
+                        probAdd = pParams->adProbLookup[lookupPos];
+                        probAdd *= pThis->consWeight;
+                        /* multiply by the patch factor to help control shapes of patches */
+                        // pF now is set to 1, so it won't affect the result.or this can be deleted // WT
+                        probAdd *= pParams->patchFactor;
+                            probAdd = probAdd;
+                        /* only actually add it if will ever transition */
+                        if (probAdd > 0.0) {
+                            pNeighbours->nCandidates++;
+                            if (probAdd > pNeighbours->maxProb) {
+                                pNeighbours->maxProb = probAdd;
+                            listChanged = 1;
+    return listChanged;
+// From Wenwu
+    Sort according to the new flag and conversion probability.
+static int sortNeighbours(const void *pOne, const void *pTwo)
+    t_candidateNeighbour *pNOne = (t_candidateNeighbour *) pOne;
+    t_candidateNeighbour *pNTwo = (t_candidateNeighbour *) pTwo;
+       if(pNOne->newInList > pNTwo->newInList)
+       return -1;
+       if(pNTwo->newInList > pNOne->newInList)
+       return 1;
+    float p = rand() / (float)RAND_MAX;
+       if(p<0.0){
+       if(pNOne->distance> pNTwo->distance)
+       return 1;
+       if(pNTwo->distance > pNOne->distance)
+       return -1;
+    float alpha = 0.5;          // assign this from parameter file
+    alpha = (sParams.patchMean) - (sParams.patchRange) * 0.5;
+    alpha += p * sParams.patchRange;
+    //alpha=0;
+    float p1, p2;
+    p1 = pNOne->probAdd / pow(pNOne->distance, alpha);
+    p2 = pNTwo->probAdd / pow(pNTwo->distance, alpha);
+    //p1=alpha*pNOne->probAdd+(1-alpha)*pow(pNOne->distance,-2);
+    //p2=alpha*pNTwo->probAdd+(1-alpha)*pow(pNTwo->distance,-2);
+    if (p1 > p2) {
+        return -1;
+    if (p2 > p1) {
+        return 1;
+    return 0;
+    randomly shuffle the 4 neighbors
+    int proba[4], flag[4];
+    int size = 4, i;
+    for (i = 0; i < size; i++) {
+        proba[i] = rand() % 1000;
+        flag[i] = 1;
+    int numChecked = 0;
+    int max;
+    int index = 0;
+    while (numChecked != 4) {
+        max = -9999;
+            if (flag[i] != 0) {
+                if (proba[i] > max) {
+                    max = proba[i];
+                    index = i;
+        flag[index] = 0;
+        mat[numChecked] = index;
+        numChecked++;
+void findNeighbours(int nThisID, t_Landscape * pLandscape,
+    t_Cell *pThis;
+    int listChanged = 0;
+    // int     idmat[4]; idmat[0]=0;idmat[1]=1;idmat[2]=2;idmat[3]=3;
+    /* try to add the neighbours of this one */
+    pThis = &(pLandscape->asCells[nThisID]);
+    //note: if sorted, then shuffle is no need
+       Shuffle4(&idmat[0]);
+       for(i=0;i<4;i++){
+       if(idmat[i]==0)
+       listChanged+=addNeighbourIfPoss(pThis->thisX-1,pThis->thisY,pLandscape,pNeighbours,pParams);
+       else if(idmat[i]==1)
+       listChanged+=addNeighbourIfPoss(pThis->thisX+1,pThis->thisY,pLandscape,pNeighbours,pParams);
+       else if(idmat[i]==2)
+       listChanged+=addNeighbourIfPoss(pThis->thisX,pThis->thisY-1,pLandscape,pNeighbours,pParams);
+       else if (idmat[i]==3)
+       listChanged+=addNeighbourIfPoss(pThis->thisX,pThis->thisY+1,pLandscape,pNeighbours,pParams);
+    listChanged += addNeighbourIfPoss(pThis->thisX - 1, pThis->thisY, pLandscape, pNeighbours, pParams);  // left
+    listChanged += addNeighbourIfPoss(pThis->thisX + 1, pThis->thisY, pLandscape, pNeighbours, pParams);  // right
+    listChanged += addNeighbourIfPoss(pThis->thisX, pThis->thisY - 1, pLandscape, pNeighbours, pParams);  // down
+    listChanged += addNeighbourIfPoss(pThis->thisX, pThis->thisY + 1, pLandscape, pNeighbours, pParams);  // up
+    if (sParams.numNeighbors == 8) {
+        listChanged +=
+            addNeighbourIfPoss(pThis->thisX - 1, pThis->thisY - 1, pLandscape,
+                               pNeighbours, pParams);
+        listChanged +=
+            addNeighbourIfPoss(pThis->thisX - 1, pThis->thisY + 1, pLandscape,
+        listChanged +=
+            addNeighbourIfPoss(pThis->thisX + 1, pThis->thisY - 1, pLandscape,
+        listChanged +=
+            addNeighbourIfPoss(pThis->thisX + 1, pThis->thisY + 1, pLandscape,
+    /* if anything has been altered then resort */
+    if (listChanged) {
+        //qsort(pNeighbours->aCandidates,pNeighbours->nCandidates,sizeof(t_candidateNeighbour),sortNeighbours);
+double getDistance(int id1, int id2, t_Landscape * pLandscape)
+    double x1, x2, y1, y2, result = 0;
+    x1 = pLandscape->asCells[id1].thisX;
+    x2 = pLandscape->asCells[id2].thisX;
+    y1 = pLandscape->asCells[id1].thisY;
+    y2 = pLandscape->asCells[id2].thisY;
+    result = sqrt((x1 - x2) * (x1 - x2) + (y1 - y2) * (y1 - y2));
+    return result;
+    double result = 0;
+    return result;
+int newPatchFinder(int nThisID, t_Landscape * pLandscape, t_Params * pParams,
+                   int *anToConvert, int nWantToConvert)
+    int bTrying, i, nFound, j;
+    t_neighbourList sNeighbours;
+    memset(&sNeighbours, 0, sizeof(t_neighbourList));
+    pLandscape->asCells[nThisID].bUntouched = 0;
+    pLandscape->asCells[nThisID].bUndeveloped = 0;
+    nFound = 1;
+    findNeighbours(nThisID, pLandscape, &sNeighbours, pParams);
+    for (i = 0; i < sNeighbours.nCandidates; i++) {
+        sNeighbours.aCandidates[i].distance =
+            getDistance(nThisID, sNeighbours.aCandidates[i].cellID,
+                        pLandscape);
+    while (nFound < nWantToConvert && sNeighbours.nCandidates > 0) {
+        i = 0;
+        bTrying = 1;
+        while (bTrying) {
+            if (uniformRandom() < sNeighbours.aCandidates[i].probAdd) {
+                anToConvert[nFound] = sNeighbours.aCandidates[i].cellID;
+                /* flag that it is about to develop */
+                pLandscape->asCells[anToConvert[nFound]].bUndeveloped = 0;
+                /* remove this one from the list by copying down everything above it */
+                for (j = i + 1; j < sNeighbours.nCandidates; j++) {
+                    sNeighbours.aCandidates[j - 1].cellID =
+                        sNeighbours.aCandidates[j].cellID;
+                    sNeighbours.aCandidates[j - 1].newInList =
+                        sNeighbours.aCandidates[j].newInList;
+                    sNeighbours.aCandidates[j - 1].probAdd =
+                        sNeighbours.aCandidates[j].probAdd;
+                /* reduce the size of the list */
+                sNeighbours.nCandidates--;
+                sNeighbours.maxProb = 0.0;
+                for (j = 0; j < sNeighbours.nCandidates; j++) {
+                    if (sNeighbours.aCandidates[j].probAdd >
+                        sNeighbours.maxProb) {
+                /* add its neighbours */
+                findNeighbours(anToConvert[nFound], pLandscape, &sNeighbours,
+                               pParams);
+                nFound++;
+                bTrying = 0;
+            else {
+                sNeighbours.aCandidates[i].newInList = 0;
+            if (bTrying) {
+                i++;
+                if (i == sNeighbours.nCandidates) {
+                    i = 0;
+            else {
+                /* always resort the list if have just added, to let new elements bubble to the top */
+                if (sNeighbours.nCandidates > 0) {
+                    //                                      int z;
+                                        sNeighbours.aCandidates[i].cellID,
+                                        pLandscape);
+                    qsort(sNeighbours.aCandidates, sNeighbours.nCandidates,
+                          sizeof(t_candidateNeighbour), sortNeighbours);
+#if 0
+                    for (z = 0; z < sNeighbours.nCandidates; z++) {
+                        fprintf(stdout, "%d %d %f\n", z,
+                                sNeighbours.aCandidates[z].newInList,
+                                sNeighbours.aCandidates[z].probAdd);
+                    fprintf(stdout, "***\n");
+#endif
+    if (sNeighbours.nSpace) {   /* free any allocated memory */
+        free(sNeighbours.aCandidates);
+    //      fprintf(stdout, "looking for %d found %d\n", nWantToConvert,nFound);
+    return nFound;
+int convertCells(t_Landscape * pLandscape, t_Params * pParams, int nThisID,
+                 int nStep, int bAllowTouched, int bDeterministic)
+    int i, x, y, nCell, nDone, nToConvert, nWantToConvert;
+    int *anToConvert;
+    t_Cell *pThis, *pThat;
+    nDone = 0;
+    /* in here need to build list of near neigbours to loop over */
+    nWantToConvert = pLandscape->aParcelSizes[(int)
+                                              (uniformRandom() *
+                                               pLandscape->parcelSizes)];
+    anToConvert = (int *)malloc(sizeof(int) * nWantToConvert);
+    if (anToConvert) {
+        /* in here goes code to fill up list of neighbours */
+            nToConvert =
+                newPatchFinder(nThisID, pLandscape, pParams, anToConvert,
+                               nWantToConvert);
+        else {
+            nToConvert =
+                fillValidNeighbourList(nThisID, pLandscape, pParams,
+                                       anToConvert, nWantToConvert,
+                                       bAllowTouched, bDeterministic);
+        /* will actually always be the case */
+        if (nToConvert > 0) {
+            //                      fprintf(stdout, "wanted %d, found %d\n", nWantToConvert, nToConvert);
+            for (i = 0; i < nToConvert; i++) {
+                /* convert, updating dev press on neighbours */
+                pThis = &(pLandscape->asCells[anToConvert[i]]);
+                pThis->bUndeveloped = 0;
+                pThis->tDeveloped = nStep + 1;
+                nDone++;
+                // fprintf(stdout, "%d total=%f dev=%f employment=%f interchange=%f roads=%f\n", pLandscape->asUndev[i].cellID, pLandscape->asUndev[i].logitVal, pParams->dDevPressure * pThis->devPressure, pParams->dEmployAttraction * pThis->employAttraction, pParams->dInterchangeDistance * pThis->interchangeDistance, pParams->dRoadDensity * pThis->roadDensity);
+                float dist = 0;
+                float force = 0;
+                for (x = pThis->thisX - pParams->nDevNeighbourhood;
+                     x <= pThis->thisX + pParams->nDevNeighbourhood; x++) {
+                    for (y = pThis->thisY - pParams->nDevNeighbourhood;
+                         y <= pThis->thisY + pParams->nDevNeighbourhood;
+                         y++) {
+                        nCell = posFromXY(x, y, pLandscape);
+                        if (nCell != _CELL_OUT_OF_RANGE) {
+                            pThat = &(pLandscape->asCells[nCell]);
+                            dist =
+                                getDistance1(pThis->thisX, pThis->thisY, x,
+                                             y);
+                            if (dist > pParams->nDevNeighbourhood)
+                                continue;
+                            force = 0;
+                            if (pParams->devPressureApproach == 1)
+                                force = 1;      // development pressure increases by 1
+                            else if (pParams->devPressureApproach == 2) {
+                                if (dist > 0)
+                                    force =
+                                        pParams->scalingFactor / pow(dist,
+        pParams->
+        alpha);
+                            else {
+                                force =
+                                    pParams->scalingFactor * exp(-2 * dist /
+        pParams->
+        alpha);
+                            pThat->devPressure = pThat->devPressure + force;
+        free(anToConvert);
+    return nDone;
+    main routine to actually run the model
+void updateMap(t_Landscape * pLandscape, t_Params * pParams)
+    FILE *fIn;
+    char *szBuff;
+    char szStepLabel[_N_MAX_FILENAME_LEN];
+    int i, nToConvert, nStep, nDone, bAllowTouched, nRandTries, nExtra;
+    double dProb;
+    t_Cell *pThis;
+    nExtra = 0;
+    fprintf(stdout, "entered updateMap()\n");
+    fIn = fopen(pParams->controlFile, "rb");
+    if (fIn) {
+        if (szBuff) {
+            /* start counter at 1 so can distinguish between cells
+               which transition on first step and those which already developed */
+            nStep = 1;
+            while (fgets(szBuff, _N_MAX_DYNAMIC_BUFF_LEN, fIn)) {
+                if (parseControlLine(szBuff, szStepLabel, &nToConvert)) {
+                    fprintf(stdout,
+                            "\tdoing step %s...controlFile requests conversion of %d cells\n",
+                            szStepLabel, nToConvert);
+                    if (nExtra > 0) {
+                        if (nToConvert - nExtra > 0) {
+                            nToConvert -= nExtra;
+                            nExtra = 0;
+                        else {
+                            nExtra -= nToConvert;
+                            nToConvert = 0;
+                    fprintf(stdout,
+                            "\t\tafter accounting for extra cells, attempt %d cells\n",
+                            nToConvert);
+                    /* if have cells to convert this step */
+                        findAndSortProbs(pLandscape, pParams, nToConvert);
+                        /* if not enough cells to convert then alter number required */
+                        if (nToConvert > pLandscape->undevSites) {
+                            fprintf(stdout,
+                                    "\t\tnot enough undeveloped sites...converting all\n");
+                            nToConvert = pLandscape->undevSites;
+                        /* update either in deterministic or stochastic fashion */
+                        fprintf(stdout, "\t\tupdating map\n");
+                        switch (pParams->nAlgorithm) {
+                        case _N_ALGORITHM_DETERMINISTIC:       /* deterministic */
+                            nDone = 0;
+                            for (i = 0; i < nToConvert && nDone < nToConvert;
+                                 i++) {
+                                nDone +=
+                                    convertCells(pLandscape, pParams,
+                                                 cellID, nStep, 1, 1);
+                            break;
+                        case _N_ALGORITHM_STOCHASTIC_I:        /* stochastic */
+                            nDone = 0;
+                            i = 0;
+                            bAllowTouched = 0;
+                            /* loop until done enough cells...might need multiple passes */
+                            while (nDone < nToConvert) {
+                                if (i == pLandscape->undevSites) {
+                                    /* if at the end of the grid, just loop around again until done */
+                                    i = 0;
+                                    /* allow previously considered cells if you have to */
+                                    bAllowTouched = 1;
+                                pThis =
+                                    &(pLandscape->asCells
+                                      [pLandscape->asUndev[i].cellID]);
+                                if (pThis->bUndeveloped) {      /* need to check is still undeveloped */
+                                    if (bAllowTouched || pThis->bUntouched) {
+                                        /* Doug's "back to front" logit */
+                                        // dProb = 1.0/(1.0 + exp(pLandscape->asUndev[i].logitVal));
+                                        dProb =
+                                        /* if starting a patch off here */
+                                            pParams->dProbWeight * dProb) {
+                                            nDone +=
+                                                             pParams,
+                                                             pLandscape->
+                                                             asUndev[i].
+                                                             cellID, nStep,
+                                                             bAllowTouched,
+                                                             0);
+                                i++;
+                            break;
+                        case _N_ALGORITHM_STOCHASTIC_II:  /* stochastic */
+                            nDone = 0;
+                            i = 0;
+                            nRandTries = 0;
+                                    i = 0;
+                                /* if tried too many randomly in this step, give up on idea of only letting untouched cells convert */
+                                if (nRandTries >
+                                    _MAX_RAND_FIND_SEED_FACTOR * nToConvert) {
+                                    /* if sorted then choose the top cell and do nothing */
+                                else {
+                                    /* otherwise give a random undeveloped cell a go */
+                                    if (sParams.seedSearch == 1)
+                                        i = (int)(uniformRandom() *
+                                    // pick one according to their probability
+                                    else
+                                        i = getUnDevIndex(pLandscape);
+                                pThis =
+                                        dProb =
+                                        if (uniformRandom() < dProb) {
+                                            nDone +=
+                                                             pParams,
+                                                             pLandscape->
+                                                             asUndev[i].
+                                                             cellID, nStep,
+                                                             bAllowTouched,
+                                                             0);
+                                    i++;
+                                else {
+                                    nRandTries++;
+                            break;
+                        default:
+                            fprintf(stderr, "Unknown algorithm...exiting\n");
+                            break;
+                        fprintf(stdout, "\t\tconverted %d sites\n", nDone);
+                        nExtra += (nDone - nToConvert);
+                        fprintf(stdout,
+                                "\t\t%d extra sites knocked off next timestep\n",
+                                nExtra);
+                nStep++;  /* next time step */
+            /* dump results to a file at the end of the run */
+            outputDevRasterStep(pLandscape, pParams, pParams->dumpFile, false,
+                                false);
+            free(szBuff);
+        fclose(fIn);
+void readDevDemand(t_Params * pParams)
+    ifstream f1;
+       f1.open(pParams->controlFile);
+       int counter=0;
+       int val1,val2;
+       while(!f1.eof()){
+       f1>>val1>>val2;
+       pParams->devDemand[counter]=val2;
+       counter++;
+       pParams->nSteps=counter;
+       f1.close();
+    //read land demand for each region
+    int i;
+    int val1;
+    char str[200];
+    f1.open(pParams->controlFileAll);
+    f1 >> str >> val1;
+    pParams->nSteps = val1;
+    f1.getline(str, 200);
+    f1.getline(str, 200);  //skip the header
+    int ii;
+    for (ii = 0; ii < pParams->nSteps; ii++) {
+        f1 >> val1;
+            f1 >> val1;
+            pParams->devDemands[i][ii] = val1;
+    f1.close();
+void initializeUnDev(t_Landscape * pLandscape, t_Params * pParams)
+    int i;
+    pLandscape->asUndevs.clear();
+    pLandscape->asUndevs.resize(pParams->num_Regions,
+                                std::vector < t_Undev > (MAX_UNDEV_SIZE));
+        pLandscape->num_undevSites[i] = 0;
+void finalizeUnDev(t_Landscape * pLandscape, t_Params * pParams)
+   main routine to run models on multiple regions // WTang
+void updateMapAll(t_Landscape * pLandscape, t_Params * pParams)
+    //readDevDemand(pParams);
+    int i, j;
+    //initialize undev arrays
+    initializeUnDev(pLandscape, pParams);
+    //iterate each step (year)
+    for (i = 0; i < pParams->nSteps; i++) {
+        cout << i << "\t" << pParams->nSteps << endl;
+        // for each sub-region, find and update conversion probability (conservation weight applied)
+        findAndSortProbsAll(pLandscape, pParams, i);
+        for (j = 0; j < pParams->num_Regions; j++)
+            //j=1;
+            updateMap1(pLandscape, pParams, i, j);
+        if (pParams->outputSeries)
+                                mapNameForStep(pParams->outputSeries, i,
+                                               pParams->nSteps), true, true);
+    outputDevRasterStep(pLandscape, pParams, pParams->dumpFile, false, false);
+    finalizeUnDev(pLandscape, pParams);
+                int regionID)
+    double dProb;
+    t_Cell *pThis;
+    nExtra = 0;
+    nStep = step;
+    //fprintf(stdout, "entered updateMap()\n");
+    nToConvert = pParams->devDemands[regionID][step];
+    //fprintf(stdout, "\tdoing step %s...controlFile requests conversion of %d cells\n", szStepLabel, nToConvert);
+    if (nExtra > 0) {
+            nExtra = 0;
+        else {
+            nToConvert = 0;
+    fprintf(stdout,
+            nToConvert);
+        //findAndSortProbs(pLandscape, pParams, nToConvert);
+        if (nToConvert > pLandscape->num_undevSites[regionID]) {
+            fprintf(stdout,
+            nToConvert = pLandscape->num_undevSites[regionID];
+        //fprintf(stdout, "\t\tupdating map\n");
+            nDone = 0;
+            for (i = 0; i < nToConvert && nDone < nToConvert; i++) {
+                nDone +=
+                                 pLandscape->asUndev[i].cellID, nStep, 1, 1);
+            break;
+            nDone = 0;
+            i = 0;
+                    i = 0;
+                pThis = &(pLandscape->asCells[pLandscape->asUndev[i].cellID]);
+                /* need to check is still undeveloped */
+                        dProb = pLandscape->asUndev[i].logitVal;
+                        if (uniformRandom() < pParams->dProbWeight * dProb) {
+                            nDone +=
+                                             nStep, bAllowTouched, 0);
+                i++;
+            break;
+            nDone = 0;
+            i = 0;
+            nRandTries = 0;
+                if (i == pLandscape->num_undevSites[regionID]) {
+                    i = 0;
+                if (nRandTries > _MAX_RAND_FIND_SEED_FACTOR * nToConvert) {
+                else {
+                                  pLandscape->num_undevSites[regionID]);
+                    //pick one according to their probability
+                    else
+                        G_verbose_message("nDone=%d, toConvert=%d", nDone,
+                                          nToConvert);
+                    i = getUnDevIndex1(pLandscape, regionID);
+                pThis =
+                      [pLandscape->asUndevs[regionID][i].cellID]);
+                        dProb = pLandscape->asUndevs[regionID][i].logitVal;
+                            nDone +=
+                                             pLandscape->asUndevs[regionID]
+                                             [i].cellID, nStep, bAllowTouched,
+                                             0);
+                    i++;
+                else {
+                    nRandTries++;
+            break;
+        default:
+            break;
+        fprintf(stdout, "\t\t%d extra sites knocked off next timestep\n",
+                nExtra);
+    Check Doug's calculation of devPressure.
+    No longer called.
+void testDevPressure(t_Landscape * pLandscape, t_Params * pParams)
+    int x, y, xN, yN, cellID, nCell, testPressure;
+    for (y = 0; y < pLandscape->maxY; y++) {
+        for (x = 0; x < pLandscape->maxX; x++) {
+            cellID = posFromXY(x, y, pLandscape);
+            if (cellID != _CELL_OUT_OF_RANGE) { /* should never happen */
+                if (pLandscape->asCells[cellID].nCellType == _CELL_VALID) {
+                    if (pLandscape->asCells[cellID].bUndeveloped) {
+                        if (pLandscape->asCells[cellID].devPressure) {
+                            fprintf(stdout,
+                                    "(x,y)=(%d,%d) cellType=%d bUndev=%d devPress=%f\n",
+                                    x, y,
+                                    pLandscape->asCells[cellID].nCellType,
+                                    pLandscape->asCells[cellID].bUndeveloped,
+                                    pLandscape->asCells[cellID].devPressure);
+                            testPressure = 0;
+                            for (xN = x - pParams->nDevNeighbourhood;
+                                 xN <= x + pParams->nDevNeighbourhood; xN++) {
+                                for (yN = y - pParams->nDevNeighbourhood;
+                                     yN <= y + pParams->nDevNeighbourhood;
+                                     yN++) {
+                                    nCell = posFromXY(xN, yN, pLandscape);
+                                        if (pLandscape->asCells[nCell].
+                                            nCellType == _CELL_VALID) {
+                                                bUndeveloped == 0) {
+                                                testPressure++;
+                            fprintf(stdout, "\t%d\n", testPressure);
+int readParcelSizes(t_Landscape * pLandscape, t_Params * pParams)
+    FILE *fIn;
+    char *szBuff;
+    int nMaxParcels;
+    fprintf(stdout, "entered readParcelSizes()\n");
+    fIn = fopen(pParams->parcelSizeFile, "rb");
+    if (fIn) {
+        if (szBuff) {
+            /* just scan the file twice */
+            nMaxParcels = 0;
+                nMaxParcels++;
+            rewind(fIn);
+            if (nMaxParcels) {
+                    (int *)malloc(sizeof(int) * nMaxParcels);
+                if (pLandscape->aParcelSizes) {
+                        pLandscape->aParcelSizes[pLandscape->parcelSizes] =
+                            atoi(szBuff) * pParams->discountFactor;
+                        if (pLandscape->aParcelSizes[pLandscape->parcelSizes]) {
+                            pLandscape->parcelSizes++;
+            free(szBuff);
+        fclose(fIn);
+    return pLandscape->parcelSizes;
+int main(int argc, char **argv)
+    struct
+        struct Option
+            *controlFile, *employAttractionFile, *interchangeDistanceFile,
+            *roadDensityFile, *undevelopedFile, *devPressureFile,
+            *consWeightFile, *addVariableFiles, *nDevNeighbourhood,
+            *devpotParamsFile, *dumpFile, *outputSeries, *algorithm,
+            *dProbWeight, *dDevPersistence, *parcelSizeFile, *discountFactor,
+            *giveUpRatio, *probLookupFile, *sortProbs, *patchFactor,
+            *patchMean, *patchRange, *numNeighbors, *seedSearch,
+            *devPressureApproach, *alpha, *scalingFactor, *num_Regions,
+            *indexFile, *controlFileAll, *seed;
+    } opt;
+    struct
+        struct Flag *generateSeed;
+    } flg;
+    G_gisinit(argv[0]);
+    struct GModule *module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("patch growing"));
+    G_add_keyword(_("urban"));
+    G_add_keyword(_("landscape"));
+    G_add_keyword(_("modeling"));
+    module->label =
+        _("Simulates landuse change using FUTure Urban-Regional Environment Simulation (FUTURES).");
+    module->description =
+        _("Module uses Patch-Growing Algorithm (PGA) to"
+          " simulate urban-rural landscape structure development.");
+    opt.controlFile = G_define_standard_option(G_OPT_F_INPUT);
+    opt.controlFile->key = "control_file";
+    opt.controlFile->required = NO;
+    opt.controlFile->label =
+        _("File containing information on how many cells to transition and when");
+    opt.controlFile->description =
+        _("Needed only for single region/zone run");
+    opt.undevelopedFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.undevelopedFile->key = "undeveloped";
+    opt.undevelopedFile->required = YES;
+    opt.undevelopedFile->description =
+        _("Files containing the information to read in");
+    opt.employAttractionFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.employAttractionFile->key = "employ_attraction";
+    opt.employAttractionFile->required = YES;
+    opt.employAttractionFile->description =
+    opt.interchangeDistanceFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.interchangeDistanceFile->key = "interchange_distance";
+    opt.interchangeDistanceFile->required = YES;
+    opt.interchangeDistanceFile->description =
+    opt.roadDensityFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.roadDensityFile->key = "road_density";
+    opt.roadDensityFile->required = YES;
+    opt.roadDensityFile->description =
+    opt.devPressureFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.devPressureFile->key = "development_pressure";
+    opt.devPressureFile->required = YES;
+    opt.devPressureFile->description =
+    opt.consWeightFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.consWeightFile->key = "cons_weight";
+    opt.consWeightFile->required = YES;
+    opt.consWeightFile->description =
+    opt.addVariableFiles = G_define_standard_option(G_OPT_R_INPUT);
+    opt.addVariableFiles->key = "additional_variable_files";
+    opt.addVariableFiles->required = YES;
+    opt.addVariableFiles->multiple = YES;
+    opt.addVariableFiles->description = _("additional variables");
+    opt.nDevNeighbourhood = G_define_option();
+    opt.nDevNeighbourhood->key = "n_dev_neighbourhood";
+    opt.nDevNeighbourhood->type = TYPE_INTEGER;
+    opt.nDevNeighbourhood->required = YES;
+    opt.nDevNeighbourhood->description =
+        _("Size of square used to recalculate development pressure");
+    opt.devpotParamsFile = G_define_standard_option(G_OPT_F_INPUT);
+    opt.devpotParamsFile->key = "devpot_params";
+    opt.devpotParamsFile->required = YES;
+    opt.devpotParamsFile->label =
+        _("Development potential parameters for each region");
+    opt.devpotParamsFile->description =
+        _("Each line should contain region ID followed"
+          " by parameters. Values are separated by whitespace (spaces or tabs)."
+          " First line is ignored, so it can be used for header");
+    opt.algorithm = G_define_option();
+    opt.algorithm->key = "algorithm";
+    opt.algorithm->type = TYPE_STRING;
+    opt.algorithm->required = YES;
+    opt.algorithm->options = "deterministic,stochastic1,stochastic2";
+    opt.algorithm->description =
+        _("Parameters controlling the algorithm to use");
+    opt.dProbWeight = G_define_option();
+    opt.dProbWeight->key = "prob_weight";
+    opt.dProbWeight->type = TYPE_DOUBLE;
+    opt.dProbWeight->required = NO;
+    opt.dProbWeight->label = _("Parameters controlling the algorithm to use");
+    opt.dProbWeight->description = _("(only relevant if nAlgorithm=2)"
+                                     " the probabilities are multiplied"
+                                     " by this factor before comparing with random numbers...increases randomness"
+                                     " of the simulation as with probs like 0.95 is more or less deterministic");
+    opt.dProbWeight->guisection = _("Stochastic 1");
+    opt.dDevPersistence = G_define_option();
+    opt.dDevPersistence->key = "dev_neighbourhood";
+    opt.dDevPersistence->type = TYPE_DOUBLE;
+    opt.dDevPersistence->required = NO;
+    opt.dDevPersistence->label =
+    opt.dDevPersistence->description =
+        _("(only relevant if nAlgorithm=2) the devPressures"
+          " are multiplied by this factor on each timestep, meaning older development is"
+          " downweighted and more recent development most important...should lead"
+          " to clustering of new development");
+    opt.dDevPersistence->guisection = _("Stochastic 1");
+    opt.parcelSizeFile = G_define_standard_option(G_OPT_F_INPUT);
+    opt.parcelSizeFile->key = "parcel_size_file";
+    opt.parcelSizeFile->required = YES;
+    opt.parcelSizeFile->description =
+        _("File containing information on the parcel size to use");
+    opt.discountFactor = G_define_option();
+    opt.discountFactor->key = "discount_factor";
+    opt.discountFactor->type = TYPE_DOUBLE;
+    opt.discountFactor->required = YES;
+    opt.discountFactor->description = _("discount factor of patch size");
+    opt.giveUpRatio = G_define_option();
+    opt.giveUpRatio->key = "give_up_ratio";
+    opt.giveUpRatio->type = TYPE_DOUBLE;
+    opt.giveUpRatio->required = NO;
+    opt.giveUpRatio->label = _("Give up ratio");
+    opt.giveUpRatio->description = _("(only relevant if nAlgorithm=2) give up"
+                                     " spiralling around when examined this factor of sites too many");
+    opt.giveUpRatio->guisection = _("Stochastic 1");
+    /* stochastic 2 algorithm */
+    opt.probLookupFile = G_define_standard_option(G_OPT_F_INPUT);
+    opt.probLookupFile->key = "probability_lookup_file";
+    opt.probLookupFile->required = NO;
+    opt.probLookupFile->label =
+        _("File containing lookup table for probabilities");
+    opt.probLookupFile->description =
+        _("Format is tightly constrained. See documentation.");
+    opt.probLookupFile->guisection = _("Stochastic 2");
+    opt.sortProbs = G_define_option();
+    opt.sortProbs->key = "sort_probs";
+    opt.sortProbs->type = TYPE_INTEGER;
+    opt.sortProbs->required = NO;
+    opt.sortProbs->description =
+        _("Whether or not to sort the list of undeveloped cells before choosing patch seeds");
+    opt.sortProbs->guisection = _("Stochastic 2");
+    opt.patchFactor = G_define_option();
+    opt.patchFactor->key = "patch_factor";
+    opt.patchFactor->type = TYPE_DOUBLE;
+    opt.patchFactor->required = NO;
+    opt.patchFactor->description =
+        _("when building patches, multiply all probabilities by this"
+          " factor (will controls shape of patches to some extent, with higher"
+          " numbers more circular and lower numbers more linear)");
+    opt.patchFactor->guisection = _("Stochastic 2");
+    opt.patchMean = G_define_option();
+    opt.patchMean->key = "patch_mean";
+    opt.patchMean->type = TYPE_DOUBLE;
+    opt.patchMean->required = NO;
+    opt.patchMean->description =
+        _("patch_mean and patch_range are now used to control patch shape");
+    opt.patchMean->guisection = _("Stochastic 2");
+    opt.patchRange = G_define_option();
+    opt.patchRange->key = "patch_range";
+    opt.patchRange->type = TYPE_DOUBLE;
+    opt.patchRange->required = NO;
+    opt.patchRange->description =
+    opt.patchRange->guisection = _("Stochastic 2");
+    opt.numNeighbors = G_define_option();
+    opt.numNeighbors->key = "num_neighbors";
+    opt.numNeighbors->type = TYPE_INTEGER;
+    opt.numNeighbors->required = NO;
+    opt.numNeighbors->options = "4,8";
+    opt.numNeighbors->description =
+        _("The number of neighbors to be used for patch generation (4 or 8)");
+    opt.numNeighbors->guisection = _("Stochastic 2");
+    opt.seedSearch = G_define_option();
+    opt.seedSearch->key = "seed_search";
+    opt.seedSearch->type = TYPE_INTEGER;
+    opt.seedSearch->required = NO;
+    opt.seedSearch->options = "1,2";
+    opt.seedSearch->description =
+        _("The way that the location of a seed is determined");
+    opt.seedSearch->guisection = _("Stochastic 2");
+    opt.devPressureApproach = G_define_option();
+    opt.devPressureApproach->key = "development_pressure_approach";
+    opt.devPressureApproach->type = TYPE_INTEGER;
+    opt.devPressureApproach->required = NO;
+    opt.devPressureApproach->options = "1,2,3";
+    opt.devPressureApproach->description =
+        _("approaches to derive development pressure");
+    opt.devPressureApproach->guisection = _("Stochastic 2");
+    opt.alpha = G_define_option();
+    opt.alpha->key = "alpha";
+    opt.alpha->type = TYPE_DOUBLE;
+    opt.alpha->required = NO;
+    opt.alpha->description =
+        _("Required for development_pressure_approach 1 and 2");
+    opt.alpha->guisection = _("Stochastic 2");
+    opt.scalingFactor = G_define_option();
+    opt.scalingFactor->key = "scaling_factor";
+    opt.scalingFactor->type = TYPE_DOUBLE;
+    opt.scalingFactor->required = NO;
+    opt.scalingFactor->description =
+        _("Required for development_pressure_approach 2 and 3");
+    opt.scalingFactor->guisection = _("Stochastic 2");
+    opt.num_Regions = G_define_option();
+    opt.num_Regions->key = "num_regions";
+    opt.num_Regions->type = TYPE_INTEGER;
+    opt.num_Regions->required = NO;
+    opt.num_Regions->description =
+        _("Number of sub-regions (e.g., counties) to be simulated");
+    opt.num_Regions->guisection = _("Stochastic 2");
+    opt.indexFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.indexFile->key = "index_file";
+    opt.indexFile->required = NO;
+    opt.indexFile->description = _("File for index of sub-regions");
+    opt.indexFile->guisection = _("Stochastic 2");
+    opt.controlFileAll = G_define_standard_option(G_OPT_F_INPUT);
+    opt.controlFileAll->key = "control_file_all";
+    opt.controlFileAll->required = NO;
+    opt.controlFileAll->description =
+        _("Control file with number of cells to convert");
+    opt.controlFileAll->guisection = _("Stochastic 2");
+    opt.dumpFile = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt.dumpFile->key = "output";
+    opt.dumpFile->required = YES;
+    opt.dumpFile->description =
+        _("State of the development at the end of simulation");
+    opt.dumpFile->guisection = _("Output");
+    opt.outputSeries = G_define_standard_option(G_OPT_R_BASENAME_OUTPUT);
+    opt.outputSeries->key = "output_series";
+    opt.outputSeries->required = NO;
+    opt.outputSeries->label =
+        _("State of the development at after each step");
+    opt.outputSeries->guisection = _("Output");
+    // TODO: add mutually exclusive?
+    // TODO: add flags or options to control values in series and final rasters
+    opt.seed = G_define_option();
+    opt.seed->key = "random_seed";
+    opt.seed->type = TYPE_INTEGER;
+    opt.seed->required = NO;
+    opt.seed->label = _("Seed for random number generator");
+    opt.seed->description =
+        _("The same seed can be used to obtain same results"
+          " or random seed can be generated by other means.");
+    opt.seed->guisection = _("Random numbers");
+    flg.generateSeed = G_define_flag();
+    flg.generateSeed->key = 's';
+    flg.generateSeed->label =
+        _("Generate random seed (result is non-deterministic)");
+    flg.generateSeed->description =
+        _("Automatically generates random seed for random number"
+          " generator (use when you don't want to provide the seed option)");
+    flg.generateSeed->guisection = _("Random numbers");
+    // provided XOR generated
+    G_option_exclusive(opt.seed, flg.generateSeed, NULL);
+    G_option_required(opt.seed, flg.generateSeed, NULL);
+    if (G_parser(argc, argv))
+    long seed_value;
+    if (flg.generateSeed->answer) {
+        seed_value = G_srand48_auto();
+        G_message("Generated random seed (-s): %ld", seed_value);
+    if (opt.seed->answer) {
+        seed_value = atol(opt.seed->answer);
+        // this does nothing since we are not using GRASS random function
+        G_srand48(seed_value);
+        G_message("Read random seed from %s option: %ld",
+                  opt.seed->key, seed_value);
+    // although GRASS random function is initialized
+    // the general one must be done separately
+    // TODO: replace all by GRASS random number generator?
+    srand(seed_value);
+    // TODO: move this back to local variables
+    //t_Params      sParams;
+    //t_Landscape   sLandscape;
+    memset(&sParams, 0, sizeof(t_Params));
+    /* parameters dependednt on region */
+    sParams.xSize = Rast_window_rows();
+    sParams.ySize = Rast_window_cols();
+    G_message(_("Running on %d rows and %d columns (%d cells)"),
+              sParams.xSize, sParams.ySize, sParams.xSize * sParams.ySize);
+    /* set up parameters */
+    sParams.controlFile = opt.controlFile->answer;
+    sParams.undevelopedFile = opt.undevelopedFile->answer;
+    sParams.employAttractionFile = opt.employAttractionFile->answer;
+    sParams.interchangeDistanceFile = opt.interchangeDistanceFile->answer;
+    sParams.roadDensityFile = opt.roadDensityFile->answer;
+    sParams.devPressureFile = opt.devPressureFile->answer;
+    sParams.consWeightFile = opt.consWeightFile->answer;
+    sParams.numAddVariables = 0;
+    char **answer = opt.addVariableFiles->answers;
+    size_t num_answers = 0;
+    while (opt.addVariableFiles->answers[num_answers]) {
+        sParams.addVariableFile[num_answers] = *answer;
+        num_answers++;
+    sParams.numAddVariables = num_answers;
+    // TODO: dyn allocate file list
+    sParams.nDevNeighbourhood = atoi(opt.nDevNeighbourhood->answer);
+    sParams.dumpFile = opt.dumpFile->answer;
+    sParams.outputSeries = opt.outputSeries->answer;
+    sParams.parcelSizeFile = opt.parcelSizeFile->answer;
+    sParams.discountFactor = atof(opt.discountFactor->answer);
+    // always 1 if not stochastic 2
+    sParams.sortProbs = 1;
+    // TODO: implement real switching of algorithm
+    if (!strcmp(opt.algorithm->answer, "deterministic"))
+        sParams.nAlgorithm = _N_ALGORITHM_DETERMINISTIC;
+    else if (!strcmp(opt.algorithm->answer, "stochastic1"))
+        sParams.nAlgorithm = _N_ALGORITHM_STOCHASTIC_I;
+    else if (!strcmp(opt.algorithm->answer, "stochastic2"))
+        sParams.nAlgorithm = _N_ALGORITHM_STOCHASTIC_II;
+    if (sParams.nAlgorithm == _N_ALGORITHM_STOCHASTIC_I) {
+        // TODO: add check of filled answer
+        sParams.dProbWeight = atof(opt.dProbWeight->answer);
+        sParams.dDevPersistence = atof(opt.dDevPersistence->answer);
+        sParams.giveUpRatio = atof(opt.giveUpRatio->answer);
+    else if (sParams.nAlgorithm == _N_ALGORITHM_STOCHASTIC_II) {
+        int parsedOK, i;
+        FILE *fp;
+        char inBuff[N_MAXREADINLEN];
+        char *pPtr;
+        fprintf(stdout, "reading probability lookup\n");
+        sParams.probLookupFile = opt.probLookupFile->answer;
+        fp = fopen(sParams.probLookupFile, "r");
+        if (fp) {
+            parsedOK = 0;
+            if (fgets(inBuff, N_MAXREADINLEN, fp)) {
+                if (inBuff[0] == ',') {
+                    sParams.nProbLookup = atoi(inBuff + 1);
+                    if (sParams.nProbLookup > 0) {
+                        sParams.adProbLookup =
+                            (double *)malloc(sizeof(double) *
+                                             sParams.nProbLookup);
+                        if (sParams.adProbLookup) {
+                            parsedOK = 1;
+                            i = 0;
+                            while (parsedOK && i < sParams.nProbLookup) {
+                                parsedOK = 0;
+                                    if (pPtr = strchr(inBuff, ',')) {
+                                        parsedOK = 1;
+                                        sParams.adProbLookup[i] =
+                                            atof(pPtr + 1);
+                                        G_debug(3,
+                                                "probability lookup table: i=%d, i/(n-1)=%f, result=%f",
+                                                i,
+                                                i * 1.0 /
+                                                (sParams.nProbLookup - 1),
+                                                sParams.adProbLookup[i]);
+                                i++;
+            if (!parsedOK) {
+                fprintf(stderr,
+                        "error parsing probLookup file '%s'...exiting\n",
+                        sParams.probLookupFile);
+                return 0;
+            fclose(fp);
+        else {
+            perror("The following error occurred");
+            fprintf(stderr, "error opening probLookup file '%s'...exiting\n",
+            return 0;
+        sParams.sortProbs = atoi(opt.sortProbs->answer);
+        sParams.patchFactor = atof(opt.patchFactor->answer);
+        sParams.patchMean = atof(opt.patchMean->answer);
+        sParams.patchRange = atof(opt.patchRange->answer);
+        sParams.numNeighbors = atoi(opt.numNeighbors->answer);
+        // TODO: convert to options or flag: 1: uniform distribution 2: based on dev. proba.
+        sParams.seedSearch = atoi(opt.seedSearch->answer);
+        sParams.devPressureApproach = atoi(opt.devPressureApproach->answer);
+        if (sParams.devPressureApproach != 1) {
+            sParams.alpha = atof(opt.alpha->answer);
+            sParams.scalingFactor = atof(opt.scalingFactor->answer);
+        sParams.num_Regions = atoi(opt.num_Regions->answer);
+        sParams.indexFile = opt.indexFile->answer;
+        sParams.controlFileAll = opt.controlFileAll->answer;
+    if (sParams.num_Regions > 1)
+        readDevPotParams(&sParams, opt.devpotParamsFile->answer);
+    readDevDemand(&sParams);
+    /* allocate memory */
+    if (buildLandscape(&sLandscape, &sParams)) {
+        /* read data */
+        if (readData(&sLandscape, &sParams)) {
+            readData4AdditionalVariables(&sLandscape, &sParams);
+            readIndexData(&sLandscape, &sParams);
+            if (readParcelSizes(&sLandscape, &sParams)) {
+                //testDevPressure(&sLandscape, &sParams);
+                /* do calculation and dump result */
+                //one region, enable the following
+                //updateMap(&sLandscape, &sParams);
+                //multiple regions
+                updateMapAll(&sLandscape, &sParams);
+            else {
+                fprintf(stderr, "error in readParcelSizes()\n");
+        else {
+            fprintf(stderr, "error in readData()\n");
+        /* could put in routines to free memory, but OS will garbage collect anyway */
+    else {
+        fprintf(stderr, "error in buildLandscape()\n");
+    return EXIT_SUCCESS;
+    float p = rand() / (double)RAND_MAX;
+    int i;
+        if (p < pLandscape->asUndev[i].cumulProb) {
+            return i;
+    // TODO: returning at least something but should be something more meaningful
+    return 0;
+    G_verbose_message(_("getUnDevIndex1: regionID=%d, num_undevSites=%d, p=%f"),
+                      regionID, pLandscape->num_undevSites[regionID], p);
+    int i;
+    for (i = 0; i < pLandscape->num_undevSites[regionID]; i++) {
+        if (p < pLandscape->asUndevs[regionID][i].cumulProb) {
+            G_verbose_message(_("getUnDevIndex1: cumulProb=%f"),
+                              pLandscape->asUndevs[regionID][i].cumulProb);
+            return i;
+    return 0;
+                         int step)
+    int i, lookupPos;
+    t_Cell *pThis;
+    int id;
+    float val = 0.0;
+                    id = pThis->index_region - 1;
+                    if (pThis->index_region == -9999)
+                        continue;
+                       but instead the probability
+                       (allows consWeight to affect sort order) */
+                    if (id < 0 || id >= pParams->num_Regions)
+                        G_fatal_error(_("Index of region %d is out of range [0, %d] (region is %d)"),
+                                      id, pParams->num_Regions - 1,
+                                      pThis->index_region);
+                    if (pLandscape->num_undevSites[id] >=
+                        pLandscape->asUndevs[id].size())
+                        pLandscape->asUndevs[id].resize(pLandscape->
+                                                        asUndevs[id].size() *
+                                                        2);
+                    pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].
+                        cellID = i;
+                    val = getDevProbability(pThis, pParams);
+                        logitVal = val;
+                    G_verbose_message("logit value %f", val);
+                    pThis->devProba = val;
+                        lookupPos = (int)(pLandscape->asUndevs[id]
+                                          [pLandscape->num_undevSites[id]].
+                                                      1));
+                        if (lookupPos >= pParams->nProbLookup ||
+                            lookupPos < 0)
+                            G_fatal_error
+                                ("lookup position (%d) out of range [0, %d]",
+                                 lookupPos, pParams->nProbLookup - 1);
+                                                 num_undevSites[id]].
+                            logitVal = pParams->adProbLookup[lookupPos];
+                    pThis->devProba =
+                                                 num_undevSites[id]].logitVal;
+                    // discount by a conservation factor
+                    pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].logitVal *= pThis->consWeight;
+                    /* need to store this to put correct elements near top of list */
+                    pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].bUntouched = pThis->bUntouched;
+                    if (pLandscape->asUndevs[id]
+                        [pLandscape->num_undevSites[id]].logitVal > 0.0) {
+                        pLandscape->num_undevSites[id]++;
+    /* sort */
+              undevCmpReverse);
+    else {
+    //calculate cumulative probability // From Wenwu Tang
+    int j;
+    for (j = 0; j < pParams->num_Regions; j++) {
+        double sum = pLandscape->asUndevs[j][0].logitVal;
+        for (i = 1; i < pLandscape->num_undevSites[j]; i++) {
+            pLandscape->asUndevs[j][i].cumulProb =
+                pLandscape->asUndevs[j][i - 1].cumulProb +
+                pLandscape->asUndevs[j][i].logitVal;
+            sum = sum + pLandscape->asUndevs[j][i].logitVal;
+        for (i = 0; i < pLandscape->num_undevSites[j]; i++) {
+                pLandscape->asUndevs[j][i].cumulProb / sum;
Property changes on: grass-addons/grass7/raster/r.futures/main.cpp
___________________________________________________________________
Added: svn:mime-type
   + text/x-c++src
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.futures/r.futures.html
--- grass-addons/grass7/raster/r.futures/r.futures.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.futures/r.futures.html	2014-11-30 05:05:19 UTC (rev 63296)
@@ -0,0 +1,108 @@
+<h2>DESCRIPTION</h2>
+<em>r.futures</em> is an implementation of
+FUTure Urban-Regional Environment Simulation (FUTURES)
+which is a model for multilevel simulations of emerging urban-rural
+landscape structure.
+This module uses stochastic Patch-Growing Algorithm (PGA)
+and a combination of field-based and object-based representations
+to simulate land changes.
+The FUTure Urban-Regional Environment Simulation (FUTURES) produces
+regional projections of landscape patterns using coupled submodels
+that integrate nonstationary drivers of land change: per capita demand,
+site suitability, and the spatial structure of conversion events.
+The PGA is a stochastic simulation that maps the
+allocation and spatial structure of land change using
+iterative site selection and a contextually aware region
+growing mechanism that changes cells from "undeveloped"
+to terminal "developed" states.
+<p>
+<center>
+<img src="r_futures.png">
+<p>
+Figure: Output map of developed areas
+</center>
+<p>
+<center>
+<img src="r_futures_detail.png">
+<p>
+Figure: Detail of output map
+</center>
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+r.futures -s control_file=demand.txt employ_attraction=d2urbkm interchange_distance=d2intkm road_density=d2rdskm undeveloped=lc96 development_pressure=gdp cons_weight=weight_1 additional_variable_files=slope n_dev_neighbourhood=10 devpot_params=devpotParams.cfg algorithm=stochastic2 parcel_size_file=patch_sizes.txt discount_factor=0.6 probability_lookup_file=probLookup.csv sort_probs=0 patch_factor=1 patch_mean=0.4 patch_range=0.08 num_neighbors=4 seed_search=2 development_pressure_approach=2 alpha=2 scaling_factor=10 num_regions=9 index_file=index control_file_all=demand.txt output=final_results output_series=development
+</pre></div>
+<h2>KNOWN ISSUES</h2>
+Module holds all data in the memory, so for large areas the memory requirements
+are high.
+Only part of the options is actually working now. The older simpler
+implementations of the algorithms are not available.
+The inputs are not documented.
+<h2>REFERENCES</h2>
+<ul>
+<li>
+    Meentemeyer, R. K., Tang, W., Dorning, M. A, Vogler, J. B., Cunniffe, N. J., Shoemaker D. A.,
+    <a href="http://dx.doi.org/10.1080/00045608.2012.707591">FUTURES: Multilevel Simulations of Emerging Urban-Rural Landscape Structure Using a Stochastic Patch-Growing Algorithm</a>
+    Annals of the Association of American Geographers
+    Vol. 103, Iss. 4, 2013
+<li>
+    Dorning, M. A, Koch J., Shoemaker D. A, Meentemeyer, R. K.,
+    Simulating urbanization scenarios under various landscape planning policies reveals trade-offs between disparate conservation goals
+    [in press]
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="r.mapcalc.html">r.mapcalc</a>,
+  <a href="r.reclass.html">r.reclass</a>,
+  <a href="r.rescale.html">r.rescale</a>
+</em>
+<h2>AUTHORS</h2>
+<p>
+<em>Corresponding author:</em><br>
+Ross K. Meentemeyer, rkmeente ncsu edu,
+<a href="http://geospatial.ncsu.edu/">Center for Geospatial Analytics, NCSU</a>
+<p>
+<em>Original standalone version:</em><br>
+Ross K. Meentemeyer *<br>
+Wenwu Tang *<br>
+Monica A. Dorning *<br>
+John B. Vogler *<br>
+Nik J. Cunniffe *<br>
+Douglas A. Shoemaker *<br>
+Jennifer A. Koch **<br>
+<br>
+* Department of Geography and Earth Sciences, UNC Charlotte<br>
+** <a href="http://geospatial.ncsu.edu/">Center for Geospatial Analytics, NCSU</a><br>
+<p>
+<em>Port to GRASS GIS and GRASS-specific additions:</em><br>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a><br>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.futures/r.futures.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/raster/r.futures/r_futures.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.futures/r_futures.png
   + image/png
Added: grass-addons/grass7/raster/r.futures/r_futures_detail.png
Property changes on: grass-addons/grass7/raster/r.futures/r_futures_detail.png
   + image/png
