[GRASS-SVN] r63297 - in grass/trunk/lib: gpde/test python/gunittest python/gunittest/testsuite python/pygrass/gis python/script python/temporal python/temporal/testsuite
svn_grass at osgeo.org
Sun Nov 30 01:28:42 PST 2014
Author: neteler
Date: 2014-11-30 01:28:41 -0800 (Sun, 30 Nov 2014)
New Revision: 63297
grass/trunk/lib/gpde/test/test_arrays.c
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
grass/trunk/lib/python/pygrass/gis/__init__.py
grass/trunk/lib/python/script/core.py
grass/trunk/lib/python/script/raster3d.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/factory.py
grass/trunk/lib/python/temporal/list_stds.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/open_stds.py
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
fix rast3d -> 3draster
Modified: grass/trunk/lib/gpde/test/test_arrays.c
--- grass/trunk/lib/gpde/test/test_arrays.c 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/gpde/test/test_arrays.c 2014-11-30 09:28:41 UTC (rev 63297)
@@ -857,7 +857,7 @@
N_free_array_3d(tmp);
sprintf(buff,
- "g.remove -f type=rast3d name=gpde_lib_test_volume_1,gpde_lib_test_volume_2");
+ "g.remove -f type=3draster name=gpde_lib_test_volume_1,gpde_lib_test_volume_2");
system(buff);
N_free_array_3d(data1);
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/gunittest/case.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -672,7 +672,7 @@
sep='=', precision=precision,
reference=statistics, msg=msg)
finally:
- call_module('g.remove', flags='f', type='rast3d', name=diff)
+ call_module('g.remove', flags='f', type='3draster', name=diff)
else:
# general case
# TODO: we are using r.info min max and r.univar min max interchangably
@@ -698,7 +698,7 @@
self.assertRaster3dFitsUnivar(raster=diff, reference=statistics,
precision=precision, msg=msg)
finally:
# TODO: this works only in 2D
# TODO: write tests
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -29,7 +29,7 @@
def tearDownClass(cls):
cls.del_temp_region()
# TODO: input as list does not work, why?
- cls.runModule('g.remove', flags='f', type='rast3d',
+ cls.runModule('g.remove', flags='f', type='3draster',
name=','.join([cls.constant_map, cls.rcd_increasing_map]))
def test_assertRaster3dFitsUnivar(self):
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -16,7 +16,7 @@
ETYPE = {'rast': libgis.G_ELEMENT_RASTER,
- 'rast3d': libgis.G_ELEMENT_RASTER3D,
+ '3draster': libgis.G_ELEMENT_RASTER3D,
'vect': libgis.G_ELEMENT_VECTOR,
'oldvect': libgis.G_ELEMENT_OLDVECTOR,
'asciivect': libgis.G_ELEMENT_ASCIIVECTOR,
@@ -315,7 +315,7 @@
* 'labels',
* 'oldvect',
* 'rast',
- * 'rast3d',
+ * '3draster',
* 'region',
* 'region3d',
* 'sites',
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/script/core.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -1086,7 +1086,7 @@
Returns the output from running g.list, as a list of qualified
names.
- :param str type: element type (rast, vect, rast3d, region, ...)
+ :param str type: element type (rast, vect, 3draster, region, ...)
:param str pattern: pattern string
:param str mapset: mapset name (if not given use search path)
:param str exclude: pattern string to exclude maps from the research
@@ -1117,7 +1117,7 @@
(name, mapset) pairs
@@ -1142,7 +1142,7 @@
>>> list_grouped('vect', pattern='*roads*')['PERMANENT']
['railroads', 'roadsmajor']
- :param str type: element type (rast, vect, rast3d, region, ...) or list of elements
+ :param str type: element type (rast, vect, 3draster, region, ...) or list of elements
:param str check_search_path: True to add mapsets for the search path
with no found elements
Modified: grass/trunk/lib/python/script/raster3d.py
--- grass/trunk/lib/python/script/raster3d.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/script/raster3d.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -33,7 +33,7 @@
>>> mapcalc3d('volume = row() + col() + depth()')
>>> raster3d_info('volume') # doctest: +ELLIPSIS
{'vertical_units': '"units"', 'tbres': 1.0, ... 'south': 185000.0}
- >>> run_command('g.remove', flags='f', type='rast3d', name='volume')
+ >>> run_command('g.remove', flags='f', type='3draster', name='volume')
0
:param str map: map name
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -46,7 +46,7 @@
@abstractmethod
def get_new_stds_instance(self, ident):
"""Return a new space time dataset instance that store maps with the
- type of this map object (rast, rast3d or vect)
+ type of this map object (rast, 3draster or vect)
:param ident The identifier of the space time dataset
:return: The new space time dataset instance
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/extract.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -237,7 +237,7 @@
gscript.run_command("g.remove", flags='f', type='rast',
name=names, quiet=True)
elif type == "raster3d":
- gscript.run_command("g.remove", flags='f', type='rast3d',
+ gscript.run_command("g.remove", flags='f', type='3draster',
elif type == "vector":
gscript.run_command("g.remove", flags='f', type='vect',
Modified: grass/trunk/lib/python/temporal/factory.py
--- grass/trunk/lib/python/temporal/factory.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/factory.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -26,7 +26,7 @@
def dataset_factory(type, id):
"""A factory functions to create space time or map datasets
- :param type: the dataset type: rast or raster, rast3d,
+ :param type: the dataset type: rast or raster, 3draster,
vect or vector, strds, str3ds, stvds
:param id: The id of the dataset ("name at mapset")
@@ -38,7 +38,7 @@
sp = SpaceTimeVectorDataset(id)
elif type == "rast" or type == "raster":
sp = RasterDataset(id)
- elif type == "rast3d":
+ elif type == "3draster":
sp = Raster3DDataset(id)
elif type == "vect" or type == "vector":
sp = VectorDataset(id)
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/list_stds.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -34,7 +34,7 @@
the values are the rows from the SQL database query.
:param type: The type of the datasets (strds, str3ds, stvds, rast,
- rast3d, vect)
+ 3draster, vect)
:param temporal_type: The temporal type of the datasets (absolute,
relative)
:param columns: A comma separated list of columns that will be selected
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -331,7 +331,7 @@
dbif.close()
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/open_stds.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -52,7 +52,7 @@
if type == "strds" or type == "rast" or type == "raster":
sp = dataset_factory("strds", id)
- elif type == "str3ds" or type == "rast3d" or type == "3draster":
+ elif type == "str3ds" or type == "3draster" or type == "3draster":
sp = dataset_factory("str3ds", id)
elif type == "stvds" or type == "vect" or type == "vector":
sp = dataset_factory("stvds", id)
@@ -108,7 +108,7 @@
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/register.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -35,7 +35,7 @@
It takes care of the correct update of the space time datasets from all
registered maps.
- :param type: The type of the maps rast, rast3d or vect
+ :param type: The type of the maps rast, 3draster or vect
:param name: The name of the space time dataset. Maps will be
registered in the temporal database if the name was set
to None
@@ -327,7 +327,7 @@
for dataset in datatsets_to_modify:
ds = dataset_factory("strds", dataset)
ds = dataset_factory("str3ds", dataset)
ds = dataset_factory("stvds", dataset)
@@ -434,7 +434,7 @@
"""Register a list of AbstractMapDataset objects in the temporal database
and optional in a space time dataset.
- :param type: The type of the map layer (rast, rast3d, vect)
+ :param type: The type of the map layer (rast, 3draster, vect)
:param map_list: List of AbstractMapDataset objects
:param output_stds: The output stds
:param delete_empty: Set True to delete empty map layer found in the map_list
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -418,7 +418,7 @@
True
>>> r3map.is_time_relative()
False
- >>> grass.run_command("g.remove", flags="f", type="rast3d", name=name, quiet=True)
+ >>> grass.run_command("g.remove", flags="f", type="3draster", name=name, quiet=True)
0
>>> grass.del_temp_region()
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -1063,7 +1063,7 @@
"""Remove maps of specific type
:param namelist: List of map names to be removed
- :param map_type: The type of the maps (rast, rast3d or vect)
+ :param map_type: The type of the maps (rast, 3draster or vect)
max = 100
chunklist = [namelist[i:i + max] for i in range(0, len(namelist), max)]
@@ -1074,7 +1074,7 @@
if map_type == "raster":
map_type = "rast"
if map_type == "raster3d":
- map_type = "rast3d"
+ map_type = "3draster"
if map_type == "vector":
map_type = "vect"
@@ -2073,7 +2073,7 @@
process_queue.put(m)
elif map_i.get_type() == 'raster3d':
m = copy.deepcopy(self.m_copy)
- m.inputs["rast3d"].value = map_i.get_id(), newident
+ m.inputs["3draster"].value = map_i.get_id(), newident
m.flags["overwrite"].value = self.overwrite
elif map_i.get_type() == 'vector':
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -45,7 +45,7 @@
self.overwrite = overwrite
self.count = 0
self.stdstype = "str3ds"
- self.maptype = "rast3d"
+ self.maptype = "3draster"
self.mapclass = Raster3DDataset
self.basename = basename
self.expression = expression
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py 2014-11-30 05:05:19 UTC (rev 63296)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py 2014-11-30 09:28:41 UTC (rev 63297)
@@ -33,7 +33,7 @@
tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
title="A", descr="A", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="rast3d", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="3draster", name="A", maps="a1,a2,a3,a4",
start="2001-01-01", increment="1 day", interval=True)
def tearDown(self):
