[GRASS-SVN] r63304 - in grass/trunk: raster/r.his scripts/r.shadedmap
svn_grass at osgeo.org
Sun Nov 30 14:25:52 PST 2014
Author: wenzeslaus
Date: 2014-11-30 14:25:52 -0800 (Sun, 30 Nov 2014)
New Revision: 63304
grass/trunk/raster/r.his/main.c
grass/trunk/scripts/r.shadedmap/r.shadedmap.html
grass/trunk/scripts/r.shadedmap/r.shadedmap.py
r.his and r.shade(edmap): propagate all NULLs by default, flag for NULLs color from color table, option for constant color for NULLs
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c 2014-11-30 21:54:53 UTC (rev 63303)
+++ grass/trunk/raster/r.his/main.c 2014-11-30 22:25:52 UTC (rev 63304)
@@ -19,6 +19,7 @@
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/display.h>
+#include <grass/colors.h>
#include "his.h"
#include <grass/glocale.h>
@@ -45,6 +46,9 @@
int g_used;
int b_file = 0;
int b_used;
+ int bg_r, bg_g, bg_b;
+ int bgcolor_state;
+ int draw_nulls; /* 0 as nulls, 1 draw using bgcolor, 2 draw from table */
struct Cell_head window;
struct Colors hue_colors;
struct Colors int_colors;
@@ -54,6 +58,7 @@
struct GModule *module;
struct Option *opt_h, *opt_i, *opt_s;
struct Option *opt_r, *opt_g, *opt_b;
+ struct Option *bgcolor;
struct Flag *nulldraw;
G_gisinit(argv[0]);
@@ -111,13 +116,34 @@
opt_b->gisprompt = "new,cell,raster";
opt_b->description = _("Name of output layer to be used for blue");
+ bgcolor = G_define_standard_option(G_OPT_C_BG);
+ bgcolor->label = _("Color to use instead of NULL values");
+ bgcolor->answer = NULL;
nulldraw = G_define_flag();
- nulldraw->key = 'n';
- nulldraw->description = _("Respect NULL values while drawing");
+ nulldraw->key = 'c';
+ nulldraw->description = _("Use colors from color tables for NULL values");
+ G_option_exclusive(bgcolor, nulldraw, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ draw_nulls = 0;
+ if (nulldraw->answer) {
+ draw_nulls = 2;
+ if (bgcolor->answer) {
+ bgcolor_state = G_str_to_color(bgcolor->answer, &bg_r, &bg_g, &bg_b);
+ if (bgcolor_state == 1) {
+ draw_nulls = 1;
+ } else if (bgcolor_state == 2) {
+ /* none is the same as not providing the color */
+ draw_nulls = 0;
+ } else {
+ G_fatal_error(_("No such color <%s>"), bgcolor->answer);
/* read in current window */
G_get_window(&window);
@@ -220,15 +246,24 @@
Rast_get_row_colors(sat_file, atrow, &sat_colors, sat_r, dummy, dummy, sat_n);
for (atcol = 0; atcol < window.cols; atcol++) {
- if (nulldraw->answer) {
- if (hue_n[atcol]
- || (int_used && int_n[atcol])
- || (sat_used && sat_n[atcol])) {
+ if (hue_n[atcol]
+ || (int_used && int_n[atcol])
+ || (sat_used && sat_n[atcol]))
+ if (draw_nulls == 0) {
+ /* write nulls where nulls are by default */
Rast_set_c_null_value(&r_array[atcol], 1);
Rast_set_c_null_value(&g_array[atcol], 1);
Rast_set_c_null_value(&b_array[atcol], 1);
continue;
+ } else if (draw_nulls == 1) {
+ /* if nulls opaque and bgcolor provided use it */
+ r_array[atcol] = bg_r;
+ g_array[atcol] = bg_g;
+ b_array[atcol] = bg_b;
+ continue;
+ /* else use the color table colors, G6 default */
if (int_used)
Modified: grass/trunk/scripts/r.shadedmap/r.shadedmap.html
--- grass/trunk/scripts/r.shadedmap/r.shadedmap.html 2014-11-30 21:54:53 UTC (rev 63303)
+++ grass/trunk/scripts/r.shadedmap/r.shadedmap.html 2014-11-30 22:25:52 UTC (rev 63304)
@@ -16,7 +16,16 @@
<a href="r.slope.aspect.html">r.slope.aspect</a> or
<a href="r.shaded.relief.html">r.shaded.relief</a><br>.
+<p>
+NULL values are propagated by default, so if any of the two input rasters
+contains NULL cell NULL will be also in the output. If <b>-c</b> flag is
+used and cell in <b>drapemap</b> raster is NULL, just <b>reliefmap</b>
+color is used. If cell in <b>reliefmap</b> raster is NULL, shading effect
+is not applied and original colors are used. If <b>bgcolor</b> option is
+used, NULL value in any input raster will be in the output replaced
+by the given color.
<h2>NOTES</h2>
Refer to the <a href="r.his.html">r.his</a> help page for more details;
Modified: grass/trunk/scripts/r.shadedmap/r.shadedmap.py
--- grass/trunk/scripts/r.shadedmap/r.shadedmap.py 2014-11-30 21:54:53 UTC (rev 63303)
+++ grass/trunk/scripts/r.shadedmap/r.shadedmap.py 2014-11-30 22:25:52 UTC (rev 63304)
@@ -42,8 +42,26 @@
#% options: -99-99
#% answer: 0
#%end
+#%option
+#% key: bgcolor
+#% type: string
+#% key_desc: name
+#% label: Color to use instead of NULL values
+#% description: Either a standard color name, R:G:B triplet, or "none"
+#% gisprompt: old,color_none,color
+#%end
+#%flag
+#% key: c
+#% description: Use colors from color tables for NULL values
+#%end
+#%rules
+#% exclusive: bgcolor, -c
+#%end
+# TODO: bgcolor is not using standard option because it has default white
+# using `answer:` will cause `default:` which is not the same as no default
import os
from grass.script import core as gcore
from grass.script import raster as grast
@@ -57,13 +75,20 @@
def main():
- options, unused = gcore.parser()
+ options, flags = gcore.parser()
drape_map = options['drapemap']
relief_map = options['reliefmap']
brighten = int(options['brighten'])
output_map = options['output']
+ bgcolor = options['bgcolor']
+ rhis_extra_args = {}
+ if bgcolor:
+ rhis_extra_args['bgcolor'] = bgcolor
+ if flags['c']:
+ rhis_extra_args['flags'] = 'c'
to_remove = []
try:
unique_name = 'tmp__rshadedmap_%d' % os.getpid()
@@ -86,7 +111,7 @@
relief_map = relief_map_tmp
to_remove.append(relief_map_tmp)
gcore.run_command('r.his', hue=drape_map, intensity=relief_map,
- red=tmp_r, green=tmp_g, blue=tmp_b)
+ red=tmp_r, green=tmp_g, blue=tmp_b, **rhis_extra_args)
to_remove.extend([tmp_r, tmp_g, tmp_b])
gcore.run_command('r.composite', red=tmp_r, green=tmp_g,
blue=tmp_b, output=output_map)
@@ -94,7 +119,7 @@
except CalledModuleError, error:
remove(to_remove)
# TODO: implement module name to CalledModuleError
- gcore.fatal(_("Module %s failed. Check the above error messages.") % error.args)
+ gcore.fatal(_("Module %s failed. Check the above error messages.") % error.cmd)
if __name__ == "__main__":
