[GRASS-SVN] r63306 - in grass/trunk/scripts: d.shade d.vect.thematic
svn_grass at osgeo.org
Sun Nov 30 16:44:13 PST 2014
Author: wenzeslaus
Date: 2014-11-30 16:44:13 -0800 (Sun, 30 Nov 2014)
New Revision: 63306
grass/trunk/scripts/d.shade/d.shade.py
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
d.* scripts: check if graphics device is open or render immediate set for modules which run from wxGUI
* changing r62845 for d.shade and d.vect.thematic
* MONITOR GRASS GIS variable is set by d.mon but GRASS_RENDER_IMMEDIATE environmental variable is set in wxGUI
* similar change might be needed for other modules too in case they are used with GRASS_RENDER_IMMEDIATE
* better error message might be needed for GRASS_RENDER_IMMEDIATE, common implementation might be advantageous
Modified: grass/trunk/scripts/d.shade/d.shade.py
--- grass/trunk/scripts/d.shade/d.shade.py 2014-12-01 00:21:48 UTC (rev 63305)
+++ grass/trunk/scripts/d.shade/d.shade.py 2014-12-01 00:44:13 UTC (rev 63306)
@@ -50,7 +50,11 @@
env = gcore.gisenv()
mon = env.get('MONITOR', None)
if not mon:
- gcore.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
+ # os is needed only here
+ import os
+ if not 'GRASS_RENDER_IMMEDIATE' in os.environ:
+ gcore.fatal(_("No graphics device selected."
+ " Use d.mon to select graphics device."))
drape_map = options['drapemap']
relief_map = options['reliefmap']
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-01 00:21:48 UTC (rev 63305)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-01 00:44:13 UTC (rev 63306)
@@ -231,10 +231,12 @@
def main():
global tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg
- env = grass.gisenv()
+ env = gcore.gisenv()
if not mon:
- grass.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
breakpoints = options['breakpoints']
colorscheme = options['colorscheme']
