[GRASS-SVN] r62160 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Thu Oct 2 13:20:45 PDT 2014
Author: mmetz
Date: 2014-10-02 13:20:45 -0700 (Thu, 02 Oct 2014)
New Revision: 62160
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: +print raster attribute tables to files
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2014-10-02 20:19:21 UTC (rev 62159)
+++ grass/trunk/raster/r.in.gdal/main.c 2014-10-02 20:20:45 UTC (rev 62160)
@@ -18,6 +18,8 @@
#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
#include <unistd.h>
#include <math.h>
#include <string.h>
@@ -39,7 +41,7 @@
struct Ref *group_ref);
static void SetupReprojector(const char *pszSrcWKT, const char *pszDstLoc,
struct pj_info *iproj, struct pj_info *oproj);
+static int dump_rat(GDALRasterBandH hBand, char *outrat, int nBand);
static int l1bdriver;
@@ -68,7 +70,8 @@
struct GModule *module;
struct
- struct Option *input, *output, *target, *title, *outloc, *band, *memory, *offset;
+ struct Option *input, *output, *target, *title, *outloc, *band,
+ *memory, *offset, *rat;
} parm;
struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c;
@@ -138,6 +141,14 @@
parm.outloc->description = _("Name for new location to create");
parm.outloc->key_desc = "name";
+ parm.rat = G_define_option();
+ parm.rat->key = "rat";
+ parm.rat->type = TYPE_STRING;
+ parm.rat->required = NO;
+ parm.rat->label = _("File prefix for raster attribute tables");
+ parm.rat->description = _("The band number and \".csv\" will be appended to the file prefix");
+ parm.rat->key_desc = "file";
flag_o = G_define_flag();
flag_o->key = 'o';
flag_o->description =
@@ -514,6 +525,8 @@
ImportBand(hBand, output, NULL);
+ if (parm.rat->answer)
+ dump_rat(hBand, parm.rat->answer, nBand);
if (title)
Rast_put_cell_title(output, title);
@@ -1339,3 +1352,107 @@
return;
+ int row, col, nrows, ncols;
+ const char *field_name;
+ GDALRATFieldUsage field_use;
+ GDALRATFieldType *field_type;
+ GDALRasterAttributeTableH gdal_rat;
+ FILE *fp;
+ char fname[GNAME_MAX];
+ if ((gdal_rat = GDALGetDefaultRAT(hBand)) == NULL)
+ return 0;
+ nrows = GDALRATGetRowCount(gdal_rat);
+ ncols = GDALRATGetColumnCount(gdal_rat);
+ if (nrows == 0 || ncols == 0)
+ return 0;
+ field_type = G_malloc(ncols * sizeof(GDALRATFieldType));
+ snprintf(fname, GNAME_MAX, "%s_%d.csv", outrat, nBand);
+ if (!(fp = fopen(fname, "w"))) {
+ int err = errno;
+ G_fatal_error(_("Unable to open file <%s>: %s."),
+ fname, strerror(err));
+ /* dump column names and usage */
+ for (col = 0; col < ncols; col++) {
+ if (col)
+ fprintf(fp, "|");
+ field_name = GDALRATGetNameOfCol(gdal_rat, col);
+ fprintf(fp, "%s", field_name);
+ field_use = GDALRATGetUsageOfCol(gdal_rat, col);
+ if (field_use == GFU_Generic)
+ fprintf(fp, " (General purpose field)");
+ else if (field_use == GFU_PixelCount)
+ fprintf(fp, " (Histogram pixel count)");
+ else if (field_use == GFU_Name)
+ fprintf(fp, " (Class name)");
+ else if (field_use == GFU_Min)
+ fprintf(fp, " (Class range minimum)");
+ else if (field_use == GFU_Max)
+ fprintf(fp, " (Class range maximum)");
+ else if (field_use == GFU_MinMax)
+ fprintf(fp, " (Class value (min=max))");
+ else if (field_use == GFU_Red)
+ fprintf(fp, " (Red class color (0-255))");
+ else if (field_use == GFU_Green)
+ fprintf(fp, " (Green class color (0-255))");
+ else if (field_use == GFU_Blue)
+ fprintf(fp, " (Blue class color (0-255))");
+ else if (field_use == GFU_Alpha)
+ fprintf(fp, " (Alpha (0=transparent,255=opaque))");
+ else if (field_use == GFU_RedMin)
+ fprintf(fp, " (Color Range Red Minimum)");
+ else if (field_use == GFU_GreenMin)
+ fprintf(fp, " (Color Range Green Minimum)");
+ else if (field_use == GFU_BlueMin)
+ fprintf(fp, " (Color Range Blue Minimum)");
+ else if (field_use == GFU_AlphaMin)
+ fprintf(fp, " (Color Range Alpha Minimum)");
+ else if (field_use == GFU_RedMax)
+ fprintf(fp, " (Color Range Red Maximum)");
+ else if (field_use == GFU_GreenMax)
+ fprintf(fp, " (Color Range Green Maximum)");
+ else if (field_use == GFU_BlueMax)
+ fprintf(fp, " (Color Range Blue Maximum)");
+ else if (field_use == GFU_AlphaMax)
+ fprintf(fp, " (Color Range Alpha Maximum)");
+ else if (field_use == GFU_MaxCount)
+ fprintf(fp, " (Maximum GFU value)");
+ else
+ fprintf(fp, " (Unknown)");
+ /* remember column type */
+ field_type[col] = GDALRATGetTypeOfCol(gdal_rat, col);
+ fprintf(fp, "\n");
+ /* dump entries */
+ for (row = 0; row < nrows; row++) {
+ if (col)
+ fprintf(fp, "|");
+ if (field_type[col] == GFT_Integer)
+ fprintf(fp, "%d", GDALRATGetValueAsInt(gdal_rat, row, col));
+ else if (field_type[col] == GFT_Real)
+ fprintf(fp, "%.15g", GDALRATGetValueAsDouble(gdal_rat, row, col));
+ else
+ fprintf(fp, "%s", GDALRATGetValueAsString(gdal_rat, row, col));
+ return 1;
