[GRASS-SVN] r62161 - grass/trunk/lib/vector/Vlib
Thu Oct 2 13:24:10 PDT 2014
Author: mmetz
Date: 2014-10-02 13:24:10 -0700 (Thu, 02 Oct 2014)
New Revision: 62161
   grass/trunk/lib/vector/Vlib/intersect2.c
Vlib: self-intersection in Vect_line_intersection2()
Modified: grass/trunk/lib/vector/Vlib/intersect2.c
--- grass/trunk/lib/vector/Vlib/intersect2.c	2014-10-02 20:20:45 UTC (rev 62160)
+++ grass/trunk/lib/vector/Vlib/intersect2.c	2014-10-02 20:24:10 UTC (rev 62161)
@@ -547,12 +547,12 @@
  * Creates array of new lines created from original A line, by
  * intersection with B line. Points (Points->n_points == 1) are not
- * supported.
+ * supported. If B line is NULL, A line is intersected with itself.
  * simplified Bentley–Ottmann Algorithm
  * \param APoints first input line
- * \param BPoints second input line
+ * \param BPoints second input line or NULL
  * \param[out] ALines array of new lines created from original A line
  * \param[out] BLines array of new lines created from original B line
  * \param[out] nalines number of new lines (ALines)
@@ -598,6 +598,12 @@
     APnts = APoints;
     BPnts = BPoints;
+    same = 0;
+    if (!BPoints) {
+	BPnts = APoints;
+	same = 1;
     ABPnts[0] = APnts;
     ABPnts[1] = BPnts;
@@ -659,26 +665,26 @@
      *  we have to break both A and B  at once i.e. in one Vect_line_intersection () call.
-    if (!Vect_box_overlap(ABox, BBox)) {
-	*nalines = 0;
-	*nblines = 0;
+    if (!same && !Vect_box_overlap(ABox, BBox)) {
 	return 0;
     /* overlap box of A line and B line */
-    abbox = *BBox;
-    if (abbox.N > ABox->N)
-	abbox.N = ABox->N;
-    if (abbox.S < ABox->S)
-	abbox.S = ABox->S;
-    if (abbox.E > ABox->E)
-	abbox.E = ABox->E;
-    if (abbox.W < ABox->W)
-	abbox.W = ABox->W;
-    if (abbox.T > ABox->T)
-	abbox.T = ABox->T;
-    if (abbox.B < ABox->B)
-	abbox.B = ABox->B;
+    abbox = *ABox;
+    if (!same) {
+	if (abbox.N > BBox->N)
+	    abbox.N = BBox->N;
+	if (abbox.S < BBox->S)
+	    abbox.S = BBox->S;
+	if (abbox.E > BBox->E)
+	    abbox.E = BBox->E;
+	if (abbox.W < BBox->W)
+	    abbox.W = BBox->W;
+	if (abbox.T > BBox->T)
+	    abbox.T = BBox->T;
+	if (abbox.B < BBox->B)
+	    abbox.B = BBox->B;
     abbox.N += rethresh;
     abbox.S -= rethresh;
@@ -692,20 +698,6 @@
 	return 0;
-    if (APnts->n_points == BPnts->n_points) {
-	same = 1;
-	for (i = 0; i < APnts->n_points; i++) {
-	    if (APnts->x[i] != BPnts->x[i] ||
-	        APnts->y[i] != BPnts->y[i] ||
-		(with_z && APnts->z[i] != BPnts->z[i])) {
-		same = 0;
-		break;
-	if (same)
-	    G_debug(3, "Intersecting different lines");
     /* initialize queue */
     bo_queue.count = 0;
     bo_queue.alloc = 2 * (APnts->n_points + BPnts->n_points);
@@ -789,39 +781,39 @@
 	/* 1. of A seg */
 	seg = cross[i].segment[0];
 	curdist =
-	    dist2(cross[i].x, cross[i].y, APoints->x[seg], APoints->y[seg]);
-	x = APoints->x[seg];
-	y = APoints->y[seg];
+	    dist2(cross[i].x, cross[i].y, APnts->x[seg], APnts->y[seg]);
+	x = APnts->x[seg];
+	y = APnts->y[seg];
 	cross[i].distance[0] = curdist;
 	/* 2. of A seg */
 	dist =
-	    dist2(cross[i].x, cross[i].y, APoints->x[seg + 1],
-		  APoints->y[seg + 1]);
+	    dist2(cross[i].x, cross[i].y, APnts->x[seg + 1],
+		  APnts->y[seg + 1]);
 	if (dist < curdist) {
 	    curdist = dist;
-	    x = APoints->x[seg + 1];
-	    y = APoints->y[seg + 1];
+	    x = APnts->x[seg + 1];
+	    y = APnts->y[seg + 1];
 	/* 1. of B seg */
 	seg = cross[i].segment[1];
 	dist =
-	    dist2(cross[i].x, cross[i].y, BPoints->x[seg], BPoints->y[seg]);
+	    dist2(cross[i].x, cross[i].y, BPnts->x[seg], BPnts->y[seg]);
 	cross[i].distance[1] = dist;
 	    curdist = dist;
-	    x = BPoints->x[seg];
-	    y = BPoints->y[seg];
+	    x = BPnts->x[seg];
+	    y = BPnts->y[seg];
 	/* 2. of B seg */
-	dist = dist2(cross[i].x, cross[i].y, BPoints->x[seg + 1], BPoints->y[seg + 1]);
+	dist = dist2(cross[i].x, cross[i].y, BPnts->x[seg + 1], BPnts->y[seg + 1]);
 	    curdist = dist;
-	    x = BPoints->x[seg + 1];
-	    y = BPoints->y[seg + 1];
+	    x = BPnts->x[seg + 1];
+	    y = BPnts->y[seg + 1];
 	if (curdist < rethresh * rethresh) {
 	    cross[i].x = x;
@@ -830,10 +822,10 @@
 	    /* Update distances along segments */
-		dist2(APoints->x[seg], APoints->y[seg], cross[i].x, cross[i].y);
+		dist2(APnts->x[seg], APnts->y[seg], cross[i].x, cross[i].y);
-		dist2(BPoints->x[seg], BPoints->y[seg], cross[i].x, cross[i].y);
+		dist2(BPnts->x[seg], BPnts->y[seg], cross[i].x, cross[i].y);
@@ -850,17 +842,17 @@
 	if (l == 1) {
 	    G_debug(2, "Clean and create array for line A");
-	    Points = APoints;
-	    Points1 = APoints;
-	    Points2 = BPoints;
+	    Points = APnts;
+	    Points1 = APnts;
+	    Points2 = BPnts;
 	    current = 0;
 	    second = 1;
 	else {
 	    G_debug(2, "Clean and create array for line B");
-	    Points = BPoints;
-	    Points1 = BPoints;
-	    Points2 = APoints;
+	    Points = BPnts;
+	    Points1 = BPnts;
+	    Points2 = APnts;
 	    current = 1;
 	    second = 0;
