[GRASS-SVN] r62189 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Sun Oct 5 18:20:50 PDT 2014
Author: wenzeslaus
Date: 2014-10-05 18:20:50 -0700 (Sun, 05 Oct 2014)
New Revision: 62189
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/main.py
grass/trunk/lib/python/gunittest/runner.py
grass/trunk/lib/python/gunittest/utils.py
gunittest: basic support for Python 2.6 and appropriate help for individual test file
Only import of modules is supposed to work with 2.6 to allow documentation build and perhaps running the machinery.
However, the individual tests may or may not work since a lot of assert methods and set up class step are missing and are impossible to provide without reimplementing unittest for 2.7. The full compatibility for 2.6 would be possible with unittest2 which even provides 3.2 features in 2.7 but this is a package which has to be installed separately.
The default help is fortunately the right one. The other help is not meant for individual files and is not possible to easily import for both 2.6 and 2.7 (and is not part of the API).
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2014-10-05 19:10:48 UTC (rev 62188)
+++ grass/trunk/lib/python/gunittest/case.py 2014-10-06 01:20:50 UTC (rev 62189)
@@ -17,7 +17,6 @@
import StringIO
import unittest
-from unittest.util import safe_repr
from grass.pygrass.modules import Module
from grass.exceptions import CalledModuleError
@@ -26,6 +25,7 @@
from .checkers import (check_text_ellipsis,
text_to_keyvalue, keyvalue_equals, diff_keyvalue,
file_md5, files_equal_md5)
+from .utils import safe_repr
class TestCase(unittest.TestCase):
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2014-10-05 19:10:48 UTC (rev 62188)
+++ grass/trunk/lib/python/gunittest/invoker.py 2014-10-06 01:20:50 UTC (rev 62189)
@@ -17,9 +17,6 @@
import string
import subprocess
-from unittest.main import TestProgram, USAGE_AS_MAIN
-TestProgram.USAGE = USAGE_AS_MAIN
from .checkers import text_to_keyvalue
from .loader import GrassTestLoader, discover_modules
Modified: grass/trunk/lib/python/gunittest/main.py
--- grass/trunk/lib/python/gunittest/main.py 2014-10-05 19:10:48 UTC (rev 62188)
+++ grass/trunk/lib/python/gunittest/main.py 2014-10-06 01:20:50 UTC (rev 62189)
@@ -15,8 +15,7 @@
import sys
import argparse
+from unittest.main import TestProgram
from .runner import (GrassTestRunner, MultiTestResult,
Modified: grass/trunk/lib/python/gunittest/runner.py
--- grass/trunk/lib/python/gunittest/runner.py 2014-10-05 19:10:48 UTC (rev 62188)
+++ grass/trunk/lib/python/gunittest/runner.py 2014-10-06 01:20:50 UTC (rev 62189)
@@ -18,8 +18,7 @@
import sys
import time
-import unittest.result
-from unittest.signals import registerResult
+import unittest
__unittest = True
@@ -40,7 +39,7 @@
self.write('\n') # text-mode streams translate to \r\n if needed
-class TestResult(unittest.result.TestResult):
+class TestResult(unittest.TestResult):
# descriptions and verbosity unused
# included for compatibility with unittest's TestResult
# where are also unused, so perhaps we can remove them
@@ -473,7 +472,7 @@
def run(self, test):
"Run the given test case or test suite."
result = self._result
- registerResult(result)
+ unittest.registerResult(result)
result.failfast = self.failfast
result.buffer = self.buffer
startTime = time.time()
Modified: grass/trunk/lib/python/gunittest/utils.py
--- grass/trunk/lib/python/gunittest/utils.py 2014-10-05 19:10:48 UTC (rev 62188)
+++ grass/trunk/lib/python/gunittest/utils.py 2014-10-06 01:20:50 UTC (rev 62189)
@@ -58,3 +58,17 @@
import __builtin__
__builtin__._ = new_translator
+_MAX_LENGTH = 80
+# taken from unittest.util (Python 2.7) since it is not part of API
+# but we need it for the same reason as it is used un unittest's TestCase
+def safe_repr(obj, short=False):
+ try:
+ result = repr(obj)
+ except Exception:
+ result = object.__repr__(obj)
+ if not short or len(result) < _MAX_LENGTH:
+ return result
+ return result[:_MAX_LENGTH] + ' [truncated]...'
