[GRASS-SVN] r62190 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Sun Oct 5 20:33:01 PDT 2014
Author: wenzeslaus
Date: 2014-10-05 20:33:01 -0700 (Sun, 05 Oct 2014)
New Revision: 62190
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/lmgr: expand user directory for fake cd command; improve error handling from r59388 by accepting only one parameter (#2152)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-10-06 01:20:50 UTC (rev 62189)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-10-06 03:33:01 UTC (rev 62190)
@@ -205,6 +205,7 @@
except:
pass
else:
+ # does center (of screen) make sense for lmgr?
self.Centre()
self.Layout()
@@ -963,8 +964,12 @@
:param cmd: command as a list (must start with 'cd')
# local functions
- def write_beginning(directory):
- self._giface.WriteCmdLog('cd "' + directory + '"')
+ def write_beginning(parameter=None, command=None):
+ if parameter:
+ self._giface.WriteCmdLog('cd "' + parameter + '"')
+ else:
+ # naive concat but will be enough most of the time
+ self._giface.WriteCmdLog(' '.join(command))
def write_changed():
self._giface.WriteLog(_("Working directory changed to:\n\"%s\"")
@@ -973,21 +978,42 @@
def write_end():
self._giface.WriteCmdLog(' ')
+ def write_help():
+ self._giface.WriteLog(_("Changes current working directory"
+ " for this GUI."))
+ self._giface.WriteLog(_("Usage: cd [directory]"))
+ self._giface.WriteLog(_("Without parameters it opens a dialog."))
+ # TODO: the following is longer then 80 chars
+ # but this should be solved by the function not caller
+ # also because of translations
+ self._giface.WriteLog(_("If ~ (tilde) is present as the first"
+ " directory on the path, it is replaced"
+ " by user's home directory."))
# check correctness of cmd
- if cmd and (cmd[0] != 'cd' or len(cmd) > 2):
- raise ValueError("OnChangeCWD cmd parameter must be list with"
+ if cmd and cmd[0] != 'cd':
+ # this is programmer's error
+ # can be relaxed in future
+ # but keep it strict unless needed otherwise
+ raise ValueError("OnChangeCWD cmd parameter must be list of"
" lenght 1 or 2 and 'cd' as a first item")
+ if cmd and len(cmd) > 2:
+ # this might be a user error
+ write_beginning(command=cmd)
+ self._giface.WriteError(_("More than one parameter provided."))
+ write_help()
+ write_end()
+ return
# use chdir or dialog
if cmd and len(cmd) == 2:
- write_beginning(cmd[1])
- if cmd[1] in ['-h', '--h', '--help']:
- self._giface.WriteLog(_("Changes current working directory"
- " for this GUI."))
- self._giface.WriteLog(_("Usage: cd [directory]"))
+ write_beginning(parameter=cmd[1])
+ if cmd[1] in ['-h', '--h', '--help', 'help']:
+ write_help()
write_end()
return
try:
- os.chdir(cmd[1])
+ path = os.path.expanduser(cmd[1])
+ os.chdir(path)
write_changed()
except OSError as error:
self._giface.WriteError(str(error))
@@ -1000,7 +1026,7 @@
if dlg.ShowModal() == wx.ID_OK:
self.cwdPath = dlg.GetPath() # is saved in the workspace
- write_beginning(self.cwdPath)
+ write_beginning(parameter=self.cwdPath)
write_changed()
write_end()
