[GRASS-SVN] r62210 - grass/trunk/raster/r.neighbors
svn_grass at osgeo.org
Tue Oct 7 17:21:13 PDT 2014
Author: annakrat
Date: 2014-10-07 17:21:13 -0700 (Tue, 07 Oct 2014)
New Revision: 62210
grass/trunk/raster/r.neighbors/r.neighbors.html
r.neighbors: remove obsolete part from manual about running module on command line
Modified: grass/trunk/raster/r.neighbors/r.neighbors.html
--- grass/trunk/raster/r.neighbors/r.neighbors.html 2014-10-07 20:02:06 UTC (rev 62209)
+++ grass/trunk/raster/r.neighbors/r.neighbors.html 2014-10-08 00:21:13 UTC (rev 62210)
@@ -11,14 +11,6 @@
appearing in its 3 x 3 cell "neighborhood" in the input
layer.
-<p>
-The program will be run non-interactively if the user
-specifies program arguments (see OPTIONS) on the command
-line. Alternately, the user can simply type
-<em><b>r.neighbors</b></em> on the command line, without program
-arguments. In this case, the user will be prompted for
-flag settings and parameter values.
<h3>OPTIONS</h3>
The user must specify the names of the raster map layers to
