[GRASS-SVN] r62211 - in grass/branches/releasebranch_7_0: . raster/r.neighbors
svn_grass at osgeo.org
Tue Oct 7 17:22:20 PDT 2014
Author: annakrat
Date: 2014-10-07 17:22:20 -0700 (Tue, 07 Oct 2014)
New Revision: 62211
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/raster/r.neighbors/r.neighbors.html
r.neighbors: remove obsolete part from manual about running module on command line (merge from trunk, r62210)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62035,62046,62060-62061,62095,62099,62114,62122,62128,62130-62131,62148,62170,62174,62200
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62035,62046,62060-62061,62095,62099,62114,62122,62128,62130-62131,62148,62170,62174,62200,62210
Modified: grass/branches/releasebranch_7_0/raster/r.neighbors/r.neighbors.html
--- grass/branches/releasebranch_7_0/raster/r.neighbors/r.neighbors.html 2014-10-08 00:21:13 UTC (rev 62210)
+++ grass/branches/releasebranch_7_0/raster/r.neighbors/r.neighbors.html 2014-10-08 00:22:20 UTC (rev 62211)
@@ -11,14 +11,6 @@
appearing in its 3 x 3 cell "neighborhood" in the input
layer.
-<p>
-The program will be run non-interactively if the user
-specifies program arguments (see OPTIONS) on the command
-line. Alternately, the user can simply type
-<em><b>r.neighbors</b></em> on the command line, without program
-arguments. In this case, the user will be prompted for
-flag settings and parameter values.
<h3>OPTIONS</h3>
The user must specify the names of the raster map layers to
